查看: 4531|回复: 7
[多段线] 统计图中封闭和未封闭多段线并标色
发表于 2016-12-11 16:19:27 | 显示全部楼层 |阅读模式
  • 插件名称 : 封闭检测
  • 作  者 : newer
  • 运行环境 :XDRX API 晓东工具箱
  • 发布时间 :2016-12-11
  • 命令名称 :XDTB_PLINECHK
  • 插件介绍 :统计图中封闭和未封闭多段线并标色
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
[sell]
(defun c:xdtb_plinechk (/ #area #closeAreal #minareal #ncloseAreal ents fz i
                          key lst1 lst2 n ss x
  (defun _prompt ()
    (xdrx_prompt "\n当前设置: 绘制宽度(" #tongji_close_pline_wid
                 " ) 面积阈值(" #tongji_close_pline_minarea ")"
  (defun _keyword (key)
    (cond
      ((= key "BE")
        (if (setq fz (getreal (xdrx_prompt "\n绘制宽度<"
                                           #tongji_close_pline_wid ">:" t
          (setq #tongji_close_pline_wid fz)
      ((= key "FZ")
        (if (setq fz (getreal (xdrx_prompt "\n最小面积阈值<"
                                           #tongji_close_pline_minarea ">:"
                                           t
          (setq #tongji_close_pline_minarea fz)
    (_prompt)
  (defun _caiji1 (ents)
    (setq i 0)
    (xdrx_statusbar_begin "采集中" (length ents))
    (mapcar
      '(lambda (x)
         (xdrx_statusbar_setpos (setq i (1+ i)))
         (xdrx_getpropertyvalue x "area")
         (cond
           ((< #area #tongji_close_pline_minarea)
             (setq #minareal (cons (list #area x) #minareal))
             (xdrx_setpropertyvalue x "color" 6 "constantwidth"
           ((xdrx_getpropertyvalue x "isclosed")
             (setq #closeAreal (cons (list #area x) #closeareal))
             (xdrx_setpropertyvalue x "color" 1 "constantwidth"
           (t
             (setq #ncloseAreal (cons (list #area x) #ncloseareal))
             (xdrx_setpropertyvalue x "color" 2 "constantwidth"
      ents
    (xdrx_statusbar_end)
    (list #closeAreal #ncloseAreal #minareal)
  (xdrx_begin)
  (if (not #tongji_close_pline_wid)
    (setq #tongji_close_pline_wid 1.0)
  (if (not #tongji_close_pline_minarea)
    (setq #tongji_close_pline_minarea 10.0)
  (_prompt)
  (xdrx_initssget "\n选取要统计的多段线[绘制宽度(BE)/面积阈值(FZ)]<退出>:"
                  "BE FZ" "" "_keyword"
  (if (setq ss (xdrx_ssget '((0 . "*POLYLINE"))))
    (progn
      (setq ents (xdrx_pickset->ents ss)
            lst1 (_caiji1 ents)
            lst2 (mapcar
                   'length
                   lst1
      (xdrx_prompt "\n采集到多段线共" (length ents) ".其中:")
      (if (setq n (car lst2))
        (xdrx_prompt "\n 封闭多段线" n ". 红色")
      (if (setq n (cadr lst2))
        (xdrx_prompt "\n 未封闭多段线" n ". 黄色")
      (if (setq n (caddr lst2))
        (xdrx_prompt "\n 面积低于阈值多段线" n ". 品红色")
  )  (xdrx_end)
  (princ)
[/sell]
发表于 2016-12-11 16:56:10 | 显示全部楼层
发表于 2016-12-11 21:54:23 来自手机 | 显示全部楼层
什么都要购买
发表于 2016-12-11 22:33:41 | 显示全部楼层
确实是难得好帖啊,顶先
发表于 2016-12-11 23:15:23 | 显示全部楼层
确实是难得好帖啊,顶先
发表于 2016-12-12 00:19:37 | 显示全部楼层
谢谢提供,下载玩玩了!!!!辛苦了
发表于 2016-12-12 09:08:43 | 显示全部楼层
想请教楼主一下,为什么这个代码我拷贝了放进记事本保存成了Unicode,然后CAD读入的时候会出现“; 错误: 读入的 (八进制) 字符不正确: 0”
发表于 2017-3-2 00:02:28 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
GMT+8, 2026-11-22 08:09 , Processed in 0.627177 second(s), 26 queries , Gzip On, File On.
