查看: 7508|回复: 44
[每日一码] 设置支持路径
发表于 2016-9-9 11:05:12 | 显示全部楼层 |阅读模式
LISP代码:
  1. (defun c:tt ()                               ; set the path to the subdirectory.
  2.   (setq netpath
  3.         "C:\\Users\\Paul&Jen\\Documents\\_Library\\_PlaceLab\\AutoCAD"
  4.   )                                       ; set the support paths to the
  5.                                        ; autocad default
  6.   (setenv "ACAD" "")                       ; store the default paths
  7.   (setq defpath (getenv "ACAD"))       ; set up the support file search
  8.                                        ; paths
  9.   (setenv "ACAD" (strcat defpath ";" netpath ";" netpath "\\" "Blocks;"
  10.                          netpath "\\" "Lisp;" netpath "\\" "Logos;" netpath
  11.                          "\\" "PC3;" netpath "\\" "Plotstyles;"
  12.                  )
  13.   )
  14. )
VLISP代码:
[it618postdisplay>0]
  1. (defun c:tt ()                               ; resets the paths usefull for
  2.                                        ; update versions of autocad
  3.                                        ; by bigal 2011
  4.                                        ; this sets a reference to the
  5.                                        ; install path of your product
  6.                                        ; the gets are their for info maybe
  7.                                        ; other use
  8.                                        ; use this to find other settings
  9.                                        ; (vlax-dump-object (vla-get-files
  10.                                        ; (vla-get-preferences
  11.                                        ; (vlax-get-acad-
  12.                                        ; object))) t)
  13.   (vl-load-com)                               ; make temp directory
  14.                                        ; (vl-mkdir "c:\\acadtemp")
  15.   (setq *files* (vla-get-files (vla-get-preferences
  16.                                                     (vlax-get-acad-object)
  17.                                )
  18.                 )
  19.   )                                       ; savepath
  20.                                        ; (vla-get-autosavepath *files*)
  21.   (vla-put-autosavepath *files* "C:\\AcadTemp")        ; custom icons
  22.                                        ; (vla-get-customiconpath *files*))
  23.   (vla-put-customiconpath *files* "P:\\Autodesk\\ICONS") ; custom menu
  24.                                        ; (vla-get-menufile *files*))
  25.   (vla-put-menufile *files* "C:\\Users\\BIGAL")        ; printers config
  26.                                        ; (vla-get-printerconfigpath
  27.                                        ; *files*)
  28.   (vla-put-printerconfigpath *files*
  29.                              "P:\\AutoDESK\\Plotting\\Plot Styles 2011"
  30.   )                                       ; printers style sheet
  31.                                        ; (vla-get-printerstylesheetpath
  32.                                        ; *files*)
  33.   (vla-put-printerstylesheetpath *files*
  34.                                  "P:\\AutoDESK\\Plotting\\Plot Styles"
  35.   )                                       ; printer drv's
  36.                                        ; (vla-get-printerdescpath *files*)
  37.   (vla-put-printerdescpath *files* "P:\\AutoDESK\\Plotting\\Drv") ; print
  38.                                        ; spooler
  39.                                        ; (vla-get-printspoolerpath *files*)
  40.   (vla-put-printspoolerpath *files* "C:\\AcadTemp\\") ; template  path
  41.                                        ; (vla-get-templatedwgpath *files*)
  42.   (vla-put-templatedwgpath *files* "P:\\Autodesk\\c3d Templates") ; templat
  43.                                        ; e location
  44.                                        ; (vla-get-qnewtemplatefile *files*)
  45.   (vla-put-qnewtemplatefile *files* "P:\\Autodesk\\c3d Templates\\my.dwt") ; make new support paths exist + new
  46.   (setq paths (vla-get-supportpath *files*))
  47.   (setq coggpaths "P:\\autodesk\\supportfiles;P:\\autodesk\\lisp;P:\\autodesk\\fonts;P:\\autodesk\\hfs fonts")
  48.   (setq newpath (strcat coggpaths paths))
  49.   (vla-put-supportpath *files* newpath)        ; tempdirectory
  50.                                        ; (vla-get-tempfilepath *files*))
  51.   (vla-put-tempfilepath *files* "C:\\AcadTemp\\") ;   plotlogfilepath =
  52.                                        ; "c:\\documents and
  53.                                        ; settings\\ad\\local
  54.                                        ; settings\\application
  55.                                        ; data\\autodesk\\c3d 2011\\enu\\"
  56.   (vla-put-plotlogfilepath *files* "C:\\AcadTemp\\") ;   logfilepath =
  57.                                        ; "c:\\documents and
  58.                                        ; settings\\ad\\local
  59.                                        ; settings\\application
  60.                                        ; data\\autodesk\\c3d 2011\\enu\\"
  61.   (vla-put-logfilepath *files* "C:\\AcadTemp\\") ; xref temp path
  62.                                        ; (vla-get-tempxrefpath *files*))
  63.   (vla-put-tempxrefpath *files* "C:\\AcadTemp\\") ; end use of *files*
  64.   (vlax-release-object *files*)               ; exit quitely
  65.   (princ "All Done")
  66. )
[/it618postdisplay]
已领礼包: 60个
发表于 2016-9-9 11:27:46 | 显示全部楼层
学习,看看
已领礼包: 343个
发表于 2016-9-9 15:12:42 | 显示全部楼层
学习,看看
已领礼包: 5800个
发表于 2016-9-9 16:55:33 | 显示全部楼层
谢谢楼主!!!
已领礼包: 3777个
发表于 2016-9-9 20:22:50 | 显示全部楼层
看看,有什么可以利用的
已领礼包: 3777个
发表于 2016-9-9 20:24:15 | 显示全部楼层
学习学习学习学习学习
已领礼包: 6881个
发表于 2016-9-9 20:43:34 | 显示全部楼层
学习学习再学习
已领礼包: 6468个
发表于 2016-9-10 22:02:44 | 显示全部楼层
看看隐藏的是什么
已领礼包: 6468个
发表于 2016-9-10 22:04:42 | 显示全部楼层
回复了还是看不到
已领礼包: 194个
发表于 2016-9-11 09:26:30 | 显示全部楼层
学习学习!
已领礼包: 41个
发表于 2017-1-28 23:57:32 | 显示全部楼层
看看,有什么可以利用的
已领礼包: 1904个
财富等级: 堆金积玉
发表于 2017-1-31 17:32:45 | 显示全部楼层
学习一下,谢谢
已领礼包: 3043个
发表于 2017-2-2 21:00:36 | 显示全部楼层
回帖学习学习!
发表于 2017-2-7 08:27:55 | 显示全部楼层
看看,有什么可以利用的
已领礼包: 2670个
财富等级: 家财万贯
发表于 2017-2-9 15:29:26 | 显示全部楼层
see the hidden content of this post
GMT+8, 2026-11-3 10:46 , Processed in 0.525712 second(s), 57 queries , Gzip On.
