查看: 3101|回复: 2
[幻灯片] (XD::Slide:List)幻灯库SLB列目录
发表于 2018-4-7 19:51:44 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::Slide:List
调用格式: (XD::Slide:List slb)
参数说明: slb --- SLB文件名(支持搜索目录)
返回值: 表
函数简介: 幻灯库SLB列目录
函数来源: 原创
函数作者: marting
适用版本: 不限
最后更新时间: 2018-04-07
备注: _$ (XD::SLIDE:LIST "d:\\acad.slb")
("ZIGZAG" "WEDGEPIC" "WEDGE" "VPORT-4R" "VPORT-4L" "VPORT-4" "VPORT-3V" "VPORT-3R" "VPORT-3L" "VPORT-3H" "VPORT-3B" "VPORT-3A" "VPORT-2V" "VPORT-2H" "VPORT-1" "VP-UR" "VP-UL" "VP-U" "VP-RIGHT" "VP-PLAN" "VP-LR" "VP-LO" "VP-LL" "VP-LEFT" "U-WORLD" "U-TOP" "U-RIGHT" "U-PREV" "U-LEFT" "U-FRONT" "U-CVIEW" "U-BOTTOM" "U-BACK" "TRIANG" "TRANS" "TORUS" "TORPIC" "SWAMP" "STEEL" "STARS" "SQUARE" "SPHERPIC" "SPHERE" "SOLID" "SACNCR" "PYRAMID" "PT100" "PT99" "PT98" "PT97" "PT96" "PT68" "PT67" "PT66" "PT65" "PT64" "PT36" "PT35" "PT34" "PT33" "PT32" "PT4" "PT3" "PT2" "PT1" "PT0" "PM-QUAD" "PM-CUBIC" "PM-BEZR" "PLASTI" "PLAST" "PL-QUAD" "PL-CUBIC" "NET3" "NET" "MUDST" "MESH" "MEDIT_WA" "MEDIT_OT" "MEDIT_OC" "MEDIT_MT" "MEDIT_MC" "MEDIT_DV" "MEDIT_CT" "MEDIT_CS" "MEDIT_CJ" "MEDIT_CC" "MEDIT_CA" "MEDIT_AV" "LINE" "INSUL" "HOUND" "HONEY" "HEX" "H-OUTER" "H-NORMAL" "H-IGNORE" "GRATE" "GRASS" "GDTU" "GDTT" "GDTS" "GDTR" "GDTP" "GDTN" "GDTM" "GDTL" "GDTK" "GDTJ" "GDTI" "GDTH" "GDTG" "GDTF" "GDTE" "GDTD" "GDTC" "GDTB" "GDTA" "FLEX" "ESCHER" "EARTH" "DOTS" "DOME" "DOLMIT" "DISH" "DDVP3D" "DASH" "CYLPIC" "CROSS" "CORK" "CONEPIC" "CONE" "CLAY" "CHROMA" "BRSTONE" "BRICK" "BRASS" "BOXPIC" "BOX3D" "BOX" "AR-SAND" "AR-RSHKE" "AR-RROOF" "AR-PARQ1" "AR-HBONE" "AR-CONC" "AR-BRSTD" "AR-BRELM" "AR-B88" "AR-B816C" "AR-B816" "ANSI38" "ANSI37" "ANSI36" "ANSI35" "ANSI34" "ANSI33" "ANSI32" "ANSI31" "ANGLE" "AILOGO" "15W100" "14W100" "13W100" "12W100" "11W100" "10W100" "09W100" "08W100" "07W100" "06W100" "05W100" "04W100" "03W100" "02W100" "%%BLANK" "GLASS" "WOOD" "GROUND")
_$
演示图片: -
  1. (defun XD::Slide:List (slb / data)
  2.   (if (setq data (xd::slide:init slb))
  3.     (mapcar 'car data)
  4.   )
  5. )
_$
发表于 2018-6-27 10:04:18 | 显示全部楼层
类似这个
CADSlide幻灯库
如能应界面管理集合
就太好了
发表于 2019-12-21 14:34:47 | 显示全部楼层
把函数收集起来做图库
GMT+8, 2026-11-22 07:53 , Processed in 0.244521 second(s), 14 queries , Gzip On, File On.
