查看: 1572|回复: 2
[每日一码] 按图层统计图块的数量别列表
发表于 2017-5-13 19:18:45 | 显示全部楼层 |阅读模式
  1. (defun c:dimcount ( / enx idx lay lst sel val )
  2.     ;; Define function and declare local variables
  3.     ;; If the user makes a valid selection of dimensions
  4.     (if (setq sel (ssget '((0 . "*DIMENSION"))))
  5.         (progn
  6.             ;; Then do the following:
  7.             ;; Iterate over the selection set
  8.             ;; [ Method 2a: http://lee-mac.com/selsetprocessing.html ]
  9.             (repeat (setq idx (sslength sel))
  10.                 ;; Obtain the DXF data for an item in the set
  11.                 (setq enx (entget (ssname sel (setq idx (1- idx))))
  12.                 ;; Obtain the dimension layer
  13.                       lay (cdr (assoc  8 enx))
  14.                 ;; Obtain the dimension measurement
  15.                       val (cdr (assoc 42 enx))
  16.                 ;; Update the association list with these entries
  17.                       lst (LM:nassoc++ (list lay val) lst)
  18.                 ) ;; end setq
  19.             ) ;; end repeat
  20.             (print lst)
  21.         ) ;; end progn
  22.     ) ;; end if
  23.     ;; Suppress the value returned by the last evaluated expression
  24.     (princ)
  25. ) ;; end defun
  26. ;; Nested Assoc++  -  Lee Mac
  27. ;; Increments the value of a key in an association list with possible nested structure,
  28. ;; or adds the set of keys to the list if not present.
  29. ;; key - [lst] List of keys & subkeys
  30. ;; lst - [lst] Association list (may be nil)
  31. (defun LM:nassoc++ ( key lst / itm )
  32.     (if key
  33.         (if (setq itm (assoc (car key) lst))
  34.             (subst (cons (car key) (LM:nassoc++ (cdr key) (cdr itm))) itm lst)
  35.             (cons  (cons (car key) (LM:nassoc++ (cdr key) nil)) lst)
  36.         )
  37.         (if lst (list (1+ (car lst))) '(1))
  38.     )
  39. )
发表于 2017-5-14 09:05:48 | 显示全部楼层
谢谢老大,坐个沙发
发表于 2017-6-12 13:34:55 | 显示全部楼层
楼主,有2个问题啊:
1.代码不全,无法实现图片中的功能
2.统计的是是标注不是图块
GMT+8, 2026-11-22 08:34 , Processed in 0.201158 second(s), 16 queries , Gzip On, File On.
