查看: 20510|回复: 82
[分享]:用程序自动生成带属性的图框(标题栏)一例
发表于 2003-7-16 04:49:19 | 显示全部楼层 |阅读模式
  1. [font=courier]
  2. (defun c:test ()
  3.   (load "lsplib")
  4.   (vl-cmdf "ucs" "w" "")
  5.   (setq index (load_dialog (findfile "dial.dcl")))
  6.   (if (not (new_dialog "dtbl" index))(exit))
  7.   (imagep)
  8.   (action_tile "accept" "(setq pa (get_tile "pa"))
  9.                          (setq to (get_tile "to"))
  10.                          (setq e (get_tile "e"))
  11.                          (setq p (get_tile "p"))
  12.                          (setq l (get_tile "l"))
  13.                          (done_dialog)")
  14.   (action_tile "cancel" "(exit)")
  15.   (start_dialog)
  16.   (unload_dialog index)
  17.   (setvar "osmode" 0)
  18.   (if (= (getvar "tilemode") 1)(setvar "tilemode" 0))
  19.   (mlayer "title_block" "cyan" "continous")
  20.   (setq rp1 '(0.0 0.1))
  21.   (if (= p "1")(setq rp2 '(7.08 10.9))(setq rp2 '(10.95 7.3)))
  22.   (setq        rtop (list (/ (car rp2) 2)(+ (cadr rp2) 0.03125)))
  23.   (vl-cmdf "rectangle" rp1 rp2)
  24.   (vl-cmdf "rectangle" (polar rtop pi 0.6) "@1.2,0.1")
  25.   (vl-cmdf "text" "s" "romand" "j" "mc" (polar rtop (/ pi 2) 0.05) 0.07 0 "IF IN DOUBT -ASK!" "")
  26.   (vl-cmdf "chprop" (entlast) "" "c" 6 "")
  27.   (vl-cmdf "rectangle" rp2 "@-2.83,-0.315")  ;;top num box
  28.   (vl-cmdf "line" "@2.611,0" "@0,0.315" "")
  29.   (vl-cmdf "text" "romand" "j" "tl" "@0.02,-0.02" 0.06 0 "REV")
  30.   (vl-cmdf "-style" "romand" "" "" 1.2 "" "" "" "")
  31.   (vl-cmdf "text" "j" "tl" "@-2.611,0" 0.06 0  "NUMBER")
  32.   (vl-cmdf "ucs" "n" rp1 "")
  33.   (vl-cmdf "line" '(0 0.315) "@2.55,0" "" "line" "@1.7,0" "@2.83,0" "line" "@-0.219,0" "@0,-0.315" "")
  34.   (vl-cmdf "line" '(2.55 0) "@0,0.748" "line" "@-2.55,0" "@4.25,0" "")
  35.   (vl-cmdf "line" '(4.25 0) "@0,1.693" "@2.83,0" "")
  36.   (vl-cmdf "line" '(0 0.748) "@4.25,0" "")
  37.   (vl-cmdf "line" '(0.85 0.748) "@0,0.63" "")
  38.   (vl-cmdf "array" (entlast) "" "r" 1 4 0.85 "")
  39.   (vl-cmdf "line" '(0 0.9055) "@3.4,0" "")
  40.   (vl-cmdf "rectangle" '(0 1.063) '(7.08 1.378))
  41.   (vl-cmdf "line" '(6.062 1.063) "@0,0.63" "" "line" "@-1.182,0" "@0,-0.63" "" "line" "@0.482,0" "@0,0.315" "")
  42.   (vl-cmdf "line" '(4.25 1.5355) "@2.83,0" "" "line" "@-0.308,0.1575" "@0,-0.315" "")
  43.   (vl-cmdf "line" '(4.565 1.378) "@0,0.315" "")
  44.   (vl-cmdf "-style" "romand" "" "" 1 "" "" "" "")
  45.   (vl-cmdf "text" "j" "mc" '(1.275 0.26) 0.052 0 "This drawing is the Property of PARKER HANNIFIN Crop.")
