查看: 1461|回复: 8
[求助] 如何用Lisp实现往幻灯片库里增加幻灯片
已领礼包: 2476个
发表于 2018-4-6 19:37:39 | 显示全部楼层 |阅读模式
这个有现成程序..但想知道LISP如何实现呢..增加或删除一些幻灯片到已有幻灯片库里..
已领礼包: 604个
发表于 2018-4-6 22:07:35 | 显示全部楼层
看到一个高手是这样处理的,先将库文字转成二进制,然后。。。。
已领礼包: 6056个
发表于 2018-4-7 02:09:37 | 显示全部楼层
厉害,二进制打包。
已领礼包: 20个
发表于 2018-4-7 04:31:05 | 显示全部楼层
1、首先要了解幻灯库的格式
2、有读写二进制文件的方法
下面是用晓东通用LISP的函数实现的读取目录的代码,加载 通用LISP函数库 2018.04.08后,这些函数都有了,纯LISP的实现。
  1. (defun c:tt ()
  2.   (if (setq fn (findfile "acad.slb"))
  3.     (progn
  4.       (setq header (xd::file:bin2str (xd::file:readbinary fn 0 25)))
  5.       (if (= header "AutoCAD Slide Library 1.0")
  6.         (progn
  7.           (setq start 32)
  8.           (princ "\n")
  9.           (while
  10.             (/= ""
  11.                 (setq name (xd::file:bin2str (xd::file:readbinary fn start 32)))
  12.             )
  13.              (prin1 name)
  14.              (princ "  ")
  15.              (setq start (+ start 32 4))
  16.           )
  17.         )
  18.       )
  19.     )
  20.   )
  21.   (princ)
  22. )
命令: tt
"ZIGZAG"  "WEDGEPIC"  "WEDGE"  "VPORT-4R"  "VPORT-4L"  "VPORT-4"  "VPORT-3V"
"VPORT-3R"  "VPORT-3L"  "VPORT-3H"  "VPORT-3B"  "VPORT-3A"  "VPORT-2V"
"VPORT-2H"  "VPORT-1"  "VP-UR"  "VP-UL"  "VP-U"  "VP-RIGHT"  "VP-PLAN"  "VP-LR"
"VP-LO"  "VP-LL"  "VP-LEFT"  "U-WORLD"  "U-TOP"  "U-RIGHT"  "U-PREV"  "U-LEFT"
"U-FRONT"  "U-CVIEW"  "U-BOTTOM"  "U-BACK"  "TRIANG"  "TRANS"  "TORUS"
"TORPIC"  "SWAMP"  "STEEL"  "STARS"  "SQUARE"  "SPHERPIC"  "SPHERE"  "SOLID"
"SACNCR"  "PYRAMID"  "PT100"  "PT99"  "PT98"  "PT97"  "PT96"  "PT68"  "PT67"
"PT66"  "PT65"  "PT64"  "PT36"  "PT35"  "PT34"  "PT33"  "PT32"  "PT4"  "PT3"
"PT2"  "PT1"  "PT0"  "PM-QUAD"  "PM-CUBIC"  "PM-BEZR"  "PLASTI"  "PLAST"
"PL-QUAD"  "PL-CUBIC"  "NET3"  "NET"  "MUDST"  "MESH"  "MEDIT_WA"  "MEDIT_OT"
"MEDIT_OC"  "MEDIT_MT"  "MEDIT_MC"  "MEDIT_DV"  "MEDIT_CT"  "MEDIT_CS"
"MEDIT_CJ"  "MEDIT_CC"  "MEDIT_CA"  "MEDIT_AV"  "LINE"  "INSUL"  "HOUND"
"HONEY"  "HEX"  "H-OUTER"  "H-NORMAL"  "H-IGNORE"  "GRATE"  "GRASS"  "GDTU"
"GDTT"  "GDTS"  "GDTR"  "GDTP"  "GDTN"  "GDTM"  "GDTL"  "GDTK"  "GDTJ"  "GDTI"
"GDTH"  "GDTG"  "GDTF"  "GDTE"  "GDTD"  "GDTC"  "GDTB"  "GDTA"  "FLEX"
"ESCHER"  "EARTH"  "DOTS"  "DOME"  "DOLMIT"  "DISH"  "DDVP3D"  "DASH"  "CYLPIC"
"CROSS"  "CORK"  "CONEPIC"  "CONE"  "CLAY"  "CHROMA"  "BRSTONE"  "BRICK"
"BRASS"  "BOXPIC"  "BOX3D"  "BOX"  "AR-SAND"  "AR-RSHKE"  "AR-RROOF"
"AR-PARQ1"  "AR-HBONE"  "AR-CONC"  "AR-BRSTD"  "AR-BRELM"  "AR-B88"  "AR-B816C"
"AR-B816"  "ANSI38"  "ANSI37"  "ANSI36"  "ANSI35"  "ANSI34"  "ANSI33"
"ANSI32"  "ANSI31"  "ANGLE"  "AILOGO"  "15W100"  "14W100"  "13W100"  "12W100"
"11W100"  "10W100"  "09W100"  "08W100"  "07W100"  "06W100"  "05W100"  "04W100"
"03W100"  "02W100"  "%%BLANK"  "GLASS"  "WOOD"  "GROUND"
已领礼包: 2476个
 楼主| 发表于 2018-4-7 05:51:55 | 显示全部楼层
marting 发表于 2018-4-7 04:31
1、首先要了解幻灯库的格式
2、有读写二进制文件的方法
真早呀..谢谢,晓东API果然厉害...
已领礼包: 9341个
发表于 2018-4-7 09:24:52 | 显示全部楼层
感谢分享程序!!!!
已领礼包: 2476个
 楼主| 发表于 2018-4-7 10:42:54 | 显示全部楼层
yoyoho 发表于 2018-4-7 09:24
感谢分享程序!!!!
这是 程序..用起来也方便,分享给大家..就是想知道LISP怎么写..
CADSlide.rar
482.44 KB, 下载次数: 30, 下载积分: D豆 -1 , 活跃度 1
已领礼包: 20个
发表于 2018-4-7 20:22:32 | 显示全部楼层
帮你写了一堆SLIDE的处理函数,
添加幻灯片的,见: http://bbs.xdcad.net/thread-715364-1-1.html
所有的SLIDE支持的函数差不多都有了,剩下就是根据幻灯库的格式,你可以自己试试写下 改名,删除等函数,
关于幻灯库格式的,可以研究讨论哈。
已领礼包: 2476个
 楼主| 发表于 2018-4-7 20:30:45 | 显示全部楼层
marting 发表于 2018-4-7 20:22
帮你写了一堆SLIDE的处理函数,
亲一下..不能用表情..晓东有BUG..大师这么热情..能不能加下QQ哈..想给个红包呢..
GMT+8, 2026-11-5 10:56 , Processed in 0.406766 second(s), 49 queries , Gzip On.
