查看: 1207|回复: 1
[求助] 如何取得多段线顶点表
已领礼包: 12个
发表于 2019-8-18 11:47:03 | 显示全部楼层 |阅读模式
如何取得多段线顶点表
已领礼包: 12个
 楼主| 发表于 2019-9-7 11:42:31 | 显示全部楼层
问题简单了,都不回复啊,自己写了一个源码如下:
(defun ljx-getplpoint (e / obj pname lst)
  (vl-load-com)
  (setq obj (vlax-ename->vla-object e)
        pname (cdr (assoc 0 (entget e)))
  (cond
    ((= pname "SPLINE")
     (setq lst (ch-lst e (vlax-safearray->list (vlax-variant-value (vla-get-ControlPoints obj)))))
    ((or (= pname "LWPOLYLINE") (= pname "POLYLINE"))
     (setq lst (ch-lst e  (vlax-safearray->list (vlax-variant-value (vla-get-Coordinates obj)))))
    (T
     (setq lst (list (vlax-safearray->list (vlax-variant-value (vla-get-StartPoint obj)))
                     (vlax-safearray->list (vlax-variant-value (vla-get-EndPoint obj))))
  );;;;cond
  lst
);;;;defun
  (defun ch-lst (ei lsti / ind nn lstn lsti1)
    (setq ind 0
          nn (if (= (cdr (assoc 0 (entget ei))) "LWPOLYLINE") 2 3)
          lstn '()
    (repeat (/ (length lsti) nn)
        (setq lsti1 (list (nth ind lsti) (nth (1+ ind) lsti) (cdr (assoc 38 (entget ei)))))
        (setq lsti1 (list (nth ind lsti) (nth (1+ ind) lsti) (nth (+ 2 ind) lsti)))
      (setq lstn (cons lsti1 lstn)
            ind (+ ind nn)
    (setq lstn (reverse lstn))
;;;;使用示例:(setq lsta (ljx-getplpoint (car (entsel "\n请选择曲线"))))
GMT+8, 2026-11-4 17:51 , Processed in 0.484526 second(s), 30 queries , Gzip On.