  46.   (vl-cmdf "text" "j" "mc" '(1.275 0.17) 0.052 0 "Any use or reproduction except by expressed")
  47.   (vl-cmdf "text" "j" "mc" '(1.275 0.08) 0.052 0 "permission of PARKER HANNIFIN Crop. is Hereby Prohibited.")
  48.   (parkerlogo '(0 0.428))
  49.   (vl-cmdf "text" "s" "romand" "j" "mc" '(0.425 0.37) 0.06 0 "Fluid Connectors" "")
  50.   (vl-cmdf "change" (entlast) "" "p" "c" 6 "")
  51.   (vl-cmdf "-style" "romand" "" "" 1.1 "" "" "" "")
  52.   (vl-cmdf "text" "s" "romand" "j" "mc" '(1.73 0.67) 0.055 0 "Parker Hannifin (N.Z) Ltd.")
  53.   (vl-cmdf "text" "j" "mc" '(1.73 0.58) 0.055 0 "PO Box 14-906 Panmure")
  54.   (vl-cmdf "text" "j" "mc" '(1.73 0.49) 0.055 0 "3 Bowden Road Mt. Wellington")
  55.   (vl-cmdf "text" "j" "mc" '(1.73 0.4) 0.055 0 "Auckland, New Zealand")
  56.   (vl-cmdf "text" "j" "tl" '(6.881 0.295) 0.06 0 "REV")
  57.   (vl-cmdf "-style" "romand" "" "" 1 "" "" "" "")
  58.   (vl-cmdf "text" "j" "tl" '(2.58 0.55) 0.06 0  "MUST CONFORM")
  59.   (vl-cmdf "text" "j" "tl" '(2.58 0.45) 0.06 0  "TO HS-99,ES-99")
  60.   (vl-cmdf "text" "j" "tl" '(2.58 0.35) 0.06 0  "ANGLE %%P1/2%%D")
  61.   (vl-cmdf "text" "j" "tl" '(2.58 0.17) 0.06 0  "DIMENSIONS IN")
  62.   (vl-cmdf "text" "j" "mc" '(5.121 1.2205) 0.18 0  "A4")
  63.   (vl-cmdf "change" (entlast) "" "p" "c" 6 "")
  64.   (setvar "cecolor" "bylayer")
  65.   (vl-cmdf "-style" "romand" "" "" 1.2 "" "" "" "")
  66.   (vl-cmdf "text" "j" "tl" '(2.57 0.728) 0.06 0 "TOLERANCE" "")
  67.   (vl-cmdf "text" "j" "mc" '(0.4252 0.8267) 0.06 0 "MATERIAL" "")
  68.   (vl-cmdf "text" "j" "mc" "@0.85,0" 0.06 0 "STOCK SIZE" "")
  69.   (vl-cmdf "text" "j" "mc" "@0.85,0" 0.06 0 "HEAT TREAT" "")
  70.   (vl-cmdf "text" "j" "mc" "@0.85,0" 0.06 0 "FINISH" "")
  71.   (vl-cmdf "text" "j" "tl" '(3.41 1.043) 0.06 0 "SCALE" "")
  72.   (vl-cmdf "text" "j" "tl" '(0.02 1.358) 0.06 0 "DRAWN" "")
  73.   (vl-cmdf "text" "j" "tl" "@0.85,0" 0.06 0 "DATE" "")
  74.   (vl-cmdf "text" "j" "tl" "@0.85,0" 0.06 0 "CHECKED" "")
  75.   (vl-cmdf "text" "j" "tl" "@0.85,0" 0.06 0 "DATE" "")
  76.   (vl-cmdf "text" "j" "tl" "@0.85,0" 0.06 0 "APPROVED" "")
  77.   (vl-cmdf "text" "j" "tl" "@0.85,0" 0.06 0 "DATE" "")
  78.   (project '(5.712 1.2205))
  79.   (vl-cmdf "text" "j" "mc" '(4.4095 1.4568) 0.06 0 "ECN" "")
  80.   (vl-cmdf "text" "j" "mc" "@0.315,0" 0.06 0 "REV""")
  81.   (vl-cmdf "text" "j" "mc" "@0.748,0" 0.06 0 "DESCRIPTION" "")
  82.   (vl-cmdf "text" "j" "mc" "@0.9448,0" 0.06 0 "DATE" "")
