查看: 1366|回复: 1
[求助] 划线标注,非常好用,求大神优化一下标注全局比例!
发表于 2019-12-24 18:16:01 | 显示全部楼层 |阅读模式
  • (defun C:dsa (/ minsize pt1 bzbl pt2 ss intlist
  • x y lds olden pts1 pts2 n ens
  • code i ptx endata
  •   (command "DIMSCALE" BZBL)
  • (defun *error* (msg)
  • (setvar "osmode" osm);;还原捕捉点设置
  • (princ "\n程序终止")
  • (if (< (atof (getvar "acadver")) 20.0)
  • (command "undo" "end")
  • (command-s "undo" "end")
  • (princ "\nF3 临时切换捕捉开关,默认关闭");;设置F3键,可能是习惯吧
  • (princ "\n过滤尺寸下限:不生成小于此数值的尺寸标注的")
  • (setq osm (getvar "osmode"));;存储捕捉点设置
  • (if ddf_old_minsize
  • (setq minsize ddf_old_minsize)
  • (command "undo" "be")
  • (if
  • (progn (initget "S")
  • (setq pt1 (getpoint "\n指定标注起始方向/设置过滤尺寸(S)"))
  • (progn
  • (while (= "S" pt1)
  • (if (null ddf_old_minsize)
  • (setq minsize (getdist "\n请输入过滤尺寸,默认为<5mm>"))
  • (setq minsize (getdist (strcat "\n请输入过滤尺寸,上次输入为<"
  • (rtos ddf_old_minsize 2 2)
  • "mm>"
  • (if (null minsize)
  • (setq minsize 5)
  • (setq ddf_old_minsize minsize)
  • (initget "S")
  • ) ;end while
  • (setq minsize 5)
  • (setq pt2 (getpoint pt1 "\n指定标注方向"))
  • (if (and pt1 pt2)
  • (progn
  • (setq pt1(polar pt1 (angle pt2 pt1) minsize))
  • (setq pt2(polar pt2 (angle pt1 pt2) minsize))
  • (if (setq ss (ssget "F"
  • (list pt1 pt2)
  • ;;'((0 . "*E,CIRCLE,ARC") (6 . "BYLAYER"))
  • (progn
  • (setq intlist ()
  • endata (ssnamex ss)
  • (foreach x endata
  • (foreach y (cdddr x) (setq intlist (cons (cadr y) intlist)))
  • ;;点要排序一下才行,按从开始点的距离来排序
  • (setq lds (+ 10 (distance pt1 pt2)))
  • (setq intlist (vl-remove-if-not
  • '(lambda (x) (<= (distance x pt1) lds))
  • intlist
  • (setq
  • intlist (vl-sort intlist
  • '(lambda (x y)
  • (< (distance pt1 x) (distance pt1 y))
  • ;;这里开始写标注程序
  • (setq olden (entlast)
  • ss (ssadd)
  • (setq n 0)
  • (repeat (- (length intlist) 1)
  • (setq pts1 (nth n intlist)
  • pts2 (nth (1+ n) intlist)
  • (if (> (distance pts1 pts2) minsize)
  • (ddf_entmakedim pts1 pts2)
  • (setq n (1+ n))
  • ) ;end repeat
  • (while (setq ens (entnext olden))
  • (setq ss (ssadd ens ss)
  • olden ens
  • (if(>(getvar"OSMODE")16384)(princ)(setvar"OSMODE"(+(getvar"OSMODE")16384)));;默认关闭捕捉
  • ;(if(>(getvar"OSMODE")16384)(setvar"OSMODE"(-(getvar"OSMODE")16384))(princ));默认打开捕捉
  • ;;下面开始来移动
  • (setq loop t);;;带捕捉的grread框架开始
  • (while loop
  • (setq gr (grread t 15 0) code (car gr) ptx (cadr gr))
  • (cond
  • ((= code 3)(redraw) (setq loop nil)) ; 鼠标左键
  • ((= code 5) ; 鼠标移动
  • (redraw)
  • (if (>(getvar"OSMODE")16384)
  • (princ)
  • (setq ptx (osnappt nil ptx))
  • ;;根据获取的动态点坐标更新程序-开始
  • (setq i 0)
  • (repeat (sslength ss)
  • (setq endata (entget (ssname ss i)))
  • (entmod (subst (cons 10 ptx) (assoc 10 endata) endata))
  • (setq i (1+ i))
  • ); end repeat
  • ;;根据获取的动态点坐标更新程序-结束
  • ((member code '(2 6)) ; 键盘输入--"F3"键
  • (if(>(getvar"OSMODE")16384)(setvar"OSMODE"(-(getvar"OSMODE")16384))(setvar"OSMODE"(+(getvar"OSMODE")16384))));切换捕捉开关
