查看: 1504|回复: 9
[求助] lisp not working
已领礼包: 2671个
财富等级: 家财万贯
发表于 2018-7-24 17:26:23 | 显示全部楼层 |阅读模式
Dear All,
Pleas check lisp not working
[Actionscript3] 纯文本查看 复制代码
(defun c:RM (/ roomname roomsz)
  (defun roomname ()
    (textpage)
    (princ "\nROOMNAME OPTIONS: ")
    (princ "\n\t Living Kitchen Bed Toilet ")
    (princ " \n\t Office SHop STore STUdy ")
    (princ "\n\t Dining Puja BAth Wc = WC ")
    (princ
      "\n\t LIft = LT LObby S.toi. Living/dining = LD "
    (princ " \n\nPress any key to return to your drawing ")
    (grread)
    (princ "\r ")
    (graphscr)
  ) ;End of roomname
  (defun roomsz
         (/ p1 p2 p3 p4 x x1 y y1 tx h ht1 rm op pl pm tm ft rsz pll)
    (sharad)
    (if (null txlay)
      (progn (setq txlay "tx")
             (setq txlayer (tblsearch "layer" txlay))
             (if (null txlayer)
               (progn (setq txlay (getstring "\nLayer name for TEXT : "))
                      ( Setq txclr
                             (getstring (strcat "\nColor for " txlay " layer: "))
                      (command "layer" "m" txlay "c" txclr "" "")
               (prompt "\nTEXT ON TX LAYER")
    (setvar "osmode" 32)
    (menucmd "p0=filters")
    (menucmd "p0=*")
    (if (null ht)
      (setq ht "250")
    (setq p1 (getpoint "\nPick room corner: ")
          P2 (getcorner p1 "\nPick Diagonally opposite corner: ")
          p3 (list (car p2) (cadr p1))
          p4 (list (car p1) (cadr p2))
          a (distance p1 p3)
          b (distance p1 p4)
          x (* 0.001 a)
          y (* 0.001 b)
          x1 (rtos x 2 2)
          y1 (rtos y 2 2)
          mt (strcat x1 "x" y1)
    (setq ix (cvunit x "meter" "inch")
          iy ( Cvunit y "meter" "inch")
          xf (rtos ix 4 0)
          yf (rtos iy 4 0)
          ft (strcat xf "x" yf)
    (PROMPT "\nENTER FOLLOWING KEYWORD OR TY FOR TYPE")
    (setq cnt T )
    (while cnt
      (initget 1
               (strcat "Living Kitchen Bed Toilet "
                       "Office SHop STore STUdy "
                       "Dining Puja BAth WC TY ? "
                       "LT LObby S.toi. LD "
      (setq rm
             (getkword
               "\nROOM NAME = Liv/Bed/Kit/Toi/Off/Din/SHop/BAth /WC/STore/STUdy/S./LT/LD/LO/TYpe/?:"
      (if (/= (type rm) 'LIST)
        (if (= rm "?")
