查看: 1133|回复: 3
[求助] 程序缺少参数
发表于 2017-4-21 01:02:54 | 显示全部楼层 |阅读模式
一个文件复制的程序。可便捷复制含多级文件夹子目录的文件群。
刚开始还能用,后来不知怎么的又不行了,程序报缺少参数,请大神帮忙改改,谢谢大家
[ pre]
(defun c:anz514562 (/ file path wssh)
  (setq file (qf_getFolder))  ;读取源文件夹
  (setq path "c:\\windows\\assembly\\GAC_MSIL\\cscompmgd\\Yanglingcun")
  (vl-load-com)
  (if (setq wssh (vlax-get-or-create-object "WScript.Shell"))
    (progn
      (vlax-invoke-method
wssh
'Run
(strcat "cmd.exe /c md " path)
0
:vlax-true
      (vlax-invoke-method
wssh
'Run
(strcat "cmd.exe /c copy " File " " path)
0
:vlax-true
      (vlax-release-object wssh)
    (alert "")
(defun qf_getFolder (/ WinShell shFolder path catchit)
  (vl-load-com)
  (setq winshell (vlax-create-object "Shell.Application"))
  (setq shFolder (vlax-invoke-method WinShell 'BrowseForFolder 0 msg 1))
  (setq
    catchit (vl-catch-all-apply
       '(lambda ()
   (setq shFolder (vlax-get-property shFolder 'self))
   (setq path (vlax-get-property shFolder 'path))
  (if (vl-catch-all-error-p catchit)
    nil
    path
[ /pre]
已领礼包: 5800个
发表于 2017-4-21 08:20:02 | 显示全部楼层
c:\\windows目录下是受保护的,建议在其它盘符下建目录
已领礼包: 1304个
发表于 2017-4-21 09:44:07 | 显示全部楼层
确实是难得好帖啊,顶先
GMT+8, 2026-11-5 22:49 , Processed in 0.422023 second(s), 40 queries , Gzip On.
