查看: 2782|回复: 7
[每日一码] 清理图形中的APP,给图形减肥
发表于 2017-1-12 22:31:17 | 显示全部楼层 |阅读模式
(defun c:_purge ( / apps doc i n)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq apps (vla-get-registeredapplications doc))
  (setq i (vla-get-count apps))
  (vlax-for n apps (vl-catch-all-apply '(lambda nil
                                          (vla-delete n)
                   ) (vlax-release-object n)
  (setq i (- i (vla-get-count apps)))
  (print (strcat "\n\t已完成清理APPID.[ " (ff_str i) " ].."))
  (vla-purgeall)
  (princ)
发表于 2017-1-13 08:04:12 | 显示全部楼层
(setq a(vla-get-registeredapplications *doc*))
(repeat        (setq n (vlax-get a 'Count))
  (setq b (vla-item a (setq n (1- n))))
  (princ "\n")
  (princ (vlax-get b 'Name))
  (vla-delete b)
这样删除会不会带来不良后果呢?
发表于 2017-1-13 10:18:50 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-1-13 12:04:11 | 显示全部楼层
正需要,支持楼主大人了!
发表于 2017-1-23 15:10:27 | 显示全部楼层
(vla-purgeall (vla-get-activedocument (vlax-get-acad-object)))
发表于 2021-12-7 00:10:15 | 显示全部楼层
感谢分享清理图形中的APP,给图形减肥
发表于 2021-12-9 11:20:06 | 显示全部楼层
ff_str 是什么函数?
GMT+8, 2026-11-22 07:56 , Processed in 0.611401 second(s), 25 queries , Gzip On, File On.
