查看: 1236|回复: 2
[每日一码] 使用VLISP BIND-AS-INSERT XREF
已领礼包: 145个
发表于 2018-6-19 19:00:25 | 显示全部楼层 |阅读模式
  1. (defun c:BindInsert ( / appAcad docActive colBlocks objBlk)
  2.    (vl-load-com) ;load ActiveX
  3.    (setq appAcad (vlax-get-acad-object)
  4.          docActive (vla-get-ActiveDocument appAcad)
  5.    ) ;setq
  6.    ;;get the blocks collection
  7.    (setq colBlocks (vla-get-blocks docActive))
  8.    (vlax-for objBlk colBlocks
  9.       ;;Is the block an xref?
  10.       (if (= (vlax-get-property objBlk 'IsXref) :vlax-true)
  11.          ;;if True, then bind it as an insert
  12.          (vlax-invoke-method objBlk "bind" :vlax-true)
  13.       ) ;if
  14.       (vlax-release-object objBlk)
  15.    ) ;vlax-for
  16.    ;;release objects from memory
  17.    (vlax-release-object colBlocks)
  18.    (vlax-release-object docActive)
  19. )
评分
参与人数 1D豆 +5 收起 理由
sh_h + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 780个
发表于 2018-6-20 09:17:25 | 显示全部楼层
谢谢老大分享!!!
已领礼包: 8个
发表于 2018-6-20 12:13:11 | 显示全部楼层
非常好,辛苦了
GMT+8, 2026-11-5 04:24 , Processed in 0.510315 second(s), 34 queries , Gzip On.
