查看: 2571|回复: 9
[每日一码] 将多行文本去掉回车变单行的代码
发表于 2016-11-25 22:40:31 | 显示全部楼层 |阅读模式
(defun c:tt ()
  (if (setq e (ssget ":s:e" '((0 . "mtext"))))
    (progn
      (setq e (ssname e 0))
      (setq o        (vlax-ename->vla-object e)
            txt        (vla-get-textstring o)
            txt        (vl-string-translate "\\P" " " txt)
      ) ;_ 结束setq
      (vla-put-TextString o txt)
    ) ;_ 结束progn
  ) ;_ 结束if
  (princ)
) ;_ 结束defun
 楼主| 发表于 2016-11-25 22:54:13 | 显示全部楼层
另外一个写法:
(defun c:tt ()
  (vl-load-com)
  (if (setq ss (ssget '((0 . "MTEXT"))))
    ((lambda (i / e v s)
       (while (setq e (ssname ss (setq i (1+ i))))
         (setq
           s (vla-get-textstring (setq v (vlax-ename->vla-object e)))
         (while        (vl-string-search "\\P" s)
           (setq s (vl-string-subst " " "\\P" s))
         (vla-put-textstring v s)
      -1
  (princ)
 楼主| 发表于 2016-11-25 22:58:47 | 显示全部楼层
反操作, 空格 变 回车 (单行变多行)
(defun C:tt (/ ss n obj)
    (repeat (setq n (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
      (vla-put-textstring
        obj
        (vl-string-translate " " "\n" (vla-get-textstring obj))
      ) ;_ end of vla-put-textstring
    ) ;_ end of repeat
  ) ;_ end of if
  (princ)
) ;_ end of defun
已领礼包: 2226个
发表于 2016-11-26 00:11:22 | 显示全部楼层
正需要,支持楼主大人了!
已领礼包: 6202个
发表于 2016-11-26 03:15:44 | 显示全部楼层
多变单,单变多,全了
已领礼包: 1304个
发表于 2016-11-26 08:12:00 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 9341个
发表于 2016-11-26 09:01:36 | 显示全部楼层
正需要,支持楼主大人了!
已领礼包: 127个
发表于 2016-11-26 09:37:28 | 显示全部楼层
感觉还是多行啊!!!!!!
已领礼包: 1094个
发表于 2021-11-3 06:28:42 | 显示全部楼层
感谢分享 将多行文本去掉回车变单行的代码
发表于 2021-11-6 10:28:22 | 显示全部楼层
Thank you. With Vl function, all Unicode character will be wrong ^^
GMT+8, 2026-11-3 01:42 , Processed in 0.525563 second(s), 47 queries , Gzip On.
