查看: 1054|回复: 0
[原创] 关于图像元数据读写处理的相关函数用法
发表于 2025-3-19 00:51:14 | 显示全部楼层 |阅读模式
去下载 2025.03.18 的API
1. 图像EXIF 元数据查询,支持通配符,正则
xdrx-image-meta->exif
  1. Command: (xdrx-image-meta->exif "z:\\经纬度照片.jpg")
(("ApertureValue" "F8") ("BodySerialNumber" "0K8TGBL0121516") ("ColorSpace" "1") ("Contrast" "2") ("DateTime" "2022:05:09 12:14:51")
("WhiteBalance" "0") ("XResolution" "300") ("YResolution" "300"))
  1. Command: (xdrx-image-meta->exif "z:\\经纬度照片.jpg" "gps*")
(("GPSAltitude" "121 m") ("GPSAltitudeRef" "0") ("GPSLatitude" "41.878303916667") ("GPSLatitudeRef" "N") ("GPSLongitude" "124.039363305556") ("GPSLongitudeRef" "E") ("GPSTag" "778") ("GPSVersionID" "2"))
  1. Command: (xdrx-image-meta->exif "z:\\经纬度照片.jpg" GPSLongitude,GPSLongitude")
(("GPSLatitude" "41.878303916667") ("GPSLongitude" "124.039363305556"))
2. 读取图片XMP元数据,支持正则查找
xdrx-image-meta->xmp
  1. Command: (xdrx-image-meta->xmp "z:\\经纬度照片.jpg" "GPS*")
(("GpsLatitude" "+41.8783039") ("GpsLongitude" "+124.0393633"))
  1. Command: (xdrx-image-meta->xmp "z:\\经纬度照片.jpg")
(("AbsoluteAltitude" "+121.30") ("AlreadyApplied" "True") ("AutoLateralCA" "0")
3. 读取图片IPTC元数据,支持正则查找
xdrx-image-meta->iptc
  1. Command: (xdrx-image-meta->iptc "z:\\经纬度照片.jpg")
(("DateCreated" "2022-05-08") ("RecordVersion" "2") ("TimeCreated" "05:35:58+00:00"))
4. 集成了 exif, xmp, iptc 三个元数据 查找的 GPS相关的信息(GPS信息在 exif,xmp,iptc里面可能都有TAG)
xdrx-image-meta->gps
  1. Command: (xdrx-image-meta->gps "z:\\经纬度照片.jpg")
((("CameraSettings" ("ApertureValue" "F8") ("ExposureTime" "1/500 s") ("FNumber" "F8") ("FocalLength" "10.3 mm") ("FocalLengthIn35mmFilm" "28") ("LensModel" "28.0 mm f/2.8") ("LightSource" "1") ("Make" "Hasselblad") ("Model" "L1D-20c") ("ShutterSpeedValue" "1/500 s") ("Software" "Adobe Photoshop 23.1 (Windows)") ("WhiteBalance" "As Shot"))) (("GPS" ("GPSAltitude" "121 m") ("GPSAltitudeRef" "0") ("GPSLatitude" "41.878303916667") ("GPSLongitude" "124.039363305556"))) (("ImageDimensions" ("PixelXDimension" "5464") ("PixelYDimension" "3640") ("XResolution" "600") ("YResolution" "600"))) (("Orientation" ("FlightPitchDegree" "-2.80") ("FlightRollDegree" "-3.00") ("FlightYawDegree" "+92.70") ("GimbalPitchDegree" "+6.30") ("GimbalRollDegree" "+0.00") ("GimbalYawDegree" "+90.20"))))
5.一个集成了 ExifTool 所有功能的函数。
Command:xdrx-image<->exiftool
它可以读写图像元数据,操作一切,具体可以向 AI 询问。
例如:使用 ExifTool 设置图像分辨率。
你可以使用 ExifTool 读写图像的元数据,例如修改图像的分辨率。
下面是一些具体的操作示例:
**1. 查看图像的所有元数据**
查看图像的所有元数据,包括Exif、GPS等信息。
命令:
  1. (xdrx-image<->exiftool "image.jpg")
**2. 设置图像的原始日期和时间**
设置图像的拍摄日期和时间为指定的时间。
命令:
exiftool -DateTimeOriginal="2023:05:15 10:30:00" image.jpg
  1. (xdrx-image<->exiftool "-DateTimeOriginal=2023:05:15 10:30:00 image.jpg")
**3. 设置图像的作者**
设置图像的作者为“John Doe”。
命令:
  1. (xdrx-image<->exiftool "-Artist=John Doe image.jpg")
**4. 设置图像的标题**
设置图像的标题为“Vacation Photo”。
命令:
  1. (xdrx-image<->exiftool "-Title=Vacation Photo image.jpg")
**5. 设置图像的GPS坐标**
设置图像的GPS经纬度为(40.712776, -74.005974)。
命令:
  1. (xdrx-image<->exiftool "-GPSLatitude=40.712776 -GPSLongitude=-74.005974 image.jpg")