          (progn (roomname) (
          Setq cnt T)) (progn
            (setq cnt nil)
            (if (= rm "LT")
              (setq rm "LIFT")
            (if (= rm "LD")
              (setq rm "living/dining")
            (if (= rm "WC")
              (setq rm "WC")
            (IF (= rm "TY")
              (setq rsz (strcase (getstring t "\nTYPE ROOM NAME: ")))
              (setq rsz (strcase rm))
        (setq cnt nil)
    (setq
      tm (strcase (getstring (strcat "\nENTER TEXT HEIGHT <" ht ">:"))
                  t
    (if (/= tm "")
      (setq ht tm)
    (setq h (atof ht)
          ht1 (* h 0.88888)
          dt (* h 1.7)
    (setvar " Osmode" 0)
    (setvar "orthomode"1)
    (setq ht1 (fix ht1))
    (setq pc (polar p1
                    (angle p1 p2)
                    (/ (distance p1 p2) 2)
          pm (polar pc
                    (* pi 1.5)
                    (/ h 3.55)
          pt (polar pc (/ pi 2) dt)
          pf (polar pc (* pi 1.5) dt)
    (command "layer" "t" txlay "on" txlay "s" Txlay
             "" "text" "s" "rD" "m" pt h "0"
             rsz
    (setq pm2 (getpoint pm "\nENDPOINT OF TEXT: ")
          PM1 (polar pm pi (distance pm pm2))
          pf1 (polar Pf pi (distance pm pm2))
          pf2 (polar pf 0 (distance pm pm2))
    (command "text" "s" "rs" "f" pm1 pm2 ht1 mt "text" "f"Pf1 pf2 ht1
             ft)
  (defun readata ()
    (setq roomname (nth (atoi (get_tile "roomn")) roomlist)
          Lay1 (nth (atoi (get_tile "lay1")) laylist)
          txth1 (atoi (get_tile "txth1"))
          txts1 (nth (atoi (get_tile "txts1")) txtslist)
          lay2 (nth (ato_get_tile "lay2")) Laylist)
          txth2 (atoi (get_tile "txth2"))
          txts2 (nth (atoi (get_tile "txts2")) txtslist)
          prec (atoi (get_tile "prec"))
          lsc (atoi (get_tile "lsc"))
          txth3 (get_tile " Txtth3")
          txts3 (nth (atoi (get_tile "txts3")) txtslist)
          lay3 (nth (atoi (get_tile "lay3")) laylist)
          alter (= (get_tile "alter") "1")
          sqmt (= (get_tile " Sqmt") "1")
          sqft (= (get_tile "sqft") "1")
          txtway (= (get_tile "txtway") "Vertical")
          Ang (read (get_tile "ang"))
  (defun showlist ()
    (setq roomlist '("living" "kitchen" "bedroom" "toilet")
          laylist '("Layer-1" "Layer-2" "Layer -3" "Layer-4" "Layer-5")
          txtslist '("Style-1" "Style-2" "Style-3" "Style-4" "Style-5")
    (start_list "roomn")
    (mapcar 'add_list roomlist)
    (end_list)
    (start_list "lay1")
    (mapcar 'add_list laylist)
    (end_list)
    (start_list "txts1")
    (mapcar 'Add_list txtslist)
    (end_list)
    (start_list "lay2")
    (end_list)
    (start_list "txts2")
    (mapcar 'add_list txtslist)
    (end_list)
    (start_list "lay3")
    (end_list)
    (start_list "txts3")
    (end_list)
    (set_tile "roomn" "0")
    (set_tile "lay1" "0")
    (set_tile "txts1" "0")
    (set_tile "lay2" "1")
    (set_tile "txts2" "1")
    (set_tile "lay3" "2")
    (set_tile "txts3" "2 ")
    (set_tile "txth1" "250")
    (set_tile "txth2" "250")
    (set_tile "Txtth3" "250")
    (set_tile "prec" "2")
    (set_tile "lsc" "1.000")
  (if (> (setq dcl_id (load_dialog "room")) 0)
    (progn (if (new_dialog "room" dcl_id "")
             (progn (showlist)
                    (action_tile "accept" "(readata) (done_dialog 1)")
                    (action_tile "cancel" "(done_dialog 0)")
                    (setq re (start_dialog ))
             (alert "Unable to display dialog box!")
           (unload_dialog dcl_id)
    (alert "Unable to load dialog box!")
