查看: 1081|回复: 1
[求助] 想求个代码,打印出当前图形打开期间运行过的所有命令和执行的次数
发表于 2017-5-6 11:15:32 | 显示全部楼层 |阅读模式
在学反应器,想求个代码,打印出当前图形打开期间运行过的所有命令和执行的次数
已领礼包: 20个
发表于 2017-5-6 13:43:25 | 显示全部楼层
  1. (defun CmdSpy()
  2.   (vl-load-com)
  3.   (if(not cmdspy:cmdreactor)
  4.     (setq cmdspy:cmdreactor
  5.            (vlr-Command-Reactor nil
  6.              '((:vlr-CommandEnded . CmdSpyReaction))
  7.              )
  8.           )
  9.     )
  10.   (princ)
  11.   )
  12. (CmdSpy)
  13. (defun CmdSpyReaction(Reac Args / cLst)
  14.   (if
  15.     (not
  16.       (setq cLst(assoc(car Args)cmdspy:list)))
  17.         (setq cmdspy:list(cons(cons(car Args) 1)cmdspy:list))
  18.         (setq cmdspy:list(subst(cons(car Args)(1+(cdr cLst)))
  19.                                              cLst cmdspy:list))
  20.     )
  21.   (princ)
  22.   )
  23. (defun c:lookcmdlist(/ cTot)
  24.   (if cmdspy:list
  25.     (progn
  26.       (setq cmdspy:list
  27.           (vl-sort cmdspy:list
  28.                    '(lambda(a b)(>(cdr a)(cdr b))))
  29.             cTot(apply '+(mapcar 'cdr cmdspy:list))
  30.             )
  31.       (princ "\n====== 命令使用列表 ======\n")
  32.       (foreach i cmdspy:list
  33.         (princ(strcat "\n "(car i)" "))
  34.         (repeat(- 26(strlen(car i)))(princ "."))
  35.         (princ " ")(princ(itoa(cdr i)))
  36.         ); end foreach
  37.       (princ(strcat "\n\n TOTAL: "(itoa cTot)))
  38.       (princ "\n\n========== 结束 报告 =========")
  39.       (textscr)
  40.       )
  41.      (princ "\nNo command history found ")
  42.     )
  43.   (princ)
  44.   ); end of c:lookcmdlist
命令: lookcmdlist
======== 命令使用列表 ========
LINE ............................. 2
MOVE ........................... 1
COPY .............................1
PROPERTIES ................ 1
TOTAL: 5
========= 结束 报告 ==========
GMT+8, 2026-11-5 22:40 , Processed in 0.415753 second(s), 31 queries , Gzip On.