  83.   (vl-cmdf "text" "j" "mc" "@0.5085,0" 0.06 0 "BY" "")
  84.   (cond
  85.     ((= pa "1")
  86.       (vl-cmdf "text" "j" "tl" '(4.27 0.295) 0.06 0 "NUMBER")
  87.       (vl-cmdf "text" "j" "tl" "@0,0.748" 0.06 0 "TITLE" ""))
  88.     ((= to "1")
  89.       (vl-cmdf "line" '(4.565 0) "@0,0.315" "")
  90.       (vl-cmdf "text" "j" "tl" '(4.27 0.295) 0.06 0 "HAND")
  91.       (vl-cmdf "text" "j" "tl" "@0.315,0" 0.06 0 "NUMBER")
  92.       (vl-cmdf "text" "j" "tl" '(4.27 0.728) 0.06 0 "TITLE" "")
  93.       (vl-cmdf "line" '(4.25 0.748) "@2.83,0" "" "line" "@0,0.1575" "@-2.83,0" "")
  94.       (vl-cmdf "line" '(4.88 0.748) "@0,0.315" "" "line" "@1.57,0" "@0,-0.315" ""
  95.                   "line" "@0.315,0" "@0,0.315" "")
  96.       (vl-cmdf "text" "j" "mc" '(4.565 0.8268) 0.06 0 "PART NO.")
  97.       (vl-cmdf "text" "j" "mc" "@0,0.1575" 0.06 0 "ENDSTYLE")
  98.       (vl-cmdf "text" "j" "mc" '(6.6075 0.8268) 0.06 0 "REV")
  99.       (vl-cmdf "text" "j" "mc" "@0,0.1575" 0.06 0 "REV"))
  100.   );c
  101.   (vl-cmdf "-style" "romand" "" "" 1 "" "" "" "")
  102.   (vl-cmdf "ucs" "w" "")
  103.   (setvar "cecolor" "6")
  104.   (entmake '((0 . "block")(410 . "Layout1")(2 . "*U")(70 . 1)(10 0 0 0)))
  105.   (setq blkn (entmake '((0 . "ENDBLK"))))
  106.   (entmake (append '((0 . "INSERT")(10 0 0 0)(66 . 1)) (list (cons 2 blkn))))
  107.   (entmake '((0 . "ATTRIB")(1 . "K3D78-30-16C-AU")(2 . "Part Num")(7 . "Romand")
  108.              (10 0 0 0)(11 5.65 0.14 0)(40 . 0.15)(70 . 0)(72 . 1)))
  109.   (entmake '((0 . "ATTRIB")(1 . "-")(2 . "Rev")(7 . "Romand")
  110.              (10 0 0 0)(11 6.972 0.16 0)(40 . 0.08)(70 . 0)(72 . 1)))
  111.   (cond
  112.     ((= to "1")
  113.       (entmake '((0 . "ATTRIB")(1 . "INTERNAL RECESS")(2 . "Title1")(7 . "Romand")
  114.                  (10 0 0 0)(11 5.68 0.68 0)(40 . 0.13)(70 . 0)(72 . 1)))
  115.       (entmake '((0 . "ATTRIB")(1 . "FRONT BARBS")(2 . "Titledown")(7 . "Romand")
  116.                  (10 0 0 0)(11 5.59 0.45 0)(40 . 0.13)(70 . 0)(72 . 1))))
  117.    ((= to "0")
  118.      (entmake '((0 . "ATTRIB")(1 . "")(2 . "Titletop")(7 . "Romand")
  119.                  (10 0 0 0)(11 5.81 0.95 0)(40 . 0.14)(70 . 0)(72 . 1)))
  120.      (entmake '((0 . "ATTRIB")(1 . "")(2 . "Title1")(7 . "Romand")
  121.                 (10 0 0 0)(11 5.68 0.75 0)(40 . 0.14)(70 . 0)(72 . 1)))
  122.      (entmake '((0 . "ATTRIB")(1 . "")(2 . "Titledown")(7 . "Romand")
