查看: 6401|回复: 37
[每日一码] LISP动态拖动生成圆代码
发表于 2017-5-5 22:37:30 | 显示全部楼层 |阅读模式
  1. (defun c:test2 ()
  2.   ;;  CAB version 1.2
  3.   ;;  Calling routine to pass a tangent point (p1) & offset distance (od)
  4.   ;;  Routine will allow user to stretch outer circle using diameter
  5.   ;;  Note if offset distance is a negative number the offset circle
  6.   ;;  will be on the outside
  7.   ;;
  8.   ;;  Returns the 2nd pick point
  9.
  10.     (setq rMin 0.001) ; Minimum Radius allowed
  11.     (setq c1
  12.            (entmakex (list (cons 0 "CIRCLE")
  13.                            (cons 6 "BYLAYER")
  14.                            (cons 8 "0")
  15.                            (cons 10 p1)
  16.                            (cons 39 0.0)
  17.                            (cons 40 rMin) ; radius
  18.                            (cons 62 256)
  19.                            (cons 210 (list 0.0 0.0 1.0))
  20.                      )
  21.            )
  22.     )
  23.     (setq c2
  24.            (entmakex (list (cons 0 "CIRCLE")
  25.                            (cons 6 "BYLAYER")
  26.                            (cons 8 "0")
  27.                            (cons 10 p1)
  28.                            (cons 39 0.0)
  29.                            (cons 40 rMin) ; radius
  30.                            (cons 62 256)
  31.                            (cons 210 (list 0.0 0.0 1.0))
  32.                      )
  33.            )
  34.     )
  35.     (setq el1 (entget c1)
  36.           el2 (entget c2)
  37.     )
  38.     ;;  p1 is a tangent point
  39.     ;;  p2 is a tangent point with center at mid point of p1 p2
  40.     (while (and (setq gr (grread 5)) (= (car gr) 5))
  41.       (cond
  42.         ((> (setq d1 (distance p1 (setq p2 (cadr gr)))) rMin)
  43.          (setq el1 (subst (cons 40 (setq r1 (/ d1 2.))) (assoc 40 el1) el1))
  44.          (setq el1 (entmod (subst (cons 10 (polar p1 (angle p1 p2) r1)) (assoc 10 el1) el1)))
  45.          (entupd (cdr (assoc -1 el1)))
  46.          (cond
  47.            ((< rMin (- d1 (* od 2.)))
  48.             (setq el2 (subst (cons 40 (/ (- d1 (* od 2.)) 2.)) (assoc 40 el2) el2))
  49.             (setq el2 (entmod (subst (assoc 10 el1) (assoc 10 el2) el2)))
  50.             (entupd (cdr (assoc -1 el2)))
  51.            )
  52.            (t ; minimize the inner circle
  53.             (setq el2 (subst (cons 40 rMin) (assoc 40 el2) el2))
  54.             (setq el2 (entmod (subst (assoc 10 el1) (assoc 10 el2) el2)))
  55.             (entupd (cdr (assoc -1 el2)))
  56.            )
  57.          )
  58.         )
  59.         (t ; minimize the outer circle
  60.          (setq el1 (subst (cons 40 rMin) (assoc 40 el1) el1))
  61.          (setq el1 (entmod (subst (cons 10 (polar p1 (angle p1 p2) (/ rMin 2.))) (assoc 10 el1) el1)))
  62.          (entupd (cdr (assoc -1 el1)))
  63.         )
  64.       )
  65.     )
  66.     ;(entdel c1) ; to remove the circle
  67.     ;(entdel c2) ; to remove the circle
  68.     p2
  69.   )
  70.   (setq pc (getpoint "\nPick center point."))
  71.   (princ "\n Select new radius  ")
  72.   (setq rad (ghostcircle pc 850.0))
  73.   (princ rad)
  74.   (princ)
  75. )
ghostCircle函数:
游客,如果您要查看本帖隐藏内容请回复
评分
参与人数 1D豆 +5 收起 理由
yufeng37 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2017-5-6 00:02:34 | 显示全部楼层
沙发,谢谢分享!
发表于 2017-5-6 00:17:46 来自手机 | 显示全部楼层
谢谢楼主分享
发表于 2017-5-6 06:47:50 | 显示全部楼层
可以学习动态拖动
发表于 2017-5-6 06:52:40 | 显示全部楼层
代码不全吧?
发表于 2017-5-6 07:50:24 | 显示全部楼层
向大师学习程序!
发表于 2017-5-6 08:24:46 | 显示全部楼层
谢谢分享!
发表于 2017-5-6 09:38:26 | 显示全部楼层
好程序,感谢楼主分享!
一看动态就想到grread函数,一想到grread函数就晕
发表于 2017-5-6 09:53:06 | 显示全部楼层
动态好视觉化好
发表于 2017-5-6 10:17:48 | 显示全部楼层
学习一下
发表于 2017-5-6 10:29:55 | 显示全部楼层
                 赞一个
发表于 2017-5-6 12:03:13 | 显示全部楼层
谢谢分享!
谢谢分享!
发表于 2017-5-24 13:58:25 | 显示全部楼层
向楼主学习
发表于 2017-6-6 14:33:34 | 显示全部楼层
向楼主学习,能做个动态云线的效果吗?类似与cad2018的云线效果。
发表于 2017-6-6 15:08:34 | 显示全部楼层
回复学习学习
GMT+8, 2026-11-22 08:59 , Processed in 0.300069 second(s), 38 queries , Gzip On, File On.
