查看: 10778|回复: 31
[每日一码] 图块位置不变的情况下重设块的插入点
发表于 2016-8-14 08:30:02 | 显示全部楼层 |阅读模式
Resetting the origins of block table records in a drawing
Issue
I have a drawing that contains block table records with non-zero origins, i.e.
they are not set to (0, 0, 0). How can I reset these origins without moving the
positions of all the block's sub-entities in the drawing?
Solution
The following code demonstrates how to modify a block table record's
origin and compensate by moving the insertion point of each of the associated
block references.
Please add the function 'testFunc' as a command.
  1. void ResetAllInstances(AcDbBlockTableRecord * pBlockTableRecord, AcGeVector3d &translation)
  2. {
  3. // Note that this function does not implement any error checking.
  4. // We are assuming that pBlockTableREcord was opened for write by the calling function
  5. // Iterate through all block references of this block table record.
  6. AcDbBlockReferenceIdIterator * pIterator;
  7. pBlockTableRecord->newBlockReferenceIdIterator(pIterator);
  8. for (pIterator->start();!pIterator->done();pIterator->step())
  9. {
  10.   AcDbBlockReference * pBlockRef;
  11.   pIterator->getBlockReference(pBlockRef, AcDb::kForWrite,true);
  12.   // Transform the translation vector from block coordinates to world coordinates.
  13.   AcGeVector3d realTranslation = (pBlockRef->blockTransform())*translation;
  14.   // Translate the block reference to counter the effect of the origin change.
  15.   pBlockRef->setPosition(pBlockRef->position()+realTranslation);
  16.   pBlockRef->close();
  17. } // Next block reference
  18. delete pIterator;
  19. }
下面是测试命令SGP
游客,如果您要查看本帖隐藏内容请回复
发表于 2016-8-15 09:20:20 | 显示全部楼层
学习学习学习
发表于 2016-8-23 11:17:56 | 显示全部楼层
看看怎么样,貌似不错的样子啊
发表于 2016-8-23 11:20:10 | 显示全部楼层
不太懂arc,完全蒙了不明觉厉的感觉
发表于 2016-9-1 11:07:57 | 显示全部楼层
回复学习
发表于 2016-9-3 11:02:05 | 显示全部楼层
很好,谢谢分享
发表于 2016-9-4 14:57:40 | 显示全部楼层
我也来学习学习
发表于 2017-1-26 11:05:49 | 显示全部楼层
学习!!!!!!!!!!!!!
发表于 2017-2-10 10:18:31 | 显示全部楼层
btrbtrbtrbtr
发表于 2017-2-21 17:19:44 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!!!!
发表于 2017-2-27 15:39:38 | 显示全部楼层
我来学习学习是怎么回事?
发表于 2017-3-22 10:35:20 | 显示全部楼层
RE: 图块位置不变的情况下重设块的插入点 [修改]
发表于 2017-3-31 22:55:29 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-5-19 10:51:16 | 显示全部楼层
谢谢分享,回复学习
发表于 2017-5-20 00:06:52 | 显示全部楼层
我写的块会变位置
GMT+8, 2026-11-22 07:21 , Processed in 0.423190 second(s), 36 queries , Gzip On, File On.