  • ;((= code 2) ; 键盘输入
  • ; (princ "\n键盘输入=")(princ pt))
  • ((member code '(11 25)); 鼠标右击
  • (redraw) (setq loop nil)
  • );end while;;;;;带捕捉的grread框架结束
  • ) ;end if
  • );end progn
  • ) ;end if
  • (princ "\n标注完成")
  • (command "undo" "END")
  • (prin1)
  • ) ;end
  • (defun ddf_entmakedim (pt1 pt2 /)
  • (cond
  • ((or (equal 0 (angle pt1 pt2) 0.001)
  • (equal pi (angle pt1 pt2) 0.001)
  • (entmake
  • (list
  • '(0 . "DIMENSION")
  • '(100 . "AcDbEntity")
  • '(100 . "AcDbDimension")
  • (cons 10 pt1)
  • '(70 . 32)
  • '(1 . "")
  • '(100 . "AcDbAlignedDimension")
  • (cons 13 pt1)
  • (cons 14 pt2)
  • '(100 . "AcDbRotatedDimension")
  • ((or (equal (/ pi 2) (angle pt1 pt2) 0.001)
  • (equal (* pi 1.5) (angle pt1 pt2) 0.001)
  • (entmake
  • (list
  •            (cons 10 pt1)
  • '(70 . 33)
  • '(1 . "")
  • (cons 13 pt1)
  • (cons 14 pt2)
  • ((and (null (equal 0 (angle pt1 pt2) 0.001))
  • (null (equal (/ pi 2) (angle pt1 pt2) 0.001))
  • (entmake
  • (list
  • (cons 10 pt1)
  • '(70 . 33)
  • '(1 . "")
  • (cons 13 pt1)
  • (cons 14 pt2)
  • ) ;end cond
  • ) ;end
  • (prin1)
  • ;;; grread捕捉子函数
  • ;;; name为移动的图元名,pt为光标点
  • ;;; 返回值:如果有捕捉点则返回捕捉点,无则返回光标点
  • (defun osnappt (name pt / color d h k lst nearpt nearpt2 osmo pt1 pt2 pt3 pt4 pt5 ptx pty x)
  • (if name (entdel name))
  • (redraw)
  • (if (< (getvar "osmode") 16384);;打开捕捉
  • (progn
  • (setq color (vla-get-autosnapmarkercolor (vla-get-drafting (vla-get-preferences (vlax-get-acad-object))))
  • h (/ (getvar "viewsize") (cadr (getvar "screensize"))) d (getvar "pickbox")
  • lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h)) k (* 1.5 d h))
  • (if (setq nearpt (osnap pt "_END,_CEN,_NOD,_QUA,_INS,_TAN,_EXT"))(setq osmo 1))
  • (if (and(setq nearpt2 (osnap pt "_NEA"))(not (equal nearpt nearpt2 k)))
  • (setq osmo 2 nearpt nearpt2))
  • (if (and(setq nearpt2 (osnap pt "_MID"))(equal nearpt nearpt2 k))
  • (setq osmo 3 nearpt nearpt2))
  • (if (and(setq nearpt2 (osnap pt "_INT"))(equal nearpt nearpt2 k))
  • (setq osmo 4 nearpt nearpt2))))
  • (if name(entdel name))
  • (if nearpt
  • (progn
  • (setq ptx (car nearpt)pty (cadr nearpt))
  • (foreach x lst
  • (setq pt1 (list (- ptx x) (- pty x)) pt2 (list (+ ptx x) (- pty x))
  • pt3 (list (+ ptx x) (+ pty x)) pt4 (list (- ptx x) (+ pty x))
  • pt5 (list ptx (+ pty x)))
  • (cond
  • ((= osmo 1)(grvecs (list color pt1 pt2 pt2 pt3 pt3 pt4 pt4 pt1)))
  • ((= osmo 2)(grvecs (list color pt1 pt2 pt2 pt4 pt3 pt4 pt3 pt1)))
  • ((= osmo 3) (grvecs (list color pt1 pt2 pt2 pt5 pt5 pt1)))
  • ((= osmo 4) (grvecs (list color pt1 pt3 color pt2 pt4)))))
  • (setq pt nearpt)))
  • pt
   这是一个非常好的划线标注命令!求大神增加一下标注尺寸的全局比例!每次标注的尺寸太小了!如果可以根据视口大小或者手动设置就完美了!
已领礼包: 6202个
发表于 2019-12-25 22:13:56 | 显示全部楼层
你的BZBL变量好像没赋值?
GMT+8, 2026-11-4 06:19 , Processed in 0.636682 second(s), 33 queries , Gzip On.