        (if (= re 1)
(progn
                                        ;add
dcl_settings : default_dcl_settings { audit_level = 3; }
room : dialog {
label="Room Name & Size Setup";
:row {
  :boxed_column {
   label="Room Name Setting";
   :popup_list{label=" Room Name :";key="roomn";edit_width=10;list="";}
   :popup_list{label="Layer:";key="lay1";edit_width=10;list="";}
   :edit_box{ Label="Text Height:";key="txth1";edit_width=10;list="";}
   :popup_list{label="Text Style:";key="txts1";edit_width=10;list=""; }
  :boxed_column {
   label="Room Size Setting";
   :popup_list{label="Layer:";Key="lay2";edit_width=10;list="";}
   :edit_box{label="Text Height:";key="txth2";edit_width=10;list="";}
   :popup_list{label="Text Style";key="txts2";edit_width=10;list="";}
   :edit_box{label="Precision:";key="prec"; edit_width=10;list="" ;}
   :edit_box{label="Liner Scale Factor";key="lsc";edit_width=10;list="";}
:row{
  :boxed_column{
   label="Alternet Room Size Setting";
   :edit_box{label ="Text Height:";key="txth3";edit_width=10;}
   :popup_list{label="Text Style:";key="txts3";edit_width=10;}
   :popup_list{label="Layer:"; Key="lay3";list="";edit_width=10;}
   :toggle{label="Alternet Unit:";key="alter";edit_width=10;value="0";}
  :column{
   :row{
    :boxed_column{
     label="Area";
     :toggle{label="Area in SqMt.";key="sqmt";value="0";}
     :toggle{label="Area in SqFt.";key="sqft";value="0";}
    :boxed_column{
     label="Text Rotation";
     key="txtway";
     :radio_column{
      :radio_button{label"Horizontal";key="hor";}
      :radio_button{label="Vertical";key="ver" ;}
     :edit_box{label="Angle";key="ang";}
   spacer;
   ok_cancel;
room.rar
2.42 KB, 下载次数: 3, 下载积分: D豆 -1 , 活跃度 1
发表于 2018-7-24 17:28:38 | 显示全部楼层
missing (sharad)
已领礼包: 2671个
财富等级: 家财万贯
 楼主| 发表于 2018-7-24 17:37:00 | 显示全部楼层
  1. (defun c:RM (/ roomname roomsz)
  2.   (defun roomname ()
  3.     (textpage)
  4.     (princ "\nROOMNAME OPTIONS: ")
  5.     (princ "\n\t Living   Kitchen    Bed     Toilet ")
  6.     (princ "\n\t Office   SHop       STore   STUdy  ")
  7.     (princ "\n\t Dining   Puja       BAth    W.c. = WC  ")
  8.     (princ
  9.       "\n\t LIft = LT LObby S.toi.  Living/dining = LD "
  10.     )
  11.     (princ "\n\nPress any key to return to your drawing ")
  12.     (grread)
  13.     (princ "\r                                          ")
  14.     (graphscr)
  15.   )                                        ;End of roomname
  16.   (defun roomsz
  17.          (/ p1 p2 p3 p4 x x1 y y1 tx h ht1 rm op pl pm tm ft rsz pll)
  18.     (sharad)
  19.     (if        (null txlay)
  20.       (progn (setq txlay "tx")
  21.              (setq txlayer (tblsearch "layer" txlay))
  22.              (if (null txlayer)
  23.                (progn (setq txlay (getstring "\nLayer name for TEXT : "))
  24.                       (setq txclr
  25.                              (getstring (strcat "\nColor for " txlay " layer: "))
  26.                       )
  27.                       (command "layer" "m" txlay "c" txclr "" "")
  28.                )
  29.                (prompt "\nTEXT ON TX LAYER")
  30.              )
  31.       )
  32.     )
  33.     (setvar "osmode" 32)
  34.     (menucmd "p0=filters")
  35.     (menucmd "p0=*")
  36.     (if        (null ht)
  37.       (setq ht "250")
  38.     )
  39.     (setq p1 (getpoint "\nPick room corner: ")
  40.           p2 (getcorner p1 "\nPick Diagonally opposite corner: ")
  41.           p3 (list (car p2) (cadr p1))
  42.           p4 (list (car p1) (cadr p2))
  43.           a  (distance p1 p3)
  44.           b  (distance p1 p4)
  45.           x  (* 0.001 a)
  46.           y  (* 0.001 b)
  47.           x1 (rtos x 2 2)
  48.           y1 (rtos y 2 2)
  49.           mt (strcat x1 "x" y1)
  50.     )
  51.     (setq ix (cvunit x "meter" "inch")
  52.           iy (cvunit y "meter" "inch")
  53.           xf (rtos ix 4 0)
  54.           yf (rtos iy 4 0)
  55.           ft (strcat xf "x" yf)
  56.     )
  57.     (PROMPT "\nENTER FOLLOWING KEYWORD OR TY FOR TYPE")
  58.     (setq cnt T)
  59.     (while cnt
  60.       (initget 1
  61.                (strcat "Living Kitchen Bed Toilet "
  62.                        "Office SHop STore STUdy "
  63.                        "Dining Puja BAth WC TY ? "
  64.                        "LT LObby S.toi. LD "
  65.                )
  66.       )
  67.       (setq rm
  68.              (getkword
  69.                "\nROOM NAME = Liv/Bed/Kit/Toi/Off/Din/SHop/BAth/WC/STore/STUdy/S./LT/LD/LO/TYpe/?:"
  70.              )
  71.       )
  72.       (if (/= (type rm) 'LIST)
  73.         (if (= rm "?")
