查看: 1498|回复: 1
[求助] 为什么读取txt文件里的坐标然后连线,但cad一开始就显示点无效
发表于 2021-3-17 16:22:51 | 显示全部楼层 |阅读模式
请教各位达人问题如题,为什么会显示点无效?怎么解决读取点坐标在连线?代码如下:
  1. (defun C:cop()
  2.   (setq datafile (getfiled "选取文件" "" "txt" 2 ))
  3.   (setq ff (open datafile "r"))
  4.   (setq data (read-line ff))
  5.   (command "pline")
  6.   (while data
  7.     (command data)
  8.     (setq data (read-line ff))
  9.   )
  10.   (command "")
  11.   (close ff)
  12.   (prin1)
  13. )
  14. (prompt "\n**********************<<C:cop>>*********************")
  15. (prin1)
发表于 2021-3-18 10:17:24 | 显示全部楼层
  1. (defun C:cop()
  4.   (setq data (read-line ff));;data为字符串类型
  6.   (while data
  7.     (command data);;这里的data应该需要为list类型,切符合点定义
  9.   )
  10.   (command "")
  11.   (close ff)
  12.   (prin1)
  13. )
  15. (prin1)
看上面的注释
GMT+8, 2026-11-3 10:46 , Processed in 0.554112 second(s), 30 queries , Gzip On.
