楼主: q3_2006
[求助] 发现dbx方式处理文字bug一枚
已领礼包: 2476个
 楼主| 发表于 2017-12-1 21:24:29 | 显示全部楼层
修复了一下..能打开 了...修复提示有两个错误
1.rar
15.35 KB, 下载次数: 0, 下载积分: D豆 -1 , 活跃度 1
已领礼包: 20个
发表于 2017-12-1 21:49:02 | 显示全部楼层
方法是可行的,试试用 VLA 改下纯LISP代码,应该不会有错误的。
已领礼包: 6468个
发表于 2017-12-2 00:03:28 | 显示全部楼层
都用上18了啊
已领礼包: 20个
发表于 2017-12-2 00:48:32 | 显示全部楼层
改成VLA,你试试下面的
  1. ;从对齐点反算插入点
  2. (defun XD::TEXT:AlignPnt2InsertPnt (obj / alignment alipnt box rot)
  3.   (setq alignment (vlax-get obj 'alignment))
  4.   (setq alipnt (vlax-get obj 'textalignmentpoint)
  5.         rot (vlax-get obj 'rotation)
  6.         box (textbox (entget (vlax-vla-object->ename obj)))
  7.   )
  8.   (cond
  9.     ((or
  10.        (= alignment acAlignmentTopRight)
  11.        (= alignment acAlignmentMiddleRight)
  12.        (= alignment acAlignmentBottomRight)
  13.        (= alignment acAlignmentRight)
  14.      )
  15.       (mapcar
  16.         '-
  17.         alipnt
  18.         (list (* (cos rot) (caadr box)) (* (sin rot) (caadr box)) 0.0)
  19.       )
  20.     )
  21.     ((or
  22.        (= alignment acAlignmentCenter)
  23.        (= alignment acAlignmentTopCenter)
  24.        (= alignment acAlignmentMiddleCenter)
  25.        (= alignment acAlignmentBottomCenter)
  26.      )
  27.       (mapcar
  28.         '-
  29.         alipnt
  30.         (list (* (cos rot) (/ (caadr box) 2.0)) (* (sin rot) (/
  31.        (caadr box)
  32.        2.0
  33.                                                              )
  34.                                                 ) 0.0
  35.         )
  36.       )
  37.     )
  38.     (t
  39.       (vlax-get obj 'InsertionPoint)
  40.     )
  41.   )
  42. )
  43. (defun c:tt (/)
  44.   (setq ffn "d:\\1.dwg"
  45.         dbx (vla-GetInterfaceObject (vlax-get-acad-object) (if (<
  46.        (setq acVer
  47.        (atoi
  48.        (getvar "ACADVER")
  49.        )
  50.        )
  51.        16
  52.        )
  53.                                                              "ObjectDBX.AxDbDocument"
  54.                                                              (strcat "ObjectDBX.AxDbDocument."
  55.        (itoa acVer)
  56.                                                              )
  57.                                                            )
  58.             )
  59.   )
  60.   (Vlax-Invoke-Method dbx 'Open ffn)
  61.   (vlax-for ob (Vlax-Get dbx 'ModelSpace) (cond
  62.                                             ((= "AcDbText"
  63.                                                 (Vlax-Get ob 'ObjectName)
  64.                                              )
  65.                                               (cond
  66.                                                 ((= "aaa" (Vlax-Get ob 'TextString))
  67.                                                   (Vlax-Put ob 'TextString
  68.                                                             "bbbbbbbbbb"
  69.                                                   )
  70.                                                   (setq int1
  71.                                                         (XD::TEXT:AlignPnt2InsertPnt ob)
  72.                                                   )
  73.                                                   (vlax-put ob
  74.                                                             'InsertionPoint
  75.                                                             int1
  76.                                                   )
  77.                                                 )
  78.                                               )
  79.                                             )
  80.                                           )
  81.   )                                       ; (vla-auditinfo dbx :vlax-true)
  82.   (Vlax-Invoke-Method dbx 'SaveAs ffn)
  83.   (vlax-release-object dbx)
  84.   (princ)
  85. )
已领礼包: 2476个
 楼主| 发表于 2017-12-2 05:53:23 | 显示全部楼层
谢谢大师...昨晚休息了..今天继续测试
已领礼包: 2476个
 楼主| 发表于 2017-12-2 05:58:20 | 显示全部楼层
太棒了..行得通..
已领礼包: 2476个
 楼主| 发表于 2017-12-2 06:49:34 | 显示全部楼层
这是全部15种对齐方式..处理后对比如截图我已经搞晕了..
1.rar
19.42 KB, 下载次数: 2, 下载积分: D豆 -1 , 活跃度 1
GMT+8, 2026-11-5 10:20 , Processed in 0.476291 second(s), 43 queries , Gzip On.