  74.           (progn (roomname) (setq cnt T))
  75.           (progn
  76.             (setq cnt nil)
  77.             (if        (= rm "LT")
  78.               (setq rm "LIFT")
  79.             )
  80.             (if        (= rm "LD")
  81.               (setq rm "living/dining")
  82.             )
  83.             (if        (= rm "WC")
  84.               (setq rm "W.C.")
  85.             )
  86.             (IF        (= rm "TY")
  87.               (setq rsz (strcase (getstring t "\nTYPE ROOM NAME: ")))
  88.               (setq rsz (strcase rm))
  89.             )
  90.           )
  91.         )
  92.         (setq cnt nil)
  93.       )
  94.     )
  95.     (setq
  96.       tm (strcase (getstring (strcat "\nENTER TEXT HEIGHT <" ht ">:"))
  97.                   t
  98.          )
  99.     )
  100.     (if        (/= tm "")
  101.       (setq ht tm)
  102.     )
  103.     (setq h   (atof ht)
  104.           ht1 (* h 0.88888)
  105.           dt  (* h 1.7)
  106.     )
  107.     (setvar "osmode" 0)
  108.     (setvar "orthomode" 1)
  109.     (setq ht1 (fix ht1))
  110.     (setq pc (polar p1
  111.                     (angle p1 p2)
  112.                     (/ (distance p1 p2) 2)
  113.              )
  114.           pm (polar pc
  115.                     (* pi 1.5)
  116.                     (/ h 3.55)
  117.              )
  118.           pt (polar pc (/ pi 2) dt)
  119.           pf (polar pc (* pi 1.5) dt)
  120.     )
  121.     (command "layer"           "t"          txlay         "on"        txlay  "s"    txlay
  122.              ""            "text" "s"          "rD"         "m"        pt     h      "0"
  123.              rsz
  124.             )
  125.     (setq pm2 (getpoint pm "\nENDPOINT OF TEXT: ")
  126.           PM1 (polar pm pi (distance pm pm2))
  127.           pf1 (polar pf pi (distance pm pm2))
  128.           pf2 (polar pf 0 (distance pm pm2))
  129.     )
  130.     (command "text" "s"        "rs" "f" pm1 pm2 ht1 mt        "text" "f" pf1 pf2 ht1
  131.              ft)
  132.   )
  133.   (defun readata ()
  134.     (setq roomname (nth (atoi (get_tile "roomn")) roomlist)
  135.           lay1           (nth (atoi (get_tile "lay1")) laylist)
  136.           txth1           (atoi (get_tile "txth1"))
  137.           txts1           (nth (atoi (get_tile "txts1")) txtslist)
  138.           lay2           (nth (atoi (get_tile "lay2")) laylist)
  139.           txth2           (atoi (get_tile "txth2"))
  140.           txts2           (nth (atoi (get_tile "txts2")) txtslist)
