查看: 974|回复: 4
[求助] 如图的OPTIONS对话框设置里面怎么用LISP实现
发表于 2017-12-9 14:33:43 | 显示全部楼层 |阅读模式
如果,怎么通过LISP设置这个值? 谢谢
已领礼包: 20个
发表于 2017-12-9 15:52:46 | 显示全部楼层
  1. (vla-get-layoutcreateviewport
  2.     (vla-get-display
  3.         (vla-get-preferences
  4.             (vlax-get-acad-object)
  5.         )
  6.     )
  7. )
  8. (vla-put-layoutcreateviewport
  9.     (vla-get-display
  10.         (vla-get-preferences
  11.             (vlax-get-acad-object)
  12.         )
  13.     )
  14.     :vlax-false
  15. )
发表于 2017-12-9 18:06:55 | 显示全部楼层
也可以通过环境变量设置
(setenv "CreateViewports" "0")
下面是ACAD环境变量的说明
Remember that environment variables are dependent on .. well, the environment, so each may or may not apply to a certain setup.
Some are almost described, some are definitely not. The first are OS dependent, the rest are AutoCAD dependent.
System related
(getenv "Path") ;string System search paths
(getenv "COMSPEC") ;string Cmd.exe path
(getenv "UserName");string User logon name
(getenv "Temp") ;string Temp path
(getenv "TMP") ;string Temp path
(getenv "ComputerName");string Computer name
(getenv "Windir") ;string Windows path
(getenv "OS") ;string Operating system
(getenv "UserProfile");string Current user profile path
(getenv "Pathext") ;string Exec extensions
(getenv "SystemDrive");string System drive
(getenv "SystemRoot");string System root path
(getenv "MaxArray");integer
General
(getenv "ACAD") ;string Support search paths
(getenv "ANSIHatch");string Pattern file for ANSI setup 1)
(getenv "ANSILinetype");string Linetype file for ANSI setup 1)
(getenv "ISOHatch");string Pattern file for ISO setup 1)
(getenv "ISOLinetype");string Linetype file for ISO setup 1)
(getenv "StartUpType");string Current default for StartUp dialog
(getenv "acet-MenuLoad");string Loading of Express Tools menu
(getenv "Measureinit");string MEASUREINIT
(getenv "InsertUnitsDefSource");integer INSUNITSDEFSOURCE
(getenv "InsertUnitsDefTarget");integer INSUNITSDEFTARGET
(getenv "acet-Enable");string
(getenv "LastTemplate");string Last DWT used
(getenv "AcetRText:type");string Current default for RTEXT "Diesel"
(getenv "Pickstyle");integer
(getenv "Coords") ;integer
(getenv "ShowProxyDialog");integer
(getenv "Osmode") ;integer
(getenv "EdgeMode");integer
(getenv "PAPERUPDATE");integer
(getenv "ACADPLCMD");string Plotter command string
(getenv "ImageHighlight");integer
(getenv "Attdia") ;integer
(getenv "Attreq") ;integer
(getenv "Delobj") ;integer
(getenv "Dragmode");integer
(getenv "UseMRUConfig");integer
(getenv "PLSPOOLALERT");integer
(getenv "PLOTLEGACY");integer
(getenv "PSTYLEPOLICY");integer
(getenv "OLEQUALITY");integer
(getenv "Anyport") ;integer
(getenv "Validation Policy");integer
(getenv "Validation Strategy");integer
(getenv "CommandDialogs");integer CMDDIA
(getenv "TempDirectory");string Temp dir
(getenv "PlotSpoolerDirectory");string Spooler dir
(getenv "DefaultLoginName");string Default login
(getenv "MenuFile");string Default menu path
(getenv "NetLocation");string Default URL
(getenv "ACADDRV") ;string Driver path
(getenv "ACADHELP");string Help path
(getenv "PrinterConfigDir");string Plotter path
(getenv "PrinterStyleSheetDir");string Plot styles path
(getenv "PrinterDescDir");string Plotter driver path
(getenv "NewStyleSheet");string Default .stb/.ctb file
(getenv "DefaultFormatForSave");integer Default saveas
(getenv "DefaultConfig");string Default pc3
(getenv "LastModifiedConfig");string Last pc3
(getenv "MRUConfig");string pc3?
