查看: 984|回复: 1
[求助] 两个cad里的同名文件合并,求助大神帮忙
发表于 2020-1-2 17:32:17 | 显示全部楼层 |阅读模式
此代码只操作完成了文件夹里第一个文件,没有操作整个文件夹的文件,求大神帮忙改正。注:此代码是网上下载的,求助大神。
(DEFUN C:pc ()
(setq dsc (xuanzekuai))
(setq ljm (xuanzewenjian))
(setq selscr (strcat (getvar "TEMPPREFIX")"20140408.scr"));;创建CSR脚本语句
;;; 向脚本添加能识别的CSR语句;;;
(setq txlist (vl-directory-files ljm "*.dwg"));;生成文件列表
(setq i 0)
(setq len (vl-list-length txlist));;读取文件个数
(setq neirong (open selscr "w"))
(repeat len
   (setq tm (nth i txlist))
   (setq str2 (strcat ljm "\\" tm));;打开文件路径
   (setq str3 (strcat dsc "\\" tm));;插入块路径
   (princ (strcat "open \"" str2 "\"\n"
                 "-insert "  str3
                " 1 1 1 0 qsave \n"
                 "close \n"
          neirong
   (setq i (1+ i))
;;;;按文件数写入语句
(close neirong)
;;;关闭脚本文件
(command "._script" selscr);;;运行脚本
(princ)
;;;以下为选择需要打开的文件的子程序;;;
(defun xuanzewenjian (/ obj folder path)
(vl-load-com)
(setq obj (vlax-create-object "Shell.Application"))
(setq    folder (vlax-invoke-method
               obj                 'browseforfolder
               0                 "请指定要打开的DWG文件夹"
               1
  (if(vl-catch-all-error-p
       (setqpath (vl-catch-all-apply
                   '(lambda
                      (vlax-get-property
                        (vlax-get-property folder 'self)
                        'path
   nil
   path
;;;以下为选择块的文件的子程序;;;
(defun xuanzekuai (/ obj folder path)
(vl-load-com)
               0               "请指定要插入的DWG块文件夹"
               1
                   '(lambda
                      (vlax-get-property
                       'path
   nil
   path
发表于 2020-2-18 10:30:57 | 显示全部楼层
我也想要这个同名文件的CAD合并
GMT+8, 2026-11-4 04:29 , Processed in 0.535177 second(s), 30 queries , Gzip On.