**6. 设置图像分辨率**
设置图像的分辨率为300 DPI,单位为英寸。
命令:
  1. (xdrx-image<->exiftool "-XResolution=300 -YResolution=300 -ResolutionUnit=inches image.jpg")
**7. 设置图像的作者并覆盖原文件**
设置图像的作者为“John Doe”,并覆盖原文件。
命令:
  1. (xdrx-image<->exiftool "-Artist=John Doe -overwrite_original *.jpg")
**8. 清除图像的GPS信息并覆盖原文件**
清除图像的所有GPS信息,并覆盖原文件。
命令:
exiftool -GPS:all= -overwrite_original image.jpg
  1. (xdrx-image<->exiftool "-GPS:all= -overwrite_original image.jpg")
**9. 清除所有元数据并覆盖原文件**
清除图像的所有元数据,并覆盖原文件。
命令:
  1. (xdrx-image<->exiftool "-all= -overwrite_original image.jpg")
**10. 查看图像的曝光时间、光圈和ISO**
查看图像的曝光时间、光圈值和ISO信息。
命令:
  1. (xdrx-image<->exiftool "-ExposureTime -FNumber -ISO image.jpg")
**11. 设置图像的版权信息**
设置图像的版权信息为“© 2023 John Doe”。
命令:
  1. (xdrx-image<->exiftool "-Copyright=© 2023 John Doe image.jpg")
**12. 重命名图像文件,使用拍摄日期和原文件名**
根据图像的拍摄日期和原文件名重命名文件。
命令:
  1. (xdrx-image<->exiftool "-Filename<${DateTimeOriginal}$Filename image.jpg")
**13. 查看所有Exif信息**
查看图像的所有Exif信息。
命令:
exiftool -Exif:all image.jpg
  1. (xdrx-image<->exiftool "-Exif:all image.jpg")
**14. 设置图像的颜色空间**
设置图像的颜色空间为Adobe RGB。
命令:
  1. (xdrx-image<->exiftool "-ColorSpace=Adobe RGB image.jpg")
**15. 设置图像的曝光补偿**
设置图像的曝光补偿为+1。
命令:
  1. (xdrx-image<->exiftool "-ExposureBiasValue=+1 image.jpg")
**16. 查看图像的白平衡信息**
查看图像的白平衡信息。
命令:
  1. (xdrx-image<->exiftool "-WhiteBalance image.jpg")
**17. 设置图像的白平衡为“自动”**
设置图像的白平衡为自动。
命令:
  1. (xdrx-image<->exiftool "-WhiteBalance=Auto image.jpg")
**18. 查看目录中的所有图像GPS信息**
查看目录中的所有图像的GPS信息。
命令:
exiftool -GPSLatitude -GPSLongitude -r /path/to/directory/
  1. (xdrx-image<->exiftool "-GPSLatitude -GPSLongitude -r /path/to/directory/")
**19. 清除目录中所有图像的元数据并覆盖原文件**
清除目录中所有图像的所有元数据,并覆盖原文件。
命令:
exiftool -all= -r -overwrite_original /path/to/directory/
  1. (xdrx-image<->exiftool "-all= -r -overwrite_original /path/to/directory/")
**20. 列出图像的所有标签**
列出图像的所有标签。
命令:
  1. (xdrx-image<->exiftool "-list image.jpg")
**21. 查看图像的缩略图**
查看图像的缩略图。
命令:
  1. (xdrx-image<->exiftool "-ThumbnailImage image.jpg")
**22. 将图像的元数据输出为CSV格式**
将图像的元数据输出为CSV格式并保存到文件。
命令:
exiftool -csv image.jpg > metadata.csv
  1. (xdrx-image<->exiftool "-csv image.jpg > metadata.csv")
**23. 设置图像的创建日期**
设置图像的创建日期为指定的时间。
命令:
exiftool -CreateDate="2023:05:15 10:30:00" image.jpg
  1. (xdrx-image<->exiftool "-CreateDate=2023:05:15 10:30:00 image.jpg")
**24. 设置图像的创建日期并覆盖原文件**
设置图像的创建日期为指定的时间,并覆盖原文件。
命令:
exiftool -CreateDate="2023:05:15 10:30:00" -overwrite_original *.jpg
  1. (xdrx-image<->exiftool "-CreateDate=2023:05:15 10:30:00 -overwrite_original *.jpg")
**25. 设置图像的曝光时间**
设置图像的曝光时间为1/250秒。
命令:
exiftool -ExposureTime="1/250" image.jpg
  1. (xdrx-image<->exiftool "-ExposureTime=1/250 image.jpg")
**26. 查看视频的时长**
查看视频文件的时长。
命令:
exiftool -Duration video.mp4
  1. (xdrx-image<->exiftool "-Duration video.mp4")
**27. 设置图像的制造商和型号**
设置图像的制造商为“Canon”,型号为“EOS 5D Mark IV”。
命令:
  1. (xdrx-image<->exiftool "-Make=Canon -Model=EOS 5D Mark IV image.jpg")
其他的用法,可以去問deepseek
GMT+8, 2026-11-22 07:37 , Processed in 0.381789 second(s), 9 queries , Gzip On, File On.
