查看: 5018|回复: 13
[每日一码] 选择SOLID 3D的子实体(面、边、顶点)
已领礼包: 6个
发表于 2016-9-11 00:04:31 | 显示全部楼层 |阅读模式
下面的命令演示了提示用户选取SOLID3D的方法,允许用户选择一个单独的子实体并且检查子实体的类型是否匹配。选取完子实体后,使用BREP API检索表达这个子实体的Brep实体。进一步的使用Brep对象的方法执行分析子实体的属性。
The following command illustrates a way to prompt user for subentity selection on a solid3d. It allows to select a single subentity and checks if the selected subentity type matches the specified type.
After the subentity has been selected, it uses the Brep API and retrieve the Brep entity representing this subentity. Further methods of the Brep object can be invoked in order to analyze the properties of the subentity.
//Command SubEntSelectBrep: Prompts user to select a single
//solid sub-entity and filters type of sub-entity selected.
//Philippe Leefsma, Developer Technical Services. March 2012.
  1. [CommandMethod("SubEntSelectBrep")]
  2. public void SubEntSelectBrep()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     PromptKeywordOptions pko = new PromptKeywordOptions(
  8.         "\nSpecify sub-entity selection type:");
  9.     pko.AllowNone = false;
  10.     pko.Keywords.Add("Face");
  11.     pko.Keywords.Add("Edge");
  12.     pko.Keywords.Add("Vertex");
  13.     pko.Keywords.Default = "Face";
  14.     PromptResult pkr = ed.GetKeywords(pko);
  15.     if (pkr.Status != PromptStatus.OK)
  16.         return;
  17.     SubentityType subentityType = SubentityType.Null;
  18.     switch(pkr.StringResult)
  19.     {
  20.         case "Face":
  21.             subentityType = SubentityType.Face;
  22.             break;
  23.         case "Edge":
  24.             subentityType = SubentityType.Edge;
  25.             break;
  26.         case "Vertex":
  27.             subentityType = SubentityType.Vertex;
  28.             break;
  29.         default:
  30.             return;
  31.     }
  32.     PromptSelectionOptions pso = new PromptSelectionOptions();
  33.     pso.MessageForAdding = "\nSelect solid " +
  34.         pkr.StringResult + ": ";
  35.     pso.SingleOnly = true;
  36.     pso.SinglePickInSpace = true;
  37.     pso.ForceSubSelections = true;
  38.     PromptSelectionResult psr = ed.GetSelection(pso);
  39.     if (psr.Status != PromptStatus.OK)
  40.         return;
  41.     SelectionSet ss = psr.Value;
  42.     SelectedObject so = ss[0];
  43.     if (!so.ObjectId.ObjectClass.IsDerivedFrom(
  44.         RXClass.GetClass(typeof(Solid3d))))
  45.     {
  46.         ed.WriteMessage(
  47.             "\nYou didn't select a solid, please try again...");
  48.         return;
  49.     }
  50.     using (Transaction Tx = db.TransactionManager.StartTransaction())
  51.     {
  52.         Solid3d solid = Tx.GetObject(so.ObjectId, OpenMode.ForRead)
  53.             as Solid3d;
  54.         SelectedSubObject[] sso = so.GetSubentities();
  55.         //Checks that selected type matches keyword selection
  56.         if (subentityType != sso[0].FullSubentityPath.SubentId.Type)
  57.         {
  58.             ed.WriteMessage("\nInvalid Subentity Type: " +
  59.                 sso[0].FullSubentityPath.SubentId.Type +
  60.                 ", please try again...");
  61.             return;
  62.         }
  63.         SubentityId subentityId = sso[0].FullSubentityPath.SubentId;
  64.         //Creates subentity path to use with GetSubentity
  65.         FullSubentityPath subEntityPath = new FullSubentityPath(
  66.             new ObjectId[] { solid.ObjectId },
  67.             subentityId);
  68.         //Returns a non-database resident entity
