查看: 1026|回复: 1
[求助] 编制一个关于视口的插件,但是一直报错.....
发表于 2025-3-24 15:45:08 | 显示全部楼层 |阅读模式
目的:
1、在模型空间内:所选范围内某个图层的矩形外框,
2、在布局空间内根据选择的外框开视口
2、在开视口时,可以选择预设视口大小(A0,A1,A2,A3,A4),并根据选择视口大小自动放大或缩小视口比例
3、在布局空间内视口可以选择摆放顺序
程序本体:
(defun c:PLSK ( / *error* ss lay rectData paperSizes paperSize vpSize scaleFactor pt arrange vpObj clayer_old)
  (vl-load-com)
  (setvar 'cmdecho 0)
  ;; 错误处理函数
  (defun *error* (msg)
    (princ (strcat "\n错误: " msg))
    (setvar 'clayer clayer_old)
    (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
    (princ)
  ;; 图纸尺寸库(单位:毫米)
  (setq paperSizes
      ("A0" 841.0 1189.0)
      ("A1" 594.0 841.0)
      ("A2" 420.0 594.0)
      ("A3" 297.0 420.0)
      ("A4" 210.0 297.0)
  ;; 步骤1:在模型空间选择矩形
  (setq clayer_old (getvar 'clayer))
  (initget 1)
  (setq lay (getstring "\n请输入目标图层名称: "))
  (princ "\n选择矩形外框: ")
  (setq ss (ssget (list (cons 0 "LWPOLYLINE") (cons 8 lay) (cons 90 4))))
  (if (null ss)
    (progn
      (princ "\n未找到符合条件的矩形!")
      (exit)
  ;; 获取矩形尺寸(修正坐标提取方式)
  (setq rectData (vlax-safearray->list
                 (vlax-variant-value
                  (vla-get-coordinates (vlax-ename->vla-object (ssname ss 0))))))
  (setq xCoords (mapcar 'car (mapcar 'list rectData (nthcdr 1 rectData)))
        yCoords (mapcar 'cadr (mapcar 'list rectData (nthcdr 1 rectData))))
  (setq rectWidth  (abs (- (apply 'max xCoords) (apply 'min xCoords)))
        rectHeight (abs (- (apply 'max yCoords) (apply 'min yCoords))))
  ;; 步骤2:切换到布局空间
  (command "_tilemode" "0")
  ;; 步骤3:选择图纸尺寸
  (initget "A0 A1 A2 A3 A4")
  (setq paperSize (getkword "\n选择图纸尺寸 [A0/A1/A2/A3/A4]: "))
  (setq vpSize (cdr (assoc paperSize paperSizes)))
  ;; 计算比例因子(添加单位转换)
  (setq scaleFactor
    (min
      (/ (car vpSize) (* rectWidth 1000.0))  ; 假设模型空间单位为米
      (/ (cadr vpSize) (* rectHeight 1000.0))
  ;; 步骤4:选择排列方向
  (initget "Horizontal Vertical")
  (setq arrange (getkword "\n选择排列方式 [Horizontal/Vertical]: "))
  ;; 步骤5:创建视口(修正命令调用)
  (setq pt (getpoint "\n指定视口插入点: "))
  (command "-vports"
           "_non" pt
           "_non"
           (polar pt
                   (if (eq arrange "Horizontal") 0 (/ pi 2))
                   (* (if (eq arrange "Horizontal") (car vpSize) (cadr vpSize)) 0.001))  ; 转换为米
  ;; 调整视口比例(添加错误保护)
  (if (setq vpObj (vlax-ename->vla-object (entlast)))
    (progn
      (vla-put-standardscale vpObj acVpCustomScale)
      (vla-put-customscale vpObj scaleFactor)
  (princ (strcat "\n创建完成,比例设置为 1:" (rtos (/ 1 scaleFactor) 2 2)))
  (princ)
发表于 2025-3-26 16:30:26 | 显示全部楼层
你报错提示你的是什么
现在你贴的函数,缺少 nthcdr 函数
GMT+8, 2026-11-22 07:19 , Processed in 0.343734 second(s), 10 queries , Gzip On, File On.