  123.                 (10 0 0 0)(11 5.59 0.5 0)(40 . 0.14)(70 . 0)(72 . 1))))
  124.   );c
  125.   (entmake '((0 . "ATTRIB")(1 . "")(2 . "Ecn") (7 . "Romand")
  126.              (10 0 0 0)(11 4.408 1.675 0)(40 . 0.06)(70 . 0)(72 . 1)))
  127.   (entmake '((0 . "ATTRIB")(1 . "-")(2 . "Erev")(7 . "Romand")
  128.              (10 0 0 0)(11 4.72 1.675 0)(40 . 0.06)(70 . 0)(72 . 1)))
  129.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "")(7 . "Romand")
  130.              (10 0 0 0)(72 . 1)(11 5.468 1.675 0)(2 . "Description")(70 . 0)))
  131.   (entmake '((0 . "ATTRIB")(1 . "10/06/03")(2 . "Date")(7 . "Romand")
  132.              (10 0 0 0)(40 . 0.06)(72 . 1)(11 6.41 1.675 0)(70 . 0)))
  133.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "")(7 . "Romand")
  134.              (10 0 0 0)(72 . 1)(11 6.92 1.675 0)(2 . "By")(70 . 0)))
  135.   (entmake '((0 . "ATTRIB")(1 . "JOHN.S")(40 . 0.08)(7 . "Romand")
  136.              (10 0 0 0)(72 . 1)(11 0.425 1.24 0)(2 . "Drawn")(70 . 0)))
  137.   (entmake '((0 . "ATTRIB")(1 . "09/06/03")(40 . 0.08)(7 . "Romand")
  138.              (10 0 0 0)(72 . 1)(11 1.275 1.24 0)(2 . "Date")(70 . 0)))
  139.   (entmake '((0 . "ATTRIB")(1 . "")        (40 . 0.08)(7 . "Romand")
  140.              (10 0 0 0)(72 . 1)(11 2.125 1.24 0)(2 . "Checked")(70 . 0)))
  141.   (entmake '((0 . "ATTRIB")(1 . "")(40 . 0.08)(7 . "Romand")
  142.              (10 0 0 0)(72 . 1)(11 2.975 1.24 0)(2 . "Date")(70 . 0)))
  143.   (entmake '((0 . "ATTRIB")(1 . "")(40 . 0.08)(7 . "Romand")
  144.              (10 0 0 0)(72 . 1)(11 3.825 1.24 0)(2 . "Approved")(70 . 0)))
  145.   (entmake '((0 . "ATTRIB")(40 . 0.08)(1 . "05/06/03")(7 . "Romand")
  146.              (10 0 0 0)(11 4.565 1.24 0.0)(2 . "Date")(70 . 0)(72 . 1)))
  147.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "316L")(7 . "Romand")
  148.              (10 0 0 0)(72 . 1)(11 0.425 1.045 0)(2 . "Material")(70 . 0)))
  149.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "36mm AF HEX")(7 . "Romand")
  150.              (10 0 0 0)(72 . 1)(11 1.275 1.045 0)(2 . "Size")(70 . 0)))
  151.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "-")(7 . "Romand")
  152.              (10 0 0 0)(72 . 1)(11 2.125 1.045 0)(2 . "Heat")(70 . 0)))
  153.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "-")(7 . "Romand")
  154.              (72 . 1)(10 0 0 0)(11 2.975 1.045 0)(2 . "Finish")(70 . 0)))
