查看: 1853|回复: 3
[每日一码] 去除MTEXT格式函数
已领礼包: 20个
发表于 2017-1-14 12:43:49 | 显示全部楼层 |阅读模式
(defun @UnFormat (Mtext Formats / All Format1 Format2 Text Str)
  ;; Primary function to perform the format stripping:
  ;; (04-20-03) John F. Uhden, Cadlantic
  ;; Arguments:
  ;;   Mtext   - the Mtext VLA-Object or Ename
  ;;   Formats - a string containing some or all of the following characters:
  ;;     A - Alignment
  ;;     C - Color
  ;;     F - Font
  ;;     H - Height
  ;;     L - Underscore
  ;;     O - Overscore
  ;;     P - Linefeed (Paragraph)
  ;;     Q - Obliquing
  ;;     S - Spacing (Stacking)
  ;;     T - Tracking
  ;;     W - Width
  ;;     ~ - Non-breaking Space
  ;;   Optional Formats -
  ;;     * - All formats
  ;; Returns:
  ;;   nil  - if not a valid Mtext object
  ;;   Text - the Mtext textstring with none, some, or all
  ;;          of the formatting removed, depending on what
  ;;          formats were present and what formats were
  ;;          specified for removal.
  (cond
    ((= (type Mtext) 'VLA-Object))
    ((= (type Mtext) 'ENAME)
     (setq Mtext (vlax-ename->vla-object Mtext))
    (1 (setq Mtext nil))
  (and
    Mtext
    (= (vlax-get Mtext 'ObjectName) "AcDbMText")
    (= (type Formats) 'STR)
    (setq Formats (strcase Formats))
    (setq Mtext (vlax-get Mtext 'TextString))
    (setq Text "")
    (setq All T)
    (if        (= Formats "*")
      (setq Formats "S"
            Format1 "\\[LOP`~]"
            Format2 "\\[ACFHQTW]"
      (progn
        (setq Format1 ""
              Format2 ""
        (foreach item '("L" "O" "P" "~")
          (if (vl-string-search item Formats)
            (setq Format1 (strcat Format1 "`" item))
            (setq All nil)
        (if (= Format1 "")
          (setq Format1 nil)
          (setq Format1 (strcat "\\[" Format1 "]"))
        (foreach item '("A" "C" "F" "H" "Q" "T" "W")
            (setq Format2 (strcat Format2 item))
            (setq All nil)
        (if (= Format2 "")
          (setq Format2 nil)
          (setq Format2 (strcat "\\[" Format2 "]"))
        T
    (while (/= Mtext "")
      (cond
        ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[\\{}]")
         (setq Mtext (substr Mtext 3)
               Text  (strcat Text Str)
        ((and All (wcmatch (substr Mtext 1 1) "[{}]"))
         (setq Mtext (substr Mtext 2))
        ((and Format1 (wcmatch (strcase (substr Mtext 1 2)) Format1))
         (setq Mtext (substr Mtext 3))
        ((and Format2 (wcmatch (strcase (substr Mtext 1 2)) Format2))
         (setq Mtext (substr Mtext (+ 2 (vl-string-search ";" Mtext))))
        ((and (vl-string-search "S" Formats)
              (wcmatch (strcase (substr Mtext 1 2)) "\\S")
         (setq Str   (substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
               Text  (strcat Text (vl-string-translate "#^\\" "   " Str))
               Mtext (substr Mtext (+ 4 (strlen Str)))
        (1
         (setq Text  (strcat Text (substr Mtext 1 1))
  Text
已领礼包: 862个
发表于 2017-1-14 12:53:55 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 7743个
发表于 2017-1-15 17:47:14 | 显示全部楼层
谢谢提供,下载收藏试用了
发表于 2017-10-21 10:05:30 | 显示全部楼层
很好的工具
GMT+8, 2026-11-5 13:54 , Processed in 0.399491 second(s), 34 queries , Gzip On.
