查看: 3910|回复: 1
ActiveX client with MFC ClassWizard or #import
发表于 2021-1-11 20:36:39 | 显示全部楼层 |阅读模式
问题:
Are there two ways of creating an AutoCAD ActiveX client using C++?
解答:
There are two ways of creating an AutoCAD Active X client using C++.
Method #1
Use MFC ClassWizard to import the interfaces (from acad.tlb) that you need for
your client application.
Method #2
Use #import with acad.tlb.
NOTE:  Although #import is something new from VC++ 5.0, it previously existed in
ClassWizard.
The following code segments demonstrate both methods, and is to be used with a
MFC ClassWizard-generated IAcadApplication interface.
// This is declared as a member variable in the CSampActiveXClientDlg.
// Given that you've use ClassWizard to import IAcadApplication interface
// from acad.tlb.
  1. IAcadApplication m_IApp;
  2. void CSampActiveXClientDlg::OnStartacad()
  3. {
  4. // TODO: Add your control notification handler code here
  5. HRESULT hr = NOERROR;
  6. CLSID clsid;
  7. LPUNKNOWN pUnk = NULL;
  8. LPDISPATCH pDisp = NULL;
  9. BeginWaitCursor();
  10. CoInitialize(NULL);
  11. hr = ::CLSIDFromProgID(L"AutoCAD.Application", &clsid);
  12. if (SUCCEEDED(hr))
  13. {
  14. if(::GetActiveObject(clsid, NULL, &pUnk) == S_OK)
  15. {
  16.   VERIFY(pUnk->QueryInterface(IID_IDispatch, (LPVOID*) &pDisp) == S_OK);
  17.   m_IApp.AttachDispatch(pDisp);
  18.   pUnk->Release();
  19. }
  20. else
  21.   VERIFY(m_IApp.CreateDispatch(clsid) == TRUE);
  22. m_IApp.SetVisible(TRUE);
  23. }
  24. else
  25. AfxMessageBox("Acad.Application is not registered!");
  26. EndWaitCursor();
  27. }
This code snippet is to be used with #import.
// your location of acad.tlb may vary
#import "c:\acad2k\acad.tlb" raw_interfaces_only, raw_native_types,
no_namespace, named_guids
  1. CComQIPtr<IAcadApplication, &IID_IAcadApplication> gpApp;
  2. // start Acad
  3. HRESULT InitAcad()
  4. {
  5. HRESULT hr = S_OK;
  6. CLSID clsid;
  7. // get acad running first
  8. hr = CLSIDFromProgID(L"AutoCAD.Application", &clsid);
  9. if(FAILED(hr))
  10. return hr;
  11. CComPtr<IUnknown> pIUnk;
  12. hr = GetActiveObject(clsid, NULL, pIUnk);
  13. if(!pIUnk)
  14. {
  15.   hr = CoCreateInstance(clsid, NULL, CLSCTX_LOCAL_SERVER,
  16.   IID_IAcadApplication, (void**)&gpApp);
  17. }
  18. else
  19.   gpApp = pIUnk;
  20. if(FAILED(hr) || !gpApp)
  21. return hr;
  22. gpApp->put_Visible(VARIANT_TRUE);
  23. return hr;
  24. }
发表于 2021-1-11 20:59:45 | 显示全部楼层
N版,改成C十十了?
GMT+8, 2026-11-22 07:21 , Processed in 0.325990 second(s), 6 queries , Gzip On, File On.
