查看: 1571|回复: 1
[每日一码] 不打开图形,列表一个磁盘上DWG的所有LAYOUT名
已领礼包: 20个
发表于 2018-4-3 23:48:46 | 显示全部楼层 |阅读模式
  1. (defun layout-list-of-file (file / odbx list_lay lays)
  2.   (vl-load-com)
  3.   (setq
  4.     odbx     (if (< (setq vers (substr (getvar "acadver") 1 2)) "16")
  5.                (vla-GetInterfaceObject
  6.                  (vlax-get-acad-object)
  7.                  "ObjectDBX.AxDbDocument"
  8.                )
  9.                (vla-GetInterfaceObject
  10.                  (vlax-get-acad-object)
  11.                  (strcat "ObjectDBX.AxDbDocument." vers)
  12.                )
  13.              )
  14.     list_lay (list)
  15.   )
  16.   (vla-open odbx file)
  17.   (setq lays (vlax-get odbx 'layouts))
  18.   (vlax-for lay        lays
  19.     (setq list_lay (cons (vla-get-name lay) list_lay))
  20.   )
  21.   (vlax-release-object lays)
  22.   (vlax-release-object odbx)
  23.   list_lay
  24. )
命令: (layout-list-of-file "C:\\abc.dwg" )
("Model" "Layout2" "Layout1")
已领礼包: 6468个
发表于 2018-4-4 00:01:11 | 显示全部楼层
沙发。支持楼主。
GMT+8, 2026-11-5 13:04 , Processed in 0.379645 second(s), 30 queries , Gzip On.