  69.         //that represents the subentity
  70.         using (Entity entity = solid.GetSubentity(subEntityPath))
  71.         {
  72.             ed.WriteMessage("\nSubentity Entity Type: "
  73.                 + entity.ToString());
  74.         }
  75.         //Creates entity path to generate Brep object from it
  76.         FullSubentityPath entityPath = new FullSubentityPath(
  77.             new ObjectId[] { solid.ObjectId },
  78.             new SubentityId(SubentityType.Null, IntPtr.Zero));
  79.         using (Brep brep = new Brep(entityPath))
  80.         {
  81.             switch (subentityType)
  82.             {
  83.                 case SubentityType.Face:
  84.                     foreach (
  85.                         Autodesk.AutoCAD.BoundaryRepresentation.Face
  86.                             face in brep.Faces)
  87.                     {
  88.                         if (subentityId ==
  89.                             face.SubentityPath.SubentId)
  90.                         {
  91.                             ed.WriteMessage("\nSurface: "
  92.                                 + face.Surface.ToString());
  93.                             break;
  94.                         }
  95.                     }
  96.                     break;
  97.                 case SubentityType.Edge:
  98.                     foreach (
  99.                         Autodesk.AutoCAD.BoundaryRepresentation.Edge
  100.                            edge
  101.                         in brep.Edges)
  102.                     {
  103.                         if (subentityId ==
  104.                             edge.SubentityPath.SubentId)
  105.                         {
  106.                             ed.WriteMessage("\nCurve: " +
  107.                                 edge.Curve.ToString());
  108.                             break;
  109.                         }
  110.                     }
  111.                     break;
  112.                 case SubentityType.Vertex:
  113.                     foreach (
  114.                        Autodesk.AutoCAD.BoundaryRepresentation.Vertex
  115.                            vertex
  116.                         in brep.Vertices)
  117.                     {
  118.                         if (subentityId ==
  119.                             vertex.SubentityPath.SubentId)
  120.                         {
  121.                             ed.WriteMessage("\nPoint: " +
  122.                                 PointToStr(vertex.Point));
  123.                             break;
  124.                         }
  125.                     }
  126.                     break;
  127.                 default:
  128.                     break;
  129.             }
  130.         }
  131.         Tx.Commit();
  132.     }
  133. }
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 9341个
发表于 2016-9-11 10:38:25 | 显示全部楼层
回复查看本帖隐藏内容!!!!!
发表于 2017-7-1 07:02:46 | 显示全部楼层
看看,,,试了下,,出错的不知道怎么处理
已领礼包: 26个
发表于 2017-7-11 08:12:00 | 显示全部楼层
发表于 2018-7-2 14:05:57 | 显示全部楼层
想看看能不能获取三角面
发表于 2018-7-4 08:30:24 | 显示全部楼层
DDDDDDDDDDDDDDDDDDDDDD
发表于 2019-6-8 20:34:14 | 显示全部楼层
1555544222
发表于 2019-9-1 12:01:52 来自手机 | 显示全部楼层
感谢楼主分享!学习中!
来自: 微社区
已领礼包: 58个
发表于 2019-10-22 18:39:03 来自手机 | 显示全部楼层
学习一下,感谢您分享!
来自: 微社区
发表于 2019-11-1 09:13:30 | 显示全部楼层
楼主厉害,正好用来学习学习
发表于 2020-2-21 11:19:34 | 显示全部楼层
学习了
发表于 2020-2-21 12:59:54 | 显示全部楼层
有没有VB.NET
发表于 2020-2-21 17:46:35 | 显示全部楼层
学习!!!!!!!!!!!
发表于 2021-7-14 11:09:24 | 显示全部楼层
回复查看本帖隐藏内容!!!!!
GMT+8, 2026-11-3 11:15 , Processed in 0.513541 second(s), 54 queries , Gzip On.
