查看: 1552|回复: 0
[每日一码] LWPolyline 的Coordinate转换到 WCS
已领礼包: 1268个
发表于 2017-8-4 10:55:40 | 显示全部楼层 |阅读模式
OCS 的坐标原点和 WCS 原点 重合,LWpolyline 的节点坐标为 OCS,转换时要加上 38 组码(elevation)
  1. (defun c:tt (/ ss e obj el i z nor ptocs ptwcs)
  2.   (setvar "dimzin" 0)
  3.   (if (setq ss (ssget "+.:S" '((0 . "lwpolyline"))))
  4.     (progn
  5.       (setq e        (ssname ss 0)
  6.             el        (entget e)
  7.             obj        (vlax-ename->vla-object e)
  8.             z        (cdr (assoc 38 el))
  9.             nor        (cdr (assoc 210 el))
  10.       )
  11.       (princ "\n节点数 = ")
  12.       (princ (cdr (assoc 90 el)))
  13.       (while (and (setq i (getint "\n索引: "))
  14.                   (< i (cdr (assoc 90 el)))
  15.              )
  16.         (setq ptocs (safearray-value (variant-value (vla-get-coordinate obj i)))
  17.               ptwcs (trans (append ptocs (list z)) nor 0)
  18.         )
  19.         (princ (strcat "\nOCS = "
  20.                        (rtos (car ptocs) 2 3)
  21.                        ","
  22.                        (rtos (cadr ptocs) 2 3)
  23.                )
  24.         )
  25.         (princ (strcat "\nWCS = "
  26.                        (rtos (car ptwcs) 2 3)
  27.                        ","
  28.                        (rtos (cadr ptwcs) 2 3)
  29.                        ","
  30.                        (rtos (last ptwcs) 2 3)
  31.                )
  32.         )
  33.       )
  34.     )
  35.   )
  36.   (princ)
  37. )
转换结果可以使用 vlax-curve-getpointatparam 验证,同样 AddVertex 时也要将 WCS 转换到 OCS
这个 OCS 是什么一个 UCS 呢?
可以使用 UCS 命令的  ZA 选项建立,原点为 (0 0 0)  ZAxis 为 组码 210 的值
GMT+8, 2026-11-5 14:44 , Processed in 0.360371 second(s), 28 queries , Gzip On.
