查看: 2009|回复: 3
[每日一码] 打印到文件通用函数
已领礼包: 20个
发表于 2021-1-29 01:50:05 | 显示全部楼层 |阅读模式
  1. (vl-load-com)
  2. (defun PlotToFile (ConfigName         MediaName     Window
  3.                    FileName         /               AcadObj
  4.                    ActiveDocObj         ActiveLayoutObj
  5.                    PlotObj
  6.                   )
  7.   (setq        AcadObj                (vlax-get-acad-object)
  8.         ActiveDocObj        (vla-get-ActiveDocument AcadObj)
  9.         ActiveLayoutObj        (vla-get-ActiveLayout ActiveDocObj)
  10.   )
  11.   (vla-RefreshPlotDeviceInfo ActiveLayoutObj)
  12.   (vla-Put-ConfigName ActiveLayoutObj ConfigName)
  13.   (setq PlotObj (vla-get-Plot ActiveDocObj))
  14.   (vla-Put-CanonicalMediaName ActiveLayoutObj MediaName)
  15.   (vla-Put-StandardScale ActiveLayoutObj acScaleToFit)
  16.   (vla-Put-PlotRotation ActiveLayoutObj ac0degrees)
  17.   (vla-put-PlotOrigin
  18.     ActiveLayoutObj
  19.     (vlax-make-variant
  20.       (vlax-make-safearray vlax-vbDouble '(0 . 1))
  21.     )
  22.   )
  23.   (vla-Put-CenterPlot ActiveLayoutObj :vlax-false)
  24.   (vla-SetWindowToPlot
  25.     ActiveLayoutObj
  26.     (vlax-make-variant
  27.       (vlax-safearray-fill
  28.         (vlax-make-safearray vlax-vbDouble '(0 . 1))
  29.         (car Window)
  30.       )
  31.     )
  32.     (vlax-make-variant
  33.       (vlax-safearray-fill
  34.         (vlax-make-safearray vlax-vbDouble '(0 . 1))
  35.         (cadr Window)
  36.       )
  37.     )
  38.   )
  39.   (vla-Put-PlotType ActiveLayoutObj acWindow)
  40.   (vla-PlotToFile PlotObj FileName)
  41.   (foreach o (list PlotObj ActiveLayoutObj ActiveDocObj AcadObj)
  42.     (vlax-release-object o)
  43.   )
  44. )
用法:
  1. (PlotToFile
  2.   "DWG To PDF.pc3"
  3.   "ANSI_A_(11.00_x_8.50_Inches)"
  4.   (list (list 0 0) (list 100 100))
  5.   (strcat (getvar "DWGPREFIX") (getvar "DWGNAME") ".pdf")
  6. )
  1. (defun c:tt ()
  2.   (setq llpt (getpoint "\nll corner"))
  3.   (setq urpt (getcorner llpt "\nur corner"))
  4.   (PlotToFile
  5.     "DWG To PDF.pc3"
  6.     "ISO_A2_(594.00_x_420.00_MM)"
  7.     (list (list (car llpt) (cadr llpt))
  8.           (list (car urpt) (cadr urpt))
  9.     )
  10.     (strcat (getvar "DWGPREFIX") "FULL-FILE-NAME-TEST" ".pdf")
  11.   )
  12. )
已领礼包: 2230个
发表于 2021-1-29 10:34:42 | 显示全部楼层
做个对论坛有益的人。
已领礼包: 2759个
财富等级: 家财万贯
发表于 2021-1-29 10:40:30 | 显示全部楼层
多谢分享!
已领礼包: 418个
发表于 2021-1-29 13:18:01 | 显示全部楼层
非常有用,多谢分享。
GMT+8, 2026-11-4 07:25 , Processed in 0.505631 second(s), 38 queries , Gzip On.
