查看: 1589|回复: 0
[分享] 调试ARX程序
发表于 2017-1-20 18:12:00 | 显示全部楼层 |阅读模式
[ScreenCast]feb15244-6824-4c89-90f6-4a778224524a[/ScreenCast]
Also instead of Start debugging (if AutoCAD was started and arx-application is loaded) you can select menu item Attach to Process... and select acad.exe
[ScreenCast]6f597b1d-e0b4-418d-8212-8e9ea80e22dd[/ScreenCast]
It is look like this solution was created not with ObjectARX Wizard. ObjectARX Wizard create next setting for debugger:
You have to set Command to full path to acad.exe
GMT+8, 2026-11-22 11:03 , Processed in 0.319601 second(s), 11 queries , Gzip On, File On.
