查看: 1109|回复: 5
[研讨] 标注递增1
发表于 2020-1-15 12:54:07 | 显示全部楼层 |阅读模式
_$ (defun addone (str)
  (setq n (strlen str))
  (setq nlst (reverse (vl-remove nil (mapcar '(lambda (x) (if (<= 48 x 57) (- x 48) nil)) (vl-string->list str)))))
  (setq str1 (substr str 1 (- n (length nlst))))
  (setq nlst (cons (+ 1 (car nlst)) (cdr nlst)) vlst nil flag t)
  (while  flag
    (if (< (car nlst) 10)
            (progn
          (setq vlst (append (reverse vlst) nlst))
                  (setq flag nil)
                (progn
           (setq vlst (cons (rem (car nlst) 10) vlst))
               (setq nlst (cons (+ (cadr nlst) (/ (car nlst) 10)) (cdr (cdr nlst))))
(setq str (strcat  str1 (vl-list->string (mapcar '(lambda (x) (+ 48 x)) (reverse vlst)))))
ADDONE
_$  (addone "A-001")
"A-002"
_$ (addone "A-009")
"A-010"
_$ (addone "A-019")
"A-020"
_$  (addone "A-099")
"A-100"
_$  (addone "A-101")
"A-102"
_$
 楼主| 发表于 2020-1-15 13:11:06 | 显示全部楼层
_$ (defun add_num (str num)
  (setq nlst (vl-remove nil (mapcar '(lambda (x) (if (<= 48 x 57) (- x 48) nil)) (vl-string->list str))))
  (setq numstr (itoa num) k (- (length nlst) (strlen numstr)))
  (repeat k (setq numstr (strcat "0" numstr)))
  (setq addnumlst (mapcar '(lambda (x) (- x 48)) (vl-string->list numstr)))
  (setq nlst (reverse (mapcar '+ nlst addnumlst)) vlst nil flag t)
  (while  flag
            (progn
                  (setq flag nil)
                (progn
ADD_NUM
_$ (ADD_NUM "A-019" 1)
"A-020"
_$ (ADD_NUM "A-019" 5)
"A-024"
_$ (ADD_NUM "A-019" 25)
"A-044"
_$ (ADD_NUM "A-139" 45)
"A-184"
_$
发表于 2020-1-15 14:31:50 | 显示全部楼层
感谢楼主分享程序!!!
发表于 2020-1-15 15:00:34 | 显示全部楼层
用正则表达式去识别更好
正则表达式太高大上了,小问题小办法解决就可以了。  详情 回复 发表于 2020-1-15 16:38
 楼主| 发表于 2020-1-15 16:38:12 | 显示全部楼层
Lisphk 发表于 2020-1-15 15:00
用正则表达式去识别更好
发表于 2020-1-15 22:06:29 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (setq ss (ssget '((0 . "text"))))
  3.     (progn
  4.       (setq i -1)
  5.       (repeat (sslength ss)
  6.         (setq e          (ssname ss (setq i (1+ i)))
  7.               txt (cdr (assoc 1 (setq ed (entget e))))
  8.         )
  9.         (if (setq num (xd::string:regexps "\\d+$" txt ""))
  10.           (progn
  11.             (setq num1         (car num)
  12.                   num num1
  13.                   prefix (substr txt 1 (- (strlen txt) (strlen num1)))
  14.                   num1         (+ 1 (atoi num1))
  15.                   num1         (itoa num1)
  16.             )
  17.             (if        (< (setq l1 (strlen num1)) (setq l2 (strlen num)))
  18.               (progn
  19.                 (repeat        (- l2 l1)
  20.                   (setq num1 (strcat "0" num1))
  21.                 )
  22.               )
  23.             )
  24.             (setq
  25.               ed (subst (cons 1 (strcat prefix num1)) (assoc 1 ed) ed)
  26.             )
  27.             (entmod ed)
  28.           )
  29.         )
  30.       )
  31.     )
  32.   )
  33.   (princ)
  34. )
GMT+8, 2026-11-22 10:01 , Processed in 0.484931 second(s), 19 queries , Gzip On, File On.
