查看: 1828|回复: 4
[求助] 求帮忙修改两根等高线内插高点使之能连续使用
发表于 2020-7-23 22:48:24 | 显示全部楼层 |阅读模式
(defun c:nc(/ p0 p1 p2 h h0 h1 h2 len ang dat strl min sec sec1 num num1 ss)
       (SETVAR "OSMODE" 512)
       (while (SETQ P0 (GETPOINT "\n指定第一条等高线:    "))
           (WHILE (not (SETQ P2 (GETPOINT "\n指定相邻的另一条等高线:    "))))
           (setq h1 (nth 2 p0) h2 (nth 2 p2) p0 (list (nth 0 p0) (nth 1 p0)) p2 (list (nth 0 p2) (nth 1 p2)))
           (setq len (distance p0 p2) ang (angle p0 p2))
           (if (and (/= h1 h2) (/= h1 0.0) (/= h2 0.0)) (progn
               (SETQ DAT (rtos (* (GETVAR "CDATE") 100000000) 2 8))
               (setq strl (strlen dat))
               (setq min (atoi (substr dat (- strl 5) 2)))
               (if (= min 0) (setq min 0.5))
               (setq sec (atoi (substr dat (- strl 3) 2)))
               (if (= sec 0) (setq sec 0.5))
               (setq sec1 (atoi (substr dat (- strl 1))))
               (if (= sec1 0) (setq sec1 0.5)(setq sec1 sec1))
               (setq num1 (/ (+ PI (* sec1 min)) sec))
               (IF (< NUM1 0.1) (SETQ NUM (* NUM1 10)))
               (if (AND (> NUM1 0.1) (< num1 1)) (setq num num1))
               (if (and (> num1 1) (< num1 10)) (setq num (/ num1 10.0)))
               (if (and (> num1 10) (< num 100)) (setq num (/ num1 100.0)))
               (if (and (> num1 100) (< num 1000)) (setq num (/ num1 1000.0)))
               (if (and (> num1 1000) (< num 10000)) (setq num (/ num1 10000.0)))
               (SETQ NUM (/ (ATOI (RTOS (* NUM 1000) 2 0)) 1000.0)) ;;;随机数函数
               (setq h (+ h1 (* num (- h2 h1))))
               (setq p1 (polar p0 ang (* len num)))
               (setq p1 (list (car p1) (cadr p1) h))
               (SETQ P2 (LIST (+ (CAR P1) 1.5) (- (CADR P1) 0.5) H))
               (SETVAR "OSMODE" 0)
               (command "layer" "s" "GCD" "")
               ;(COMMAND "TEXT" "S" "HZ" P2 "2.00" "0.0" (RTOS H 2 2))
               (SETQ SS (SSGET "W" (LIST (- (CAR P1) 0.3) (- (CADR P1) 0.3))
                                   (LIST (+ (CAR P1) 0.3) (+ (CADR P1) 0.3))))
               (IF SS (COMMAND "ERASE" SS ""))
               (COMMAND "ELEV" "0.0" "1610000")
               ;(COMMAND "POINT" P1)
               (command "clayer" "gcd")
               (command "dd" "202101"  "1" p1  "")
               (setvar "osmode" 0)
           ));;;end of IF
           (princ "\n.\n.\n.")
           (if (= h1 h2) (princ "\n警告: 等高线有严重错误或选中同一条等高线!两等高线之间的高差为0!!"))
           (if (or (> (- h1 h2) 0.5) (< (- h1 h2) -0.5)) (progn(princ "\n两等高线高差太大。为")
               (princ (- h2 h1))(princ"米。内插高程正确性难以保证。")))
       );;;end of WHILE
    );;;end of ADD_HI子函数
选择两根相邻等高线随机加高程后  在继续选择等高线会出现函数错误中断  求修改后可以连续选择等高线添加高程点
测试附件.rar
350.94 KB, 下载次数: 2, 下载积分: D豆 -1 , 活跃度 1
等高线
发表于 2020-7-24 13:44:48 | 显示全部楼层
求助问题,应该把你的图附上,让人家测试,几根线即可
另外,有什么错误,详细信息说明下,别人也好帮你
发表于 2020-7-24 14:43:53 | 显示全部楼层
竟然给min赋值
 楼主| 发表于 2020-8-4 21:12:48 | 显示全部楼层
已上传附件
 楼主| 发表于 2020-8-4 21:16:36 | 显示全部楼层
已上传附件
GMT+8, 2026-11-22 07:41 , Processed in 0.818336 second(s), 18 queries , Gzip On, File On.