  155.   (entmake '((0 . "ATTRIB")(40 . 0.12)(1 . "NTS")(7 . "Romand")
  156.              (10 0 0 0)(72 . 1)(11 4.0 0.9 0)(2 . "Scale")(70 . 0)))
  157.   (entmake '((0 . "ATTRIB")(40 . 0.21)(1 . "INCH")(7 . "Romand")
  158.              (10 0 0 0)(72 . 1)(11 6.57 1.23 0)(2 . "Unit")(70 . 0)))
  159.   (entmake '((0 . "ATTRIB")(1 . "X.X%%P0.04")(2 . "x.x")(7 . "Romand")
  160.              (10 0 0 0)(11 3.85 0.59 0)(40 . 0.06)(70 . 0)(72 . 1)))
  161.   (entmake '((0 . "ATTRIB")(1 . "X.XX%%P0.008")(2 . "x.xx")(7 . "Romand")
  162.              (10 0 0 0)(11 3.85 0.49 0)(40 . 0.06)(70 . 0)(72 . 1)))
  163.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "X.XXX%%P0.004")(7 . "Romand")
  164.              (10 0 0 0)(11 3.85 0.39 0)(2 . "x.xxx")(70 . 0)(72 . 1)))
  165.   (entmake '((0 . "ATTRIB")(40 . 0.06)(1 . "INCH")(7 . "Romand")
  166.              (10 0 0 0)(72 . 1)(11 3.4 0.21 0)(2 . "UNIT")(70 . 0)))
  167.   (if (<= (car rp2) 7.08)
  168.     (progn
  169.       (entmake '((0 . "ATTRIB")(1 . "K3D78-30-16C-AU")(2 . "Part Num")(7 . "Romand")
  170.                  (10 0 0 0)(11 5.65 10.63 0)(40 . 0.15)(70 . 0)(72 . 1)))
  171.       (entmake '((0 . "ATTRIB")(1 . "-")(2 . "Rev")(7 . "Romand")
  172.                  (10 0 0 0)(11 6.972 10.65 0)(40 . 0.08)(70 . 0)(72 . 1)))
  173.       (entmake '((0 . "ATTRIB")(1 . "K3D78-30-16C-AU")(2 . "Part Num")(7 . "Romand")
  174.                  (10 7.15 2.0 0)(11 7.15 0.8 0)(40 . 0.15)(70 . 0)(72 . 5))))
  175.     (progn
  176.       (entmake '((0 . "ATTRIB")(1 . "K3D78-30-16C-AU")(2 . "Part Num")(7 . "Romand")
  177.                  (10 0 0 0)(11 5.65 7.03 0)(40 . 0.15)(70 . 0)(72 . 1)))
  178.       (entmake '((0 . "ATTRIB")(40 . 0.08)(1 . "-")(7 . "Romand")
  179.                  (10 0 0 0)(11 6.962 7.05 0)(2 . "Rev")(70 . 0)(72 . 1))))
  180.   );i
  181.   (if (= to "1")
  182.     (progn
  183.       (entmake '((0 . "ATTRIB")(10 0 0 0)(40 . 0.1)(1 . "T")(7 . "Romand")
  184.                  (72 . 1)(11 4.4075 0.18 0)(2 . "Hand")(70 . 0)))
  185.       (entmake '((0 . "ATTRIB")(10 0 0 0)(40 . 0.07)(1 . "K9170-6-6-AU")(7 . "Romand")
  186.                  (72 . 1)(11 5.665 1.054 0)(2 . "Part No")(70 . 0)))
  187.       (entmake '((0 . "ATTRIB")(10 0 0 0)(40 . 0.07)(1 . "-")(7 . "Romand")
  188.                  (72 . 1)(11 6.9225 1.054 0)(2 . "Rev")(70 . 0)))
  189.       (entmake '((0 . "ATTRIB")(10 0 0 0)(40 . 0.07)(1 . "D83,31-6")(7 . "Romand")
