查看: 1204|回复: 0
[求助] 打印时,怎样获取到打印的设置信息
发表于 2019-5-17 20:10:11 | 显示全部楼层 |阅读模式
我在打印反应器中,想获取到当前设置的打印设置AcDbPlotSettings,但试了一下没成功,想请教一下各位大大,下面是我写的代码:
void CPlotReactor::beginPlot(AcPlPlotProgress* pPlotProgress,PlotType type)
        AcApLayoutManager *pLayMan = NULL;
        pLayMan = (AcApLayoutManager *) acdbHostApplicationServices()->layoutManager();
        //get the active layout
        AcDbLayout *pLayout = pLayMan->findLayoutNamed(pLayMan->findActiveLayout(TRUE),TRUE);
        AcDbPlotSettings* pPlotSetting = (AcDbPlotSettings*)pLayout;
        if(pPlotSetting->plotType()!=AcDbPlotSettings::kWindow)
             acutPrintf(_T("打印范围只能选择窗口方式"));
                 pPlotProgress->setPlotCancelStatus(pPlotProgress->kPlotCanceledByCaller);
                 return;
        double minX,minY,maxX,maxY;
        pPlotSetting->getPlotWindowArea(minX,minY,maxX,maxY);
        double window_area=(maxX-minX)*(maxY-minY);
        if(window_area>1)
                acutPrintf(_T("当前绘制面积大于1平方公里"));
                return;
GMT+8, 2026-11-22 08:54 , Processed in 0.209843 second(s), 8 queries , Gzip On, File On.
