查看: 1711|回复: 6
[CAD] AUTOCAD版本转换工具(支持2018格式一下各个版本互转)
发表于 2018-4-20 11:40:34 | 显示全部楼层 |阅读模式
Acme CAD Converter是一款优秀的多功能CAD图形管理软件,Acme CAD Converter可以转换到低版本的cad中打开。软件的界面友好,操作起来简单方便,是一款非常好用的软件,打开要转换的cad,文件------另存为------想要的低版本!你也可以试下哦!
Acme CAD Converter 2017 8.x Multilingual + Portable | 17.5 Mb
Acme CAD Converter is a power bacth DWG converter, it can convert DWG DXF and DWF files into PDF, BMP, GIF, JPEG, WMF, PCX, TIFF, PNG, TGA, DXF, DWG, SVG, SVGZ, CGM, EPS, HPGL(PLT,HGL) etc., and also supports the conversion between DWG and DXF file versions (AutoCAD R2.5-R2012). Supports replacing missing font file. Supports bacth transmit command like AutoCAD,and batch recover drawing files. It can export layers information into the PDF file and it allows you export OLE entity and raster entity into PDF file, Supports 3D objects Hidden line removal. Supports user-defined Watermark.
Characteristics:
- Supports to open various DWG,DXF formats ( R2.5-R2012 ) and DWF;
- Supports to save DWG and DXF into DWF format(Beta).
- Identify literal fonts and entity color correctly;
- Supports batched conversion of multiple files;
- Supports to select the printout of color or monochrome raster file; set background color freely;
- Print out raster mask file; be used as image channel (used in Photoshop etc.);
- Replaces font files.
- Sets the size of raster file to be printed out freely;
- Supports full-screen mode ( press F );
- Supports printing;
- Supports AutoCAD pen sets file (*.ctb).
- Supports the paper setting of each layout, can adjust the size of output pages with its layout automatically.
- Supports 3D objects Hidden line removal when convert DWG/DXF to other formats.
- Supports user-defined Watermark.
- Converts DWG to PDF;
- Creates PDF bookmark automatically with layout name and file name, and you can edit them.
- Supports PDF's security Options.
- Can export OLE entity to PDF file;
- Can export layer information and raster image in the dwg/dxf file to PDF file
- Batch recover DWG/DXF files;
- Can select a window area for conversion;
- Exports the arc/circle objects to true arc/circle objects of other vector file.
- Supports true color
- Supports pen width and destination colors settings, and can export/import these settings;
- SHX font, XRef and Image search path
- Supports to separate layers to drawings(one drawing per layer).
- What you see is what you get
- Supports command line parameters;
- Free DWG viewer;
- Register once and upgrade free permanently;
- Supports Windows95,98,ME,NT,2000,XP,Vista,Window7,without AutoCAD;
What can Acme CAD Converter do for you ?
- DWG DXF File version conversion.
- Converts DWG, DXF, DWF to PDF.
- Converts DWG, DXF, DWF to EPS, CGM, HPGL(*.PLT).
- Converts DWG, DXF, DWF to WMF, BMP, GIF, JPEG, TIFF, PNG, TGA, PCX.
- Converts DWG, DXF, DWF to SVG.
- Batch converts multi DWG DXF and DWF files to a single PDF.
- Inserts DWG DXF and DWF into MS Word.(converts DWG to WMF)
- Replaces the missing fonts.
- Batch recovers DWG and DXF files.
- Package multi-DWG or DXF drawings toge
请先注册会员后在进行下载
已注册会员,请先登录后下载
文件名称:Acme CAD Converter 2018 v8。9。8。1472
下载次数:34  文件大小:0 Bytes  售价:1D豆 [记录]
已领礼包: 57个
发表于 2018-4-20 14:23:43 | 显示全部楼层
谢谢分享,
已领礼包: 812个
发表于 2018-4-21 07:54:04 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2018-4-21 10:51:53 | 显示全部楼层
确实是难得好帖啊,顶先
发表于 2018-7-6 22:17:35 | 显示全部楼层
确实是难得好帖,必须顶
发表于 2019-4-24 12:13:46 | 显示全部楼层
购买后,不能下载,估计是我电脑的问题,郁闷呀!
发表于 2019-4-24 13:44:20 | 显示全部楼层
感謝樓主無私地分享
GMT+8, 2026-11-6 00:15 , Processed in 0.479409 second(s), 45 queries , Gzip On.
