查看: 3969|回复: 15
[原创] 删除当前空间内除0层以外的其它层
已领礼包: 55个
发表于 2019-2-1 17:08:33 | 显示全部楼层 |阅读模式
  1. ;删除除0层以外的其他层
  2. ;套用了好多同志们的程序,拼凑而成,在此不谢
  3. ;韩建文
  4. (defun c:erase_layer (/ oce al lay_name ss)
  5.   (vl-load-com)
  6.   (graphscr)
  7.   (command "clayer" "0")                ;打开解冻解锁所有图层
  8.   (vlax-for lay (vla-get-layers
  9.                   (vla-get-activedocument (vlax-get-acad-object))
  10.                 )
  11.     (cond ((= -1 (vlax-get lay 'lock)) (vlax-put lay 'lock 0)))
  12.     (cond ((= -1 (vlax-get lay 'freeze)) (vlax-put lay 'freeze 0)))
  13.     (cond ((= -1 (vlax-get lay 'LayerOn)) (vlax-put lay 'LayerOn 0)))
  14.   )                                     ;(setq al (entsel "\n选择所要删除图层上的对象"))
  15.   (setq layer_lst (getlayers))
  16.   (setq i 0)
  17.   (repeat (length layer_lst)
  18.     (setq lay_name (nth i layer_lst))   ;(setq lay_name (cdr (assoc 8 (entget (car al)))))
  19.     (setq ss (ssget "X" (list (cons 8 lay_name))))
  20.     (command "_.erase" ss "")
  21.     (if (and (/= "0" lay_name) (/= (getvar "clayer") lay_name))
  22.       (command "_purge" "la" lay_name "n")
  23.     )
  24.     (setq i (+ i 1))
  25.   )                                     ;end repeat
  26. )                                       ;end fun
  27.                                         ;统计图层数目列表
  28. (defun getlayers (/ layername lst d)
  29.   (setq d   (tblnext "layer" t)
  30.         lst nil
  31.   )
  32.   (while d
  33.     (setq layername (cdr (assoc 2 d)))
  34.     (setq lst (append lst (list layername)))
  35.     (setq d (tblnext "layer"))
  36.   )                                     ;end while
  37.   lst
  38. )                                       ;end fun
评分
参与人数 1D豆 +5 收起 理由
newer + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2019-2-1 17:20:50 | 显示全部楼层
(getlayers)完全可以不用
你在
这个循环里面,就可以做(getlayers)的工作。
已领礼包: 20个
发表于 2019-2-1 17:45:32 | 显示全部楼层
可以改成这样
  1. (defun c:erase_layer (/ oce al lay_name ss layer_lst)  (vl-load-com)
  2.   (graphscr)
  3.   (setvar "clayer" "0")
  4.   (setvar "cmdecho" 0)
  5.   (setq layer_lst "")
  6.   (vlax-for lay (vla-get-layers
  7.                   (vla-get-activedocument (vlax-get-acad-object))
  8.                 )
  9.     (setq name (vla-get-name lay))
  10.     (if (/= name "0")
  11.       (progn (setq layer_lst (strcat name "," layer_lst))
  12.              (and (= :vlax-true (vlax-get lay 'lock)) (vlax-put lay 'lock :vlax-false))
  13.              (and (= :vlax-true (vlax-get lay 'freeze)) (vlax-put lay 'freeze :vlax-false))
  14.              (and (= :vlax-false (vlax-get lay 'LayerOn))
  15.                   (vlax-put lay 'LayerOn :vlax-true)
  16.              )
  17.       )
  18.     )
  19.   )
  20.   (and (setq ss (ssget "x" (list (cons 8 layer_lst))))
  21.        (command "_.erase" ss "")
  22.   )
  23.   (command "purge" "a" "" "n")
  24.   (princ)
  25. )
改的更简洁啦,谢谢啦,我就是半路出家,四处拼凑,只能以达到目的为追求  详情 回复 发表于 2019-2-2 08:12
已领礼包: 174个
发表于 2019-2-1 22:51:59 | 显示全部楼层
有个疑惑能帮解一下
像是其中
(and (= -1 (vlax-get lay 'lock)) (vlax-put lay 'lock 0))
跟直接(vlax-put lay 'lock 0)相比
后者会有什么不好的地方或是问题
(and (= -1 (vlax-get lay 'lock)) (vlax-put lay 'lock 0)) 就相当于: (if (= -1 (vlax-get lay 'lock)) (vlax-put lay 'lock 0) )  详情 回复 发表于 2019-2-1 22:54
已领礼包: 20个
发表于 2019-2-1 22:54:00 | 显示全部楼层
naruto018 发表于 2019-2-1 22:51
有个疑惑能帮解一下
像是其中
就相当于:
我的意思是比起先判断后(vlax-get lay 'lock) 再确定执行(vlax-put lay 'lock 0) 跟直接执行(vlax-put lay 'lock 0) 的差异  详情 回复 发表于 2019-2-1 23:01
已领礼包: 174个
发表于 2019-2-1 23:01:34 | 显示全部楼层
就相当于:
的差异
直接解冻、解锁也行 我是从他代码修改的  详情 回复 发表于 2019-2-1 23:03
已领礼包: 20个
发表于 2019-2-1 23:03:42 | 显示全部楼层
跟直接执行(vlax-put  ...
直接解冻、解锁也行
我是从他代码修改的
判断是GET,一般GET要比PUT快些,如果没冻结的, 不执行PUT,能快一丢丢
感谢marting大的解答  详情 回复 发表于 2019-2-1 23:12
已领礼包: 174个
发表于 2019-2-1 23:12:08 | 显示全部楼层
marting 发表于 2019-2-1 23:03
直接解冻、解锁也行
我是从他代码修改的
判断是GET,一般GET要比PUT快些,如果没冻结的, 不执行PUT,能 ...
感谢marting大的解答
已领礼包: 960个
发表于 2019-2-2 07:45:15 | 显示全部楼层
感觉手动删除也挺快的啊
已领礼包: 55个
 楼主| 发表于 2019-2-2 08:12:18 | 显示全部楼层
已领礼包: 4365个
发表于 2019-2-2 10:08:03 | 显示全部楼层
已领礼包: 5295个
发表于 2019-2-2 12:11:05 | 显示全部楼层
不断改进、不断完善,达到一个更高的水平!
已领礼包: 2888个
财富等级: 家财万贯
发表于 2019-2-2 12:27:09 | 显示全部楼层
谢谢分享、、、、、、、、、、、、、、、、、
已领礼包: 6434个
发表于 2019-2-2 14:38:41 | 显示全部楼层
学习学习下
已领礼包: 148个
发表于 2019-2-3 00:20:59 | 显示全部楼层
谢谢共享111111
GMT+8, 2026-11-5 00:07 , Processed in 0.598247 second(s), 58 queries , Gzip On.