(getenv "ACADLOGFILE");string Logfile
(getenv "MaxDwg") ;integer
(getenv "AVEMAPS") ;string Texture files path
(getenv "TemplatePath");string Templates path
(getenv "DatabaseWorkSpacePath");string Data Links path
(getenv "DefaultPlotStyle");string e.g. "ByLayer"
(getenv "DefaultLayerZeroPlotStyle");string e.g."Normal"
(getenv "LineWeightUnits");integer
(getenv "LWDEFAULT");integer Default lineweight
(getenv "CustomColors");integer
(getenv "Blipmode");integer
(getenv "ToolTips");string
1) used by MEASUREINIT and MEASUREMENT sysvars
Editor Configuration
(getenv "SDF_AttributeExtractTemplateFile");string ??
(getenv "AutoSnapPolarAng");string POLARANG
(getenv "AutoSnapPolarDistance");string POLARDIST
(getenv "AutoSnapPolarAddAng");string POLARADDANG
(getenv "AutoSnapControl");integer AUTOSNAP
(getenv "AutoSnapTrackPath");integer TRACKPATH
(getenv "PickBox") ;integer PICKBOX
(getenv "AutoSnapSize");integer
(getenv "PickFirst");integer PICKFIRST
(getenv "PickAuto");integer PICKAUTO
(getenv "MenuOptionFlags");integer MENUCTL
(getenv "FontMappingFile");string
(getenv "LogFilePath");string
(getenv "PSOUT_PrologFileName");string
(getenv "MainDictionary");string
(getenv "CustomDictionary");string
(getenv "MTextEditor");string
(getenv "XrefLoadPath");string
(getenv "SaveFilePath");string
(getenv "AcadLspAsDoc");string
Drawing Window
(getenv "Background");integer Background color
(getenv "Layout background");integer PS Background color
(getenv "XhairPickboxEtc");integer Crosshair color
(getenv "LayoutXhairPickboxEtc");integer PS Crosshair color
(getenv "Autotracking vector");integer Autotracking vector color
(getenv "MonoVectors");integer
(getenv "FontFace");string Screen Menu
(getenv "FontHeight");integer
(getenv "FontWeight");integer
(getenv "FontItalic");integer
(getenv "FontPitchAndFamily");integer
(getenv "CursorSize");integer
(getenv "HideWarningDialogs");integer:00000008 <- hit
(getenv "SDIMode") ;integer:00000000 <- hit
Command Line Windows
(getenv "CmdLine.ForeColor");integer
(getenv "CmdLine.BackColor");integer
(getenv "TextWindow.ForeColor");integert
(getenv "TextWindow.BackColor");integer
(getenv "CmdLine.FontFace");string
(getenv "CmdLine.FontHeight");integer
(getenv "CmdLine.FontWeight");integer
(getenv "CmdLine.FontItalic");integer
(getenv "CmdLine.FontPitchAndFamily");integer
(getenv "TextWindow.FontFace");string
(getenv "TextWindow.FontHeight");integer
(getenv "TextWindow.FontWeight");integer
(getenv "TextWindow.FontItalic");integer
(getenv "TextWindow.FontPitchAndFamily");integer
 楼主| 发表于 2017-12-9 23:56:09 | 显示全部楼层
谢谢 marting, 谢谢N版
已领礼包: 6468个
发表于 2017-12-10 00:08:46 | 显示全部楼层
太详细了。
GMT+8, 2026-11-5 12:34 , Processed in 0.415776 second(s), 40 queries , Gzip On.
