查看: 1778|回复: 9
[每日一码] 每个图层单独保存成DWG
发表于 2018-11-23 15:24:51 | 显示全部楼层 |阅读模式
  1. (defun c:lay2dwg ( / bor doc dwg idx lst sel ssc sso tmp typ val )
  2.    (setq dwg (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)))
  3.          doc (vla-get-activedocument (vlax-get-acad-object))
  4.          ssc (vla-get-selectionsets doc)
  5.          typ (vlax-make-safearray vlax-vbinteger '(0 . 1))
  6.          val (vlax-make-safearray vlax-vbvariant '(0 . 1))
  7.          tmp 0
  8.    )
  9.    (vlax-safearray-put-element typ 0)
  10.    (vlax-safearray-put-element typ 1 410)
  11.    (vlax-safearray-put-element val 1 "Model")
  12.    (while
  13.        (not
  14.            (vl-catch-all-error-p
  15.                (vl-catch-all-apply 'vla-item
  16.                    (list ssc (strcat "lay2dwg" (itoa (setq tmp (1+ tmp)))))
  17.                )
  18.            )
  19.        )
  20.    )
  21.    (setq sso (vla-add ssc (strcat "lay2dwg" (itoa tmp))))
  22.    (if (setq sel (ssget "_X" '((8 . "BORDO") (410 . "Model"))))
  23.        (progn
  24.            (repeat (setq idx (sslength sel))
  25.                (setq idx (1- idx)
  26.                      lst (cons (vlax-ename->vla-object (ssname sel idx)) lst)
  27.                )
  28.            )
  29.            (setq bor
  30.                (vlax-make-variant
  31.                    (vlax-safearray-fill
  32.                        (vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst))))
  33.                        lst
  34.                    )
  35.                )
  36.            )
  37.        )
  38.    )
  39.    (vlax-for lay (vla-get-layers doc)
  40.        (if (/= "BORDO" (strcase (vla-get-name lay)))
  41.            (progn
  42.                (vlax-safearray-put-element val 0 (vla-get-name lay))
  43.                (vla-clear  sso)
  44.                (vla-select sso acselectionsetall nil nil (vlax-make-variant typ) (vlax-make-variant val))
  45.                (if (< 0 (vla-get-count sso))
  46.                    (progn
  47.                        (if bor (vla-additems sso bor))
  48.                        (vla-wblock doc (strcat dwg "_" (vla-get-name lay) ".dwg") sso)
  49.                    )
  50.                )
  51.            )
  52.        )
  53.    )
  54.    (vla-delete sso)
  55.    (princ)
  56. )
已领礼包: 418个
发表于 2018-11-23 17:07:22 | 显示全部楼层
好,实用。学习楼主提供。
发表于 2019-1-20 13:01:11 | 显示全部楼层
看到vl系列就头晕,之前用的是COMMAND "WBLOCK".....
发表于 2019-1-20 13:34:28 | 显示全部楼层
学习代码如此重要,每天都不能落下
已领礼包: 6056个
发表于 2019-2-19 18:07:08 | 显示全部楼层
可以再合并回来吗?
已领礼包: 2888个
财富等级: 家财万贯
发表于 2019-2-19 19:02:57 | 显示全部楼层
谢谢分享。。。。。。。。。。。。。。。。。。。
已领礼包: 228个
发表于 2019-2-20 08:40:11 | 显示全部楼层
谢谢分享!!!!!
已领礼包: 1368个
发表于 2019-3-13 12:33:53 | 显示全部楼层
雪中送炭,正需要。谢谢!
已领礼包: 1368个
发表于 2019-3-13 16:51:32 | 显示全部楼层
帮忙看看: 错误: 数组下标非法。?"图层名称没有特殊字符呢“
已领礼包: 9341个
发表于 2019-3-14 22:17:02 | 显示全部楼层
谢谢分享!!!!!!!!!!
GMT+8, 2026-11-4 23:38 , Processed in 0.584250 second(s), 47 queries , Gzip On.
