查看: 1554|回复: 4
[LISP程序]:多义线子段直线《》圆弧转换工具
发表于 2003-7-15 17:32:27 | 显示全部楼层 |阅读模式
多义线子段直线《》圆弧转换工具
(defun c:test ()
  (vl-load-com)
  (setq ent (entsel "\nSelect Polyline:"))
  (setq p (cadr ent)
      obj (vlax-ename->vla-object (car ent))
       pp (vlax-curve-getclosestpointto obj (trans p 1 0))
        n (fix (vlax-curve-getparamatpoint obj pp)))
  (initget "Value Radius")
  (setq k (getkword "\nEnter an option[Value/Radius]:"))
  (cond
    ((= k "Value")
     (setq bu (getreal "\nNew Bulge Value:")))
    ((= k "Radius")
     (setq pl (vlax-safearray->list
               (vlax-variant-value
                 (vlax-get-property obj 'coordinates)))
          p1 (list (nth (* n 2) pl)(nth (1+ (* n 2)) pl))
          p2 (list (nth (* (1+ n) 2) pl)(nth (1+ (* (1+ n) 2)) pl))
         dis (distance p1 p2)
           r (getdist "\nInptu Radius:"))
     (if (< (abs r)(/ dis 2))
       (progn (alert "Radius is too small!")(exit))
     (setq bu (tan (/ (asin (/ dis 2.0 r)) 2.0))))
  (vlax-invoke-method obj 'SetBulge n bu)
(defun asin (r / result)
  (if (and (/= 1 (abs r))(/= 1.0 (abs r)))
    (setq result (atan (/ r (sqrt (- 1 (* r r))))))
    (cond
      ((< r 0) (setq result (/ pi -2.0)))
      ((> r 0) (setq result (/ pi 2.0)))
    );c
  );i
  result
);defun
(defun tan (x)(/ (sin x)(cos x)))
评分
参与人数 1D豆 +1 收起 理由
ScmTools + 1 很给力!经验;
查看全部评分
发表于 2005-2-17 23:20:30 | 显示全部楼层
反过来就见多,这个是第一次见,谢谢了
发表于 2005-11-13 23:54:44 | 显示全部楼层
用不了。有问题。
发表于 2005-11-18 17:02:59 | 显示全部楼层
顶
发表于 2009-11-20 15:39:31 | 显示全部楼层
实用程序
感谢楼主分享!
GMT+8, 2026-11-22 10:30 , Processed in 0.618906 second(s), 18 queries , Gzip On, File On.
