查看: 2822|回复: 10
[求助] 请问如何提取实体的边?
发表于 2016-7-26 21:23:52 | 显示全部楼层 |阅读模式
请问如何提取实体的边?实现XEDGES这个命令的功能
已领礼包: 859个
发表于 2016-7-26 22:36:03 来自手机 | 显示全部楼层
查手册中 AcBrep 类
我大概知道是用Autodesk.AutoCAD.BoundaryRepresentation的Edge中的GetCurveAsNurb(),就是没搞明白怎么用  详情 回复 发表于 2016-7-26 23:16
 楼主| 发表于 2016-7-26 23:16:01 | 显示全部楼层
csharp 发表于 2016-7-26 22:36
查手册中 AcBrep 类
给你贴段代码,选择3DSOLID的子实体的,你可以参照下看看.NET如何操作BREP类 The following command illustrates a way to prompt user for subentity selection on a solid3d. It allows to select a single s  详情 回复 发表于 2016-7-26 23:39
已领礼包: 6个
发表于 2016-7-26 23:39:51 | 显示全部楼层
The following command illustrates a way to prompt user for subentity selection on a solid3d. It allows to select a single subentity and checks if the selected subentity type matches the specified type.
After the subentity has been selected, it uses the Brep API and retrieve the Brep entity representing this subentity. Further methods of the Brep object can be invoked in order to analyze the properties of the subentity.
  1. [CommandMethod("SubEntSelectBrep")]
  2. public void SubEntSelectBrep()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     PromptKeywordOptions pko = new PromptKeywordOptions(
  8.         "\nSpecify sub-entity selection type:");
  9.     pko.AllowNone = false;
  10.     pko.Keywords.Add("Face");
  11.     pko.Keywords.Add("Edge");
  12.     pko.Keywords.Add("Vertex");
  13.     pko.Keywords.Default = "Face";
  14.     PromptResult pkr = ed.GetKeywords(pko);
  15.     if (pkr.Status != PromptStatus.OK)
  16.         return;
  17.     SubentityType subentityType = SubentityType.Null;
  18.     switch(pkr.StringResult)
  19.     {
  20.         case "Face":
  21.             subentityType = SubentityType.Face;
  22.             break;
  23.         case "Edge":
  24.             subentityType = SubentityType.Edge;
  25.             break;
  26.         case "Vertex":
  27.             subentityType = SubentityType.Vertex;
  28.             break;
  29.         default:
  30.             return;
  31.     }
  32.     PromptSelectionOptions pso = new PromptSelectionOptions();
  33.     pso.MessageForAdding = "\nSelect solid " +
  34.         pkr.StringResult + ": ";
  35.     pso.SingleOnly = true;
  36.     pso.SinglePickInSpace = true;
  37.     pso.ForceSubSelections = true;
  38.     PromptSelectionResult psr = ed.GetSelection(pso);
  39.     if (psr.Status != PromptStatus.OK)
  40.         return;
  41.     SelectionSet ss = psr.Value;
  42.     SelectedObject so = ss[0];
  43.     if (!so.ObjectId.ObjectClass.IsDerivedFrom(
  44.         RXClass.GetClass(typeof(Solid3d))))
  45.     {
  46.         ed.WriteMessage(
  47.             "\nYou didn't select a solid, please try again...");
  48.         return;
  49.     }
  50.     using (Transaction Tx = db.TransactionManager.StartTransaction())
  51.     {
  52.         Solid3d solid = Tx.GetObject(so.ObjectId, OpenMode.ForRead)
  53.             as Solid3d;
  54.         SelectedSubObject[] sso = so.GetSubentities();
  55.         //Checks that selected type matches keyword selection
  56.         if (subentityType != sso[0].FullSubentityPath.SubentId.Type)
  57.         {
  58.             ed.WriteMessage("\nInvalid Subentity Type: " +
  59.                 sso[0].FullSubentityPath.SubentId.Type +
  60.                 ", please try again...");
  61.             return;
  62.         }
  63.         SubentityId subentityId = sso[0].FullSubentityPath.SubentId;
  64.         //Creates subentity path to use with GetSubentity
  65.         FullSubentityPath subEntityPath = new FullSubentityPath(
