查看: 1392|回复: 0
[每日一码] 删除所有的Raster Images
已领礼包: 20个
发表于 2017-5-29 19:27:13 | 显示全部楼层 |阅读模式
  1. (defun RemoveAllRaster ( doc / _catchapply dict lockd )
  2.     (defun _catchapply ( method params / result )
  3.         (if
  4.             (not
  5.                 (vl-catch-all-error-p
  6.                     (setq result (vl-catch-all-apply method params))
  7.                 )
  8.             )
  9.             result
  10.         )
  11.     )
  12.     (vlax-for layer (vla-get-layers doc)
  13.         (if (eq :vlax-true (vla-get-lock layer))
  14.             (vla-put-lock (car (setq lockd (cons layer lockd))) :vlax-false)
  15.         )
  16.     )
  17.     (vlax-for block (vla-get-blocks doc)
  18.         (vlax-for object block
  19.             (if (member (vla-get-objectname object) '("AcDbOle2Frame" "AcDbRasterImage"))
  20.                 (_catchapply 'vla-delete (list object))
  21.             )
  22.         )
  23.     )
  24.     (if (setq dict (_catchapply 'vla-item (list (vla-get-dictionaries doc) "ACAD_IMAGE_DICT")))
  25.         (progn
  26.             (vlax-for object dict
  27.                 (_catchapply 'vla-delete (list object))
  28.             )
  29.             (_catchapply 'vla-delete (list dict))
  30.         )
  31.     )
  32.     (if (setq dict (_catchapply 'vla-item (list (vla-get-dictionaries doc) "ACAD_IMAGE_VARS")))
  33.         (_catchapply 'vla-delete (list dict))
  34.     )
  35.     (foreach layer lockd (vla-put-lock layer :vlax-true))
  36.     (vla-regen doc acallviewports)
  37.     (princ)
  38. )
  1. (defun c:tt()
  2.     (RemoveAllRaster (vla-get-activedocument (vlax-get-acad-object)))
  3.     (princ)
  4. )
GMT+8, 2026-11-6 02:39 , Processed in 0.584155 second(s), 29 queries , Gzip On.