  141.           prec           (atoi (get_tile "prec"))
  142.           lsc           (atoi (get_tile "lsc"))
  143.           txth3           (get_tile "txth3")
  144.           txts3           (nth (atoi (get_tile "txts3")) txtslist)
  145.           lay3           (nth (atoi (get_tile "lay3")) laylist)
  146.           alter           (= (get_tile "alter") "1")
  147.           sqmt           (= (get_tile "sqmt") "1")
  148.           sqft           (= (get_tile "sqft") "1")
  149.           txtway   (= (get_tile "txtway") "Vertical")
  150.           ang           (read (get_tile "ang"))
  151.     )
  152.   )
  153.   (defun showlist ()
  154.     (setq roomlist '("living" "kitchen" "bedroom" "toilet")
  155.           laylist  '("Layer-1" "Layer-2" "Layer-3" "Layer-4" "Layer-5")
  156.           txtslist '("Style-1" "Style-2" "Style-3" "Style-4" "Style-5")
  157.     )
  158.     (start_list "roomn")
  159.     (mapcar 'add_list roomlist)
  160.     (end_list)
  161.     (start_list "lay1")
  162.     (mapcar 'add_list laylist)
  163.     (end_list)
  164.     (start_list "txts1")
  165.     (mapcar 'add_list txtslist)
  166.     (end_list)
  167.     (start_list "lay2")
  168.     (mapcar 'add_list laylist)
  169.     (end_list)
  170.     (start_list "txts2")
  171.     (mapcar 'add_list txtslist)
  172.     (end_list)
  173.     (start_list "lay3")
  174.     (mapcar 'add_list laylist)
  175.     (end_list)
  176.     (start_list "txts3")
  177.     (mapcar 'add_list txtslist)
  178.     (end_list)
  179.     (set_tile "roomn" "0")
  180.     (set_tile "lay1" "0")
  181.     (set_tile "txts1" "0")
  182.     (set_tile "lay2" "1")
  183.     (set_tile "txts2" "1")
  184.     (set_tile "lay3" "2")
  185.     (set_tile "txts3" "2")
  186.     (set_tile "txth1" "250")
  187.     (set_tile "txth2" "250")
  188.     (set_tile "txth3" "250")
  189.     (set_tile "prec" "2")
  190.     (set_tile "lsc" "1.000")
  191.   )
  192.   (if (> (setq dcl_id (load_dialog "room")) 0)
  193.     (progn (if (new_dialog "room" dcl_id "")
  194.              (progn (showlist)
  195.                     (action_tile "accept" "(readata) (done_dialog 1)")
  196.                     (action_tile "cancel" "(done_dialog 0)")
  197.                     (setq re (start_dialog))
  198.              )
  199.              (alert "Unable to display dialog box!")
  200.            )
  201.            (unload_dialog dcl_id)
  202.     )
  203.     (alert "Unable to load dialog box!")
