查看: 1235|回复: 3
[每日一码] 屏幕打印并标注多段线每段的长度
已领礼包: 20个
发表于 2017-6-6 01:13:31 | 显示全部楼层 |阅读模式
  1. (defun c:plseglen (/ *adoc ss itmn coords pt ptl seg segd pta ptb ptab
  2.                    txt txta)
  3.   (vl-load-com)
  4.   (setq *adoc (vla-get-activedocument (vlax-get-acad-object)))
  5.   (if (ssget '((0 . "LWPOLYLINE")))
  6.     (progn
  7.       (setq itmn 0)
  8.       (vlax-for itm (setq ss (vla-get-activeselectionset *adoc))
  9.         (setq itmn (1+ itmn))
  10.         (princ (strcat "\n\nPolyline number "
  11.                        (itoa itmn)
  12.                        " length :\t"
  13.                        (rtos (vlax-curve-getdistatparam
  14.                                itm
  15.                                (vlax-curve-getendparam itm)
  16.                              )
  17.                              2
  18.                              2
  19.                        )
  20.                )
  21.         )
  22.         (setq coords (vlax-safearray->list
  23.                        (vlax-variant-value (vla-get-coordinates itm))
  24.                      )
  25.         )
  26.         (repeat (/ (length coords) 2)
  27.           (setq pt (list (car coords) (cadr coords)))
  28.           (setq coords (cddr coords))
  29.           (setq ptl (cons pt ptl))
  30.         )
  31.         (setq ptl (reverse ptl))
  32.         (setq seg 0)
  33.         (repeat (- (length ptl) 1)
  34.           (setq seg (1+ seg))
  35.           (princ
  36.             (strcat "\nSegment number " (itoa seg) " from point ")
  37.           )
  38.           (princ (setq pta (nth (- seg 1) ptl)))
  39.           (princ " to point ")
  40.           (princ (setq ptb (nth seg ptl)))
  41.           (princ " length : ")
  42.           (princ (setq segd
  43.                         (rtos (- (vlax-curve-getdistatpoint itm (nth seg ptl))
  44.                                  (vlax-curve-getdistatpoint
  45.                                    itm
  46.                                    (nth (- seg 1) ptl)
  47.                                  )
  48.                               )
  49.                               2
  50.                               2
  51.                         )
  52.                  )
  53.           )
  54.           (setq ptab (vlax-curve-getpointatparam
  55.                        itm
  56.                        (+ (vlax-curve-getparamatpoint itm pta)
  57.                           (/ (- (vlax-curve-getparamatpoint itm ptb)
  58.                                 (vlax-curve-getparamatpoint itm pta)
  59.                              )
  60.                              2
  61.                           )
  62.                        )
  63.                      )
  64.           )
  65.           (setq
  66.             txt (entmakex (list (cons 0 "TEXT")
  67.                                 (cons 100 "AcDbEntity")
  68.                                 (cons 100 "AcDbText")
  69.                                 (cons 10 ptab)
  70.                                 (cons 40 (/ (getvar 'viewsize) 100))
  71.                                 (cons 1 segd)
  72.                                 (cons 50 (angle pta ptb))
  73.                                 (cons 41 1.0)
  74.                                 (cons 51 0.0)
  75.                                 (cons 71 0)
  76.                                 (cons 72 0)
  77.                                 (list 210 0.0 0.0 1.0)
  78.                                 (cons 100 "AcDbText")
  79.                                 (cons 73 0)
  80.                           )
  81.                 )
  82.           )
  83.           (setq txta (vlax-ename->vla-object txt))
  84.           (vla-put-alignment txta acAlignmentMiddleCenter)
  85.           (entmod
  86.             (subst (cons 11 ptab) (assoc 11 (entget txt)) (entget txt))
  87.           )
  88.         )
  89.         (if (= (vla-get-closed itm) :vlax-true)
  90.           (progn
  91.             (setq seg (1+ seg))
  92.             (princ
  93.               (strcat "\nSegment number " (itoa seg) " from point ")
  94.             )
  95.             (princ (setq pta (last ptl)))
  96.             (princ " to point ")
  97.             (princ (setq ptb (vlax-curve-getendpoint itm)))
  98.             (princ " length : ")
  99.             (princ (setq segd
  100.                           (rtos (- (vlax-curve-getdistatparam
  101.                                      itm
  102.                                      (vlax-curve-getendparam itm)
  103.                                    )
  104.                                    (vlax-curve-getdistatpoint itm (last ptl))
  105.                                 )
  106.                                 2
  107.                                 2
  108.                           )
  109.                    )
  110.             )
  111.             (setq ptab (vlax-curve-getpointatparam
  112.                          itm
  113.                          (+ (vlax-curve-getparamatpoint itm pta)
  114.                             (/ (- (vlax-curve-getendparam itm)
  115.                                   (vlax-curve-getparamatpoint itm pta)
  116.                                )
  117.                                2
  118.                             )
  119.                          )
  120.                        )
  121.             )
  122.             (setq
  123.               txt (entmakex (list (cons 0 "TEXT")
  124.                                   (cons 100 "AcDbEntity")
  125.                                   (cons 100 "AcDbText")
  126.                                   (cons 10 ptab)
  127.                                   (cons 40 (/ (getvar 'viewsize) 100))
  128.                                   (cons 1 segd)
  129.                                   (cons 50 (angle pta ptb))
  130.                                   (cons 41 1.0)
  131.                                   (cons 51 0.0)
  132.                                   (cons 71 0)
  133.                                   (cons 72 0)
  134.                                   (list 210 0.0 0.0 1.0)
  135.                                   (cons 100 "AcDbText")
  136.                                   (cons 73 0)
  137.                             )
  138.                   )
  139.             )
  140.             (setq txta (vlax-ename->vla-object txt))
  141.             (vla-put-alignment txta acAlignmentMiddleCenter)
  142.             (entmod (subst (cons 11 ptab)
  143.                            (assoc 11 (entget txt))
  144.                            (entget txt)
  145.                     )
  146.             )
  147.           )
  148.         )
  149.         (setq ptl nil)
  150.       )
  151.       (vla-delete ss)
  152.     )
  153.   )
  154.   (textpage)
  155.   (princ)
  156. )
已领礼包: 782个
发表于 2017-6-6 06:08:48 | 显示全部楼层
这个厉害了。
已领礼包: 2759个
财富等级: 家财万贯
发表于 2017-6-6 08:36:35 | 显示全部楼层
标注距离不压线最好,谢谢楼主提供程序!!!!!
已领礼包: 217个
发表于 2017-6-6 09:39:18 | 显示全部楼层
好用的,感谢楼主分享
GMT+8, 2026-11-5 21:09 , Processed in 0.422057 second(s), 38 queries , Gzip On.
