查看: 1349|回复: 2
[每日一码] Initialize 事件
已领礼包: 1268个
发表于 2019-10-13 06:01:14 | 显示全部楼层 |阅读模式
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.Runtime;
  3. [assembly: ExtensionApplication(typeof(ClassLibrary2.Class1))]
  4. [assembly: CommandClass(typeof(ClassLibrary2.MyCommands))]
  5. namespace ClassLibrary2
  6. {
  7.     public class Class1 : IExtensionApplication
  8.     {
  9.         public void Initialize()
  10.         {
  11.             var mc = new MyCommands();
  12.             mc.MyCommandEvents();
  13.         }
  14.         public void Terminate()
  15.         {
  16.         }
  17.     }
  18.     public class MyCommands
  19.     {
  20.         private string _cmdname = "";
  21.         internal void MyCommandEvents()
  22.         {
  23.             Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument.CommandEnded +=
  24.                 MdiActiveDocument_CommandEnded;
  25.         }
  26.         private void MdiActiveDocument_CommandEnded(object sender, CommandEventArgs e)
  27.         {
  28.             _cmdname = e.GlobalCommandName;
  29.             Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
  30.                 "\n{0} ended.",
  31.                 e.GlobalCommandName);
  32.         }
  33.      }
  34. }
已领礼包: 6202个
发表于 2019-10-13 20:13:00 | 显示全部楼层
可以跟大师学习学习,谢谢分享
发表于 2020-2-20 16:57:22 | 显示全部楼层
学习一下,楼主辛苦了
GMT+8, 2026-11-3 00:55 , Processed in 0.389183 second(s), 32 queries , Gzip On.
