查看: 1499|回复: 0
[每日一码] 获取REGION,3DSOLID的centroid的代码
已领礼包: 20个
发表于 2017-7-18 19:23:18 | 显示全部楼层 |阅读模式
  1. (defun c:centroid ( / v^v unit ucs x y ss ent enta n p )
  2.   (vl-load-com)
  3.   (defun v^v ( u v )
  4.     (mapcar '(lambda ( s1 s2 a b ) (+ ((eval s1) (* (nth a u) (nth b v))) ((eval s2) (* (nth a v) (nth b u))))) '(+ - +) '(- + -) '(1 0 0) '(2 2 1))
  5.   )
  6.   (defun unit ( v )
  7.     (mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v)
  8.   )
  9.   (if (/= (getvar 'worlducs) 1)
  10.     (command "_.ucs" "_w")
  11.   )
  12.   (setq ss (ssget "_+.:E:S" '((0 . "3DSOLID,REGION"))))
  13.   (setq ent (ssname ss 0))
  14.   (setq enta (vlax-ename->vla-object ent))
  15.   (if
  16.     (eq (cdr (assoc 0 (entget ent))) "REGION")
  17.     (progn
  18.       (setq n (vlax-safearray->list (vlax-variant-value (vla-get-normal enta))))
  19.       (if (equal (v^v n '(0.0 0.0 1.0)) '(0.0 0.0 0.0) 1e-6)
  20.         (setq x '(1.0 0.0 0.0) y '(0.0 1.0 0.0))
  21.         (setq x (unit (v^v n '(0.0 0.0 1.0))) y (unit (v^v n x)))
  22.       )
  23.       (command "_.explode" ent)
  24.       (while
  25.         (> (getvar 'cmdactive) 0)
  26.         (command "")
  27.       )
  28.       (setq p (vlax-curve-getstartpoint (entlast)))
  29.       (command "_.undo")
  30.       (while
  31.         (> (getvar 'cmdactive) 0)
  32.         (command "")
  33.       )
  34.       (setq ucs (vla-add (vla-get-usercoordinatesystems (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point p) (vlax-3d-point (mapcar '+ p x)) (vlax-3d-point (mapcar '+ p y)) "{ UCS }"))
  35.       (vla-put-activeucs (vla-get-activedocument (vlax-get-acad-object)) ucs)
  36.       (command "_.UCS" "_D" "{ UCS }")
  37.       (vlax-release-object ucs)
  38.       (setq cent (trans (vlax-safearray->list (vlax-variant-value (vla-get-centroid enta))) 1 0))
  39.       (command "_.ucs" "_p")
  40.     )
  41.     (setq cent (vlax-safearray->list (vlax-variant-value (vla-get-centroid enta))))
  42.   )
  43.   (prompt "\nCentroid : ") (princ cent)
  44.   (prompt "\nVariable is called \"cent\" - you call it with !cent")
  45.   (princ)
  46. )
GMT+8, 2026-11-5 13:54 , Processed in 0.378341 second(s), 29 queries , Gzip On.
