查看: 925|回复: 2
[求助] 求圆弧的中点,怎么求?
已领礼包: 160个
发表于 2017-9-13 10:42:08 | 显示全部楼层 |阅读模式
(setq ent (entget (car (entsel))))
            (setq pc (cdr (assoc 10 ent)) ;圆心
                     r  (cdr (assoc 40 ent)) ;半径
                     a0 (cdr (assoc 50 ent));起点方向
                     a1 (cdr (assoc 51 ent));终点方向
                     ps (polar pc a0 r);起点
                     pe (polar pc a1 r);止点
                     pd (mapcar '* '(0.5 0.5) (mapcar '+ ps pe))      ;如图键槽,当pd和pc圆心重合时,就求不出中点了。
                     pm (polar pc (angle pc pd) r));中点
发表于 2017-9-13 12:03:51 | 显示全部楼层
下面代码,在弧线的圆心和中点连线。
  1. (defun c:tt ()
  2.   (if (setq e (car (entsel "\n选取弧线:")))
  3.     (progn (setq o          (vlax-ename->vla-object e)
  4.                  cen          (vla-get-center o)
  5.                  cen          (vlax-safearray->list (vlax-variant-value cen))
  6.                  sParam          (vlax-curve-getstartparam e)
  7.                  eParam          (vlax-curve-getendparam e)
  8.                  midParam (/ (+ sParam eParam) 2.0)
  9.                  mid          (vlax-curve-getpointatparam e midParam)
  10.            )
  11.            (entmake (list '(0 . "LINE") (cons 10 cen) (cons 11 mid)))
  12.     )
  13.   )
  14.   (princ)
  15. )
已领礼包: 6468个
发表于 2017-9-14 00:02:05 | 显示全部楼层
论坛有函数。
GMT+8, 2026-11-5 10:18 , Processed in 0.366434 second(s), 35 queries , Gzip On.
