查看: 2224|回复: 0
[每日一码] 提取REGION内部原生曲线
发表于 2025-2-6 17:00:50 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()
  2.   (xdrx-begin)
  3.   (if (and (setq e (xdrx-entsel
  4.                      (xdrx-string-multilanguage
  5.                        "\n拾取要提取的路径<退出>:"
  6.                        "\nPick path to extract <exit>:"
  7.                      ) '((0 . "region,mpolygon"))
  8.                    )
  9.            )
  10.            (setq pt (cadr e)
  11.                  e  (car e)
  12.            )
  13.            (setq
  14.              loop (xdrx-getpropertyvalue e "closestloopto" pt)
  15.            )
  16.            (setq
  17.              yesorno (xdrx-yesorno
  18.                        (xdrx-string-multilanguage
  19.                          "\n是否包括内部路径"
  20.                          "\nDo you want to include internal paths"
  21.                        )
  22.                        1
  23.                      )
  24.            )
  25.       )
  26.     (progn
  27.       (setq loops (xdrx-getpropertyvalue e "childloops" loop)
  28.             loops (cond
  29.                     ((= yesorno 1)
  30.                      (cons loop loops)
  31.                     )
  32.                     (t
  33.                      (list loop)
  34.                     )
  35.                   )
  36.       )
  37.       (if (setq        loops
  38.                  (mapcar
  39.                    '(lambda (x) (xdrx-getpropertyvalue e "getloopat" x))
  40.                    loops
  41.                  )
  42.           )
  43.         (xd::drag:freemove
  44.           (setq ss (xdrx-entity-make loops))
  45.           (xdrx-getpropertyvalue (xdrx-entity-box ss) "9pt" 5)
  46.           (+ 1 4 128)
  47.           0
  48.           t
  49.         )
  50.       )
  51.       (princ)
  52.     )
  53.   )
  54.   (xdrx-end)
  55.   (princ)
  56. )
GMT+8, 2026-11-2 16:55 , Processed in 0.486160 second(s), 32 queries , Gzip On.
