查看: 1588|回复: 1
[求助] 遍历autocad模型空间有意思的问题
发表于 2018-3-27 19:53:15 | 显示全部楼层 |阅读模式
向高人求教了!
叙述一下问题:
我是用vb.net+AutoCAD .NET API对autocad2012进行二次开发的。
实现的功能是
1.建立符号库,先自定义一个控件,控件内包含一个树形控件,树形控件各节点对应符号库中的自定义符号(dwg文件)
2.遍历模型空间内的所有块引用实体并记录块的名称。
我是这样做的:
1.符号库部分:
首先设计一个自定义控件,自定义控件上放一个树形控件,编程增加各节点,每个节点对应符号库中一个dwg符号文件,通过拖动,增加到模型空间。
Public Function AddToPaletteSet(ByRef ps As PaletteSet, ByVal sName As String, ByRef UserCtrl As UserControl) As Palette
         Dim pale As Palette = Nothing
        If ps Is Nothing Then
             Return Nothing
         End If
        pale = ps.Add(sName, UserCtrl)
         ps.Visible = True
        Return pale
End Function
Public Sub AddToolPalleteToDatabase(ByVal sPalleteName As String, ByVal sToolName As String)
         Dim ps As PaletteSet = CreateToolPalette(sPalleteName)
         Dim UserCtrl As MyUsrCtrl = New MyUsrCtrl
         AddToPaletteSet(ps, sToolName, UserCtrl)
End Sub
调用函数AddToolPalleteToDatabase在autocad里增加。
    Public Function GetBlockNames() As String()
         Dim list As ArrayList = New ArrayList
         Dim db As Database = Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase
         Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
        Dim docLock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
         Dim ta As Transaction = tm.StartTransaction()
         Try
             Dim bt As BlockTable = ta.GetObject(db.BlockTableId, OpenMode.ForRead)
             Dim btr As BlockTableRecord = ta.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            For Each id As ObjectId In btr
                 Dim obj As DBObject = ta.GetObject(id, OpenMode.ForRead)
                 If TypeOf obj Is BlockReference Then
                     Dim br As BlockReference = CType(obj, BlockReference)
                     list.Add(br.Name)
                 End If
             Next
             ta.Commit()
             Dim arr As String()
            If list.Count = 0 Then
                 Return Nothing
             End If
             ReDim arr(list.Count - 1)
             For i As Integer = 0 To list.Count - 1 Step 1
                 arr(i) = CType(list(i), String)
             Next
             Return arr
         Catch
             ta.Abort()
             Return Nothing
         Finally
             docLock.Dispose()
             ta.Dispose()
         End Try
     End Function
通过函数GetBlockNames遍历模型空间内的所有块引用并记录块名称。
3.出现的问题
当我通过命令将符号库自定义控件加载到autocad并显示后,在模型空间内插入若干个符号块后,调用函数GetBlockNames遍历模型空间内的块引用时,找不到块引用,即GetBlockNames不能返回块名称。但是如果我随意创建一个autocad文件,插入若干块,此时根本没有增加符号库条,用GetBlockNames遍历模型空间就能返回块引用的名称,这种现象我一直没有找到出现问题的原因,及解决办法,故请autocad二次开发高手指教,谢谢了!!!!!!
已领礼包: 20个
发表于 2018-3-27 20:00:47 | 显示全部楼层
你意思是通过你的控件,已经插入到模型空间了,而且也正常显示了?
你用MOVE命令移动下你插入的所有块,正常不?
如果MOVE正常,你再用你的函数读下块引用,看能读出不?
另外,把你用符号库插入的块保存的DWG,传到论坛来看看。
GMT+8, 2026-11-3 02:47 , Processed in 0.455545 second(s), 29 queries , Gzip On.
