查看: 2759|回复: 4
[求助] 人民币大写转换
发表于 2016-8-16 09:11:20 | 显示全部楼层 |阅读模式
人民币大写在线转换工具
http://www.ad75.cn/tool/rmb.html
感觉这个功能有点牛
那位大师
出手小试一下
开发一个CAD中的此程序
也让新手学习一下
发表于 2016-8-16 09:42:17 | 显示全部楼层
早就有了,自己动手搜,另外你是金牌会员,明经是钻石会员,为什么自己不学,不动手,总是寄托给别人呢?
搜我会的 只是没搜到 大师们不方便就算了 没关系的  详情 回复 发表于 2016-8-16 10:24
 楼主| 发表于 2016-8-16 10:24:31 | 显示全部楼层
搜我会的
只是没搜到
大师们不方便就算了
没关系的
发表于 2016-8-16 21:24:37 | 显示全部楼层
抽空写了一个,看下开源函数库的函数  http://bbs.xdcad.net/thread-705086-1-1.html
发表于 2016-8-16 22:02:23 | 显示全部楼层
这是网页的转换代码
function convertCurrency(currencyDigits) {
// Constants:
    var MAXIMUM_NUMBER = 99999999999.99;
    // Predefine the radix characters and currency symbols for output:
    var CN_ZERO = "零";
    var CN_ONE = "壹";
    var CN_TWO = "贰";
    var CN_THREE = "叁";
    var CN_FOUR = "肆";
    var CN_FIVE = "伍";
    var CN_SIX = "陆";
    var CN_SEVEN = "柒";
    var CN_EIGHT = "捌";
    var CN_NINE = "玖";
    var CN_TEN = "拾";
    var CN_HUNDRED = "佰";
    var CN_THOUSAND = "仟";
    var CN_TEN_THOUSAND = "万";
    var CN_HUNDRED_MILLION = "亿";
    var CN_SYMBOL = "";
    var CN_DOLLAR = "元";
    var CN_TEN_CENT = "角";
    var CN_CENT = "分";
    var CN_INTEGER = "整";
// Variables:
    var integral;    // Represent integral part of digit number.
    var decimal;    // Represent decimal part of digit number.
    var outputCharacters;    // The output result.
    var parts;
    var digits, radices, bigRadices, decimals;
    var zeroCount;
    var i, p, d;
    var quotient, modulus;
// Validate input string:
    currencyDigits = currencyDigits.toString();
    if (currencyDigits == "") {
        alert("Empty input!");
        return "";
    if (currencyDigits.match(/[^,.\d]/) != null) {
        alert("Invalid characters in the input string!");
        return "";
    if ((currencyDigits).match(/^((\d{1,3}(,\d{3})*(.((\d{3},)*\d{1,3}))?)|(\d+(.\d+)?))$/) == null) {
        alert("Illegal format of digit number!");
        return "";
// Normalize the format of input digits:
    currencyDigits = currencyDigits.replace(/,/g, "");    // Remove comma delimiters.
    currencyDigits = currencyDigits.replace(/^0+/, "");    // Trim zeros at the beginning.
    // Assert the number is not greater than the maximum number.
    if (Number(currencyDigits) > MAXIMUM_NUMBER) {
        alert("Too large a number to convert!");
        return "";
// Process the coversion from currency digits to characters:
    // Separate integral and decimal parts before processing coversion:
    parts = currencyDigits.split(".");
    if (parts.length > 1) {
        integral = parts[0];
        decimal = parts[1];
        // Cut down redundant decimal digits that are after the second.
        decimal = decimal.substr(0, 2);
    else {
        decimal = "";
    // Prepare the characters corresponding to the digits:
    digits = new Array(CN_ZERO, CN_ONE, CN_TWO, CN_THREE, CN_FOUR, CN_FIVE, CN_SIX, CN_SEVEN, CN_EIGHT, CN_NINE);
    radices = new Array("", CN_TEN, CN_HUNDRED, CN_THOUSAND);
    bigRadices = new Array("", CN_TEN_THOUSAND, CN_HUNDRED_MILLION);
    decimals = new Array(CN_TEN_CENT, CN_CENT);
    // Start processing:
    outputCharacters = "";
    // Process integral part if it is larger than 0:
    if (Number(integral) > 0) {
        zeroCount = 0;
        for (i = 0; i < integral.length; i++) {
            p = integral.length - i - 1;
            d = integral.substr(i, 1);
            quotient = p / 4;
            modulus = p % 4;
            if (d == "0") {
                zeroCount++;
            else {
                if (zeroCount > 0)
                    outputCharacters += digits[0];
                zeroCount = 0;
                outputCharacters += digits[Number(d)] + radices[modulus];
            if (modulus == 0 && zeroCount < 4) {
                outputCharacters += bigRadices[quotient];
        outputCharacters += CN_DOLLAR;
    // Process decimal part if there is:
    if (decimal != "") {
        for (i = 0; i < decimal.length; i++) {
            d = decimal.substr(i, 1);
            if (d != "0") {
                outputCharacters += digits[Number(d)] + decimals[i];
    // Confirm and return the final output string:
    if (outputCharacters == "") {
        outputCharacters = CN_ZERO + CN_DOLLAR;
    if (decimal == "") {
        outputCharacters += CN_INTEGER;
    outputCharacters = CN_SYMBOL + outputCharacters;
    return outputCharacters;
GMT+8, 2026-11-22 07:55 , Processed in 0.324552 second(s), 20 queries , Gzip On, File On.
