查看: 2508|回复: 5
[研讨] 打印机文件pc3数据查看工具
发表于 2018-6-26 00:13:48 | 显示全部楼层 |阅读模式
DWG To PDF.pc3用文本文件打开是乱码的,通过这个工具打开是这样的。大家可以用这个研究研究。本人功力不够,不知道是否能够通过lisp读写.PC3文件。csdn转过来的https://download.csdn.net/download/xhs1115/4549108
以下是读取DWG To PDF.pc3的内容
PIAFILEVERSION_2.0,pc3raw
meta{
user_defined_model_pathname="
user_defined_model_basename="
driver_pathname="U:\develop\RunRoot\Debug\acad\Program Files\AutoCAD Gator Beta 1\drv\pdfplot10.hdi
driver_version="1.1-10.0.36.0 [v018-1]
driver_tag_line="PDF ePlot - by Autodesk
toolkit_version=1
driver_type=3
canonical_family_name="Autodesk ePlot
show_custom_first=FALSE
truetype_as_text=TRUE
canonical_model_name="pdf
localized_family_name="Autodesk ePlot (PDF)
localized_model_name="DWG To PDF
file_only=TRUE
model_abilities="000550055000
udm_description="
short_net_name="
friendly_net_name="
dm_driver_version=0
default_system_cfg=FALSE
platform="2,5,1
locale="4B00409
config_description="
config_autospool=FALSE
media{
selection_method=2
type="
dm_orientation=1
actual_printable_bounds_llx=5.7937498093 (    P,PL%T 8_0)
actual_printable_bounds_lly=17.793750763 (    0#/+,4"%9@)
actual_printable_bounds_urx=273.60623169 (    (+,9<4"T7@)
actual_printable_bounds_ury=198.10624695 (    8&;#:$ <30)
number_of_copies=1
size{
  name="ANSI_A_(11.00_x_8.50_Inches)
  group=0
  landscape_mode=TRUE
  longplot_reduction=1.0
  media_description{
   printable_area=48289.937117 ("J#=_#V4YT \:0)
   dimensional=TRUE
   media_bounds{
    urx=279.39999390 (    8&9V<4!J5P)
    ury=215.89999390 (    P,S\:D"QW0)
io{
type=2
pathname="
allsysvalid=FALSE
plot_to_file=TRUE
res_color_mem{
name="RGB
num_colors=16777216
color_depth=24
num_undithered_colors=16777216
color_system=1
dm_color=1
lines_overwrite=TRUE
resolution{
  name="Default
  phys_resolution_x=1.0
  phys_resolution_y=1.0
  addr_resolution_x=1.0
  addr_resolution_y=1.0
  effective_resolution_x=1.0
  effective_resolution_y=1.0
custom{
0{
  name="View_New_File
  value=TRUE
1{
  name="Custom_Raster_Resolution
  value=FALSE
2{
  name="Custom_DWF_Resolution
  value=FALSE
3{
  name="Custom_Monochrome_Resolution
  value=FALSE
4{
  name="Custom_Gradient_Resolution
  value=FALSE
5{
  name="Gradient_Limit
  value=400
6{
  name="Monochrome_Raster_Limit
  value=400
7{
  name="Raster_Limit
  value=400
8{
  name="All_As_Geometry
  value=FALSE
9{
  name="Capture
  value=1
10{
  name="Font_Capture
  value=TRUE
11{
  name="Hardcopy_Resolution
  value=600
12{
  name="Include_Layer
  value=TRUE
13{
  name="Resolution
  value=14
PC3文件查看工具.rar
568.09 KB, 下载次数: 53, 下载积分: D豆 -1 , 活跃度 1
售价: 3 D豆  [记录]
pc3数据查看工具
已领礼包: 3904个
发表于 2018-6-26 09:40:52 | 显示全部楼层
做一个热心并受欢迎的人!
已领礼包: 6056个
发表于 2018-6-28 15:24:52 | 显示全部楼层
谢谢分享。
已领礼包: 6468个
发表于 2018-6-29 00:36:30 | 显示全部楼层
不知道有什么用。
自定义纸张用的,不知道怎么使用。  详情 回复 发表于 2018-6-29 12:52
 楼主| 发表于 2018-6-29 12:52:48 | 显示全部楼层
sicky111 发表于 2018-6-29 00:36
不知道有什么用。
自定义纸张用的,不知道怎么使用。
发表于 2020-3-27 02:30:04 | 显示全部楼层
程序无法打开?
GMT+8, 2026-11-4 08:16 , Processed in 0.555594 second(s), 48 queries , Gzip On.
