查看: 2434|回复: 6
[曲线] (XD::Curve:Vertices)获得曲线的顶点列表
发表于 2017-5-15 22:28:05 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::Curve:Vertices
调用格式: (XD::Curve:Vertices ent)
参数说明: ent --- 曲线实体(POINT,LINE,ARC,CIRCLE,ELLIPSE,*POLYLINE,SPLINE)
返回值: 表
函数简介: 获得曲线的顶点列表
函数来源: 原创
函数作者: Lispboy
适用版本: 不限
最后更新时间: 2017-05-15
备注: 支持:POINT,LINE,ARC,CIRCLE,ELLIPSE,*POLYLINE,SPLINE
演示图片: -
  1. (defun XD::Curve:Vertices ( ent / der di1 di2 di3 elst fun inc lst par rad )
  2.     (setq elst (entget ent))
  3.     (cond
  4.         (   (eq "POINT" (cdr (assoc 0 elst)))
  5.             (list (cdr (assoc 10 elst)))
  6.         )
  7.         (   (eq "LINE" (cdr (assoc 0 elst)))
  8.             (list (cdr (assoc 10 elst)) (cdr (assoc 11 elst)))
  9.         )
  10.         (   (member (cdr (assoc 0 elst)) '("CIRCLE" "ARC"))
  11.             (setq di1 0.0
  12.                   di2 (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent))
  13.                   inc (/ di2 (1+ (fix (* 35.0 (/ di2 (cdr (assoc 40 elst)) (+ pi pi))))))
  14.                   fun (if (vlax-curve-isclosed ent) < <=)
  15.             )
  16.             (while (fun di1 di2)
  17.                 (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
  18.                       di1 (+ di1 inc)
  19.                 )
  20.             )
  21.             (reverse lst)
  22.         )
  23.         (   (or (eq (cdr (assoc 0 elst)) "LWPOLYLINE")
  24.                 (and (eq (cdr (assoc 0 elst)) "POLYLINE") (zerop (logand (cdr (assoc 70 elst)) 80)))
  25.             )
  26.             (setq par 0)
  27.             (repeat (fix (1+ (vlax-curve-getendparam ent)))
  28.                 (if (setq der (vlax-curve-getsecondderiv ent par))
  29.                     (if (equal der '(0.0 0.0 0.0) 1e-8)
  30.                         (setq lst (cons (vlax-curve-getpointatparam ent par) lst))
  31.                         (if (setq rad (distance '(0.0 0.0) (vlax-curve-getfirstderiv ent par))
  32.                                   di1 (vlax-curve-getdistatparam ent par)
  33.                                   di2 (vlax-curve-getdistatparam ent (1+ par))
  34.                             )
  35.                             (progn
  36.                                 (setq inc (/ (- di2 di1) (1+ (fix (* 35.0 (/ (- di2 di1) rad (+ pi pi)))))))
  37.                                 (while (< di1 di2)
  38.                                     (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
  39.                                           di1 (+ di1 inc)
  40.                                     )
  41.                                 )
  42.                             )
  43.                         )
  44.                     )
  45.                 )
  46.                 (setq par (1+ par))
  47.             )
  48.             (if (or (vlax-curve-isclosed ent) (equal '(0.0 0.0 0.0) der 1e-8))
  49.                 (reverse lst)
  50.                 (reverse (cons (vlax-curve-getendpoint ent) lst))
  51.             )
  52.         )
  53.         (   (eq (cdr (assoc 0 elst)) "ELLIPSE")
  54.             (setq di1 (vlax-curve-getdistatparam ent (vlax-curve-getstartparam ent))
  55.                   di2 (vlax-curve-getdistatparam ent (vlax-curve-getendparam   ent))
  56.                   di3 (* di2 (/ (+ pi pi) (abs (- (vlax-curve-getendparam ent) (vlax-curve-getstartparam ent)))))
  57.             )
  58.             (while (< di1 di2)
  59.                 (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
  60.                       der (distance '(0.0 0.0) (vlax-curve-getsecondderiv ent (vlax-curve-getparamatdist ent di1)))
  61.                       di1 (+ di1 (/ di3 (1+ (fix (/ 35.0 (/ di3 der (+ pi pi)))))))
  62.                 )
  63.             )
  64.             (if (vlax-curve-isclosed ent)
  65.                 lst
  66.                 (setq lst (cons (vlax-curve-getendpoint ent) lst))
  67.             )
  68.             (reverse lst)
  69.         )
  70.         (   (eq (cdr (assoc 0 elst)) "SPLINE")
  71.             (setq di1 (vlax-curve-getdistatparam ent (vlax-curve-getstartparam ent))
  72.                   di2 (vlax-curve-getdistatparam ent (vlax-curve-getendparam   ent))
  73.                   inc (/ di2 25.0)
  74.             )
  75.             (while (< di1 di2)
  76.                 (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
  77.                       der (/ (distance '(0.0 0.0) (vlax-curve-getsecondderiv ent (vlax-curve-getparamatdist ent di1))) inc)
  78.                       di1 (+ di1 (if (equal 0.0 der 1e-10) inc (min inc (/ 1.0 der (* 10. inc)))))
  79.                 )
  80.             )
  81.             (if (vlax-curve-isclosed ent)
  82.                 lst
  83.                 (setq lst (cons (vlax-curve-getendpoint ent) lst))
  84.             )
  85.             (reverse lst)
  86.         )
  87.     )
  88. )
发表于 2017-5-16 08:25:51 | 显示全部楼层
感谢大师的分享
能不能来个应用实例啊
发表于 2017-5-16 08:44:25 | 显示全部楼层
  1. (defun c:tt ()
  2.   (princ "\n选取曲线<退出>:")
  3.   (if (setq e (ssget ":E:S" '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE"))))
  4.     (progn
  5.       (princ "\n顶点列表:")
  6.       (princ (xd::curve:vertices (ssname e 0)))
  7.     )
  8.   )
  9.   (princ)
  10. )
发表于 2017-5-16 08:46:40 | 显示全部楼层
感谢感谢
两位大师
请教大师,以下的写法是什么意思啊?
":E:S"
"_+.:E:S"
谢谢
发表于 2017-5-17 20:37:38 | 显示全部楼层
这个不错,收藏了。
发表于 2018-6-10 00:59:34 来自手机 | 显示全部楼层
inc (/ di2 (1+ (fix (* 35.0 (/ di2 (cdr (assoc 40 elst)) (+ pi pi))))))inc是什么,为什么这么算
GMT+8, 2026-11-22 07:42 , Processed in 0.451171 second(s), 23 queries , Gzip On, File On.