  66.             new ObjectId[] { solid.ObjectId },
  67.             subentityId);
  68.         //Returns a non-database resident entity
  69.         //that represents the subentity
  70.         using (Entity entity = solid.GetSubentity(subEntityPath))
  71.         {
  72.             ed.WriteMessage("\nSubentity Entity Type: "
  73.                 + entity.ToString());
  74.         }
  75.         //Creates entity path to generate Brep object from it
  76.         FullSubentityPath entityPath = new FullSubentityPath(
  77.             new ObjectId[] { solid.ObjectId },
  78.             new SubentityId(SubentityType.Null, IntPtr.Zero));
  79.         using (Brep brep = new Brep(entityPath))
  80.         {
  81.             switch (subentityType)
  82.             {
  83.                 case SubentityType.Face:
  84.                     foreach (
  85.                         Autodesk.AutoCAD.BoundaryRepresentation.Face
  86.                             face in brep.Faces)
  87.                     {
  88.                         if (subentityId ==
  89.                             face.SubentityPath.SubentId)
  90.                         {
  91.                             ed.WriteMessage("\nSu**ce: "
  92.                                 + face.Su**ce.ToString());
  93.                             break;
  94.                         }
  95.                     }
  96.                     break;
  97.                 case SubentityType.Edge:
  98.                     foreach (
  99.                         Autodesk.AutoCAD.BoundaryRepresentation.Edge
  100.                            edge
  101.                         in brep.Edges)
  102.                     {
  103.                         if (subentityId ==
  104.                             edge.SubentityPath.SubentId)
  105.                         {
  106.                             ed.WriteMessage("\nCurve: " +
  107.                                 edge.Curve.ToString());
  108.                             break;
  109.                         }
  110.                     }
  111.                     break;
  112.                 case SubentityType.Vertex:
  113.                     foreach (
  114.                        Autodesk.AutoCAD.BoundaryRepresentation.Vertex
  115.                            vertex
  116.                         in brep.Vertices)
  117.                     {
  118.                         if (subentityId ==
  119.                             vertex.SubentityPath.SubentId)
  120.                         {
  121.                             ed.WriteMessage("\nPoint: " +
  122.                                 PointToStr(vertex.Point));
  123.                             break;
  124.                         }
  125.                     }
  126.                     break;
  127.                 default:
  128.                     break;
  129.             }
  130.         }
  131.         Tx.Commit();
  132.     }
  133. }
游客,如果您要查看本帖隐藏内容请回复
现在倒是能获取到边了,也能给这些边改个颜色了,可是怎么获取这些边的曲线的类型,并根据不同的类型生成实体呢? ObjectId[] ids = new ObjectId[] { solid.ObjectId }; Subent  详情 回复 发表于 2016-7-29 13:01
谢谢提供代码,我琢磨琢磨  详情 回复 发表于 2016-7-27 21:13
已领礼包: 4044个
发表于 2016-7-27 08:08:09 | 显示全部楼层
回复学习学习!:lol
 楼主| 发表于 2016-7-27 21:13:46 | 显示全部楼层
谢谢提供代码,我琢磨琢磨
 楼主| 发表于 2016-7-29 13:01:47 | 显示全部楼层
谢谢,终于搞定这个问题了。
发表于 2017-6-27 21:07:46 | 显示全部楼层
学习学习了,,,,,,,,,,,,,,,,,
发表于 2017-7-1 07:01:36 | 显示全部楼层
大神,,,这代码怎么用的,出错不知道怎么处理呀 ,
已领礼包: 2个
发表于 2018-11-24 10:38:38 | 显示全部楼层
谢谢老板,参考参考代码
发表于 2020-9-21 18:31:35 | 显示全部楼层
666666666666666
GMT+8, 2026-11-3 04:02 , Processed in 0.530810 second(s), 53 queries , Gzip On.