  190.                  (72 . 1)(11 5.665 0.897 0)(2 . "Endstyle")(70 . 0)))
  191.       (entmake '((0 . "ATTRIB")(10 0 0 0)(40 . 0.07)(1 . "a")(7 . "Romand")
  192.                  (72 . 1)(11 6.9225 0.897 0)(2 . "Rev")(70 . 0))))
  193.   );I
  194.   (entmake '((0 . "SEQEND")))
  195.   (if (> (car rp2) 7.08)(vl-cmdf "move" (entlast) "" '(0 0) '(3.87 0) ""))
  196.   (vl-cmdf "-style" "romand" "" "" 1.0 "" "" "" "")
  197.   (setvar "cecolor" "bylayer")
  198.   (setvar "osmode" 37)
  199.   (princ)
  200. );defun
  201. [/font]
发表于 2003-7-16 08:41:34 | 显示全部楼层
太麻烦了,还是做一图块方便。
发表于 2003-7-16 10:28:14 | 显示全部楼层
是啊。做一个图块更方便,而且可以不分解,绘图时不会和其它实体混在一起
已领礼包: 593个
发表于 2003-7-16 13:33:13 | 显示全部楼层
最初由 正航 发布
[B]是啊。做一个图块更方便,而且可以不分解,绘图时不会和其它实体混在一起 [/B]
用程序生成图块更方便,只要有程序就可以生成图块。
发表于 2003-7-16 14:26:50 | 显示全部楼层
发表于 2003-7-16 16:20:47 | 显示全部楼层
楼主很辛苦,可惜我等实在看不懂,也不知道怎么用
 楼主| 发表于 2003-7-16 16:38:40 | 显示全部楼层
不好意思。请将以下程序码行删掉,既可运行(如果在模型空间运行会自动转向图纸空间)。
删掉:
;(load "lsplib")
;(imagep)
;(mlayer "title_block" "cyan" "continous")
;(project '(5.712 1.2205))
另复制一对话框文件:dial.dal
dtbl : dialog {label = "Title Block";
  : row {
    : radio_column {label = "Type:";
      : radio_button {label = "Part"; key = "pa"; value = "1";}
      : radio_button {label = "Tool"; key = "to";}
      : radio_button {label = "EDM"; key = "e";}
    } spacer;
    : radio_column {label = "Orientation:";
      : radio_button {label = "Po&rtrait"; key = "p"; value = "1";}
      : radio_button {label = "La&ndscape"; key = "l";}
      spacer; spacer; spacer;
  spacer;
  ok_cancel;
  : row {
    : image { key = "im" ; width = 4; fixed_width= true;}
    : paragraph {
      : text_part { label = "Designed and Created";alignment=right;}
      : text_part { label = "by Richard Liang";alignment=right;}
发表于 2003-7-16 17:34:58 | 显示全部楼层
按提示进行改动,并将“另复制一对话框文件:dial.dal”中的DAL改为DCL文件,移到SUPPORT文件夹中,运行后出现下图:按确定后有点动静。但“未知命令”提示重复出现。
能否详细说说?
 楼主| 发表于 2003-7-16 17:49:21 | 显示全部楼层
dial.dal 应该是dial.dcl。
我刚在家又试了,可以呀,你再试试?有什么问题请告。
已领礼包: 593个
发表于 2003-7-17 02:03:55 | 显示全部楼层
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 488个
发表于 2003-7-17 08:26:22 | 显示全部楼层
图框每个地方的都不一样,要程序写出来,不可能.
自己的图框,画一遍存好就可以了.当然也要属性.
所以需要的不是画,而是改.
我写的我们院的
发表于 2003-7-17 11:17:52 | 显示全部楼层
有关图框及初始化的程序没有一个能通用的,所以还是自已写好些。
发表于 2003-7-20 14:30:47 | 显示全部楼层
学到了一种思路
发表于 2003-7-25 12:43:58 | 显示全部楼层
图框及初始化的程序不难写,还是自己写吧
发表于 2003-8-25 10:05:13 | 显示全部楼层
同意15楼,还是自己写!
GMT+8, 2026-11-2 17:15 , Processed in 0.633035 second(s), 60 queries , Gzip On.