  204.   )
  205.         (if (= re 1)
  206. (progn
  207.                                         ;add
  208. )
  209. )
  1. dcl_settings : default_dcl_settings { audit_level = 3; }
  2. room : dialog {
  3. label="Room Name & Size Setup";
  4. :row {
  5. &#160;&#160;:boxed_column {
  6. &#160; &#160;label="Room Name Setting";
  7. &#160; &#160;:popup_list{label="Room Name :";key="roomn";edit_width=10;list="";}
  8. &#160; &#160;:popup_list{label="Layer:";key="lay1";edit_width=10;list="";}
  9. &#160; &#160;:edit_box{label="Text Height:";key="txth1";edit_width=10;list="";}
  10. &#160; &#160;:popup_list{label="Text Style:";key="txts1";edit_width=10;list="";}
  11. &#160;&#160;}
  12. &#160;&#160;:boxed_column {
  13. &#160; &#160;label="Room Size Setting";
  14. &#160; &#160;:popup_list{label="Layer:";key="lay2";edit_width=10;list="";}
  15. &#160; &#160;:edit_box{label="Text Height:";key="txth2";edit_width=10;list="";}
  16. &#160; &#160;:popup_list{label="Text Style";key="txts2";edit_width=10;list="";}
  17. &#160; &#160;:edit_box{label="Precision:";key="prec"; edit_width=10;list="";}
  18. &#160; &#160;:edit_box{label="Liner Scale Factor";key="lsc";edit_width=10;list="";}
  19. &#160;&#160;}
  20. }
  21. :row{
  22. &#160;&#160;:boxed_column{
  23. &#160; &#160;label="Alternet Room Size Setting";
  24. &#160; &#160;:edit_box{label="Text Height:";key="txth3";edit_width=10;}
  25. &#160; &#160;:popup_list{label="Text Style:";key="txts3";edit_width=10;}
  26. &#160; &#160;:popup_list{label="Layer:";key="lay3";list="";edit_width=10;}
  27. &#160; &#160;:toggle{label="Alternet Unit:";key="alter";edit_width=10;value="0";}
  28. &#160;&#160;}
  29. &#160;&#160;:column{
  30. &#160; &#160;:row{
  31. &#160; &#160; :boxed_column{
  32. &#160; &#160;&#160;&#160;label="Area";
  33. &#160; &#160;&#160;&#160;:toggle{label="Area in S.q.Mt.";key="sqmt";value="0";}
  34. &#160; &#160;&#160;&#160;:toggle{label="Area in S.q.Ft.";key="sqft";value="0";}
  35. &#160; &#160; }
  36. &#160; &#160; :boxed_column{
  37. &#160; &#160;&#160;&#160;label="Text Rotation";
  38. &#160; &#160;&#160;&#160;key="txtway";
  39. &#160; &#160;&#160;&#160;:radio_column{
  40. &#160; &#160;&#160; &#160;:radio_button{label="Horizontal";key="hor";}
  41. &#160; &#160;&#160; &#160;:radio_button{label="Vertical";key="ver";}
  42. &#160; &#160;&#160;&#160;}
  43. &#160; &#160;&#160;&#160;:edit_box{label="Angle";key="ang";}
  44. &#160; &#160; }
  45. &#160; &#160;}
  46. &#160; &#160;spacer;
  47. &#160; &#160;ok_cancel;
  48. &#160;&#160;}
  49. }
  50. }
已领礼包: 2671个
财富等级: 家财万贯
 楼主| 发表于 2018-7-25 18:24:40 | 显示全部楼层
master can help me
已领礼包: 604个
发表于 2018-7-25 19:13:44 | 显示全部楼层
Can tell you methods, but can't write code for you
已领礼包: 51个
发表于 2018-7-25 20:36:48 | 显示全部楼层
You haven't finished this program yet.
dear sir, thanks for reply , as per advice revised the code but not working , not execute the command  详情 回复 发表于 2018-7-26 15:09
dear sir, thanks for reply , as per advice revised the code but not working , not execute the command  详情 回复 发表于 2018-7-26 15:07
已领礼包: 2671个
财富等级: 家财万贯
 楼主| 发表于 2018-7-26 15:07:11 | 显示全部楼层
dear sir,
thanks for reply ,
你贴的代码,还没有完成,执行当然要出错了。  详情 回复 发表于 2018-7-26 16:41
已领礼包: 2671个
财富等级: 家财万贯
 楼主| 发表于 2018-7-26 15:09:41 | 显示全部楼层
dear sir,
thanks for reply ,
发表于 2018-7-26 16:41:04 | 显示全部楼层
sachindkini 发表于 2018-7-26 15:07
dear sir,
thanks for reply ,
as per advice revised the code but not working , not execute the co ...
已领礼包: 568个
发表于 2018-7-28 08:15:19 | 显示全部楼层
我来看看,哈哈
GMT+8, 2026-11-5 04:23 , Processed in 0.487188 second(s), 52 queries , Gzip On.
