- UID
- 771746
- 积分
- 89
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2017-10-19
- 最后登录
- 1970-1-1
(defun C:sdhjs (/ ss ent distTotal step offset lx ptFoot ptNext tanAng norAng ptOff num txtPt opt reverseFlg startDist fpath fobj)
(vl-load-com)
(setvar "CMDECHO" 0)
;;自动创建【环号】图层
(if (not (tblsearch "LAYER" "环号"))
(entmake '((0 . "LAYER")(100 . "AcDbSymbolTableRecord")(2 . "环号")(62 . 5)(70 . 0)(6 . "CONTINUOUS")))
;;选择中线:直线、多段线(含圆弧段)、轻多段线
(setq ss (ssget "_+.:E:S" '((0 . "LINE,PLINE,LWPOLYLINE"))))
(if ss
(progn
(setq ent (ssname ss 0)
distTotal (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent))
;;选择编号方向,默认1(起点开始)
(initget "1 2")
(setq opt (getkword "\n 编号方向 [1起点开始/2终点开始] <默认1>:"))
(if (not opt) (setq opt "1"))
(setq reverseFlg (= opt "2"))
;;输入布点间距
(initget 1)
(setq step (getreal "\n输入中线布点间距:"))
;;输入统一偏距 前进方向左负、右正
(initget "")
(setq offset (getreal "\n 输入统一偏距(前进方向左负/右正):"))
(if offset
(progn
;;选择保存坐标文件
(setq fpath (getfiled "保存" "中线坐标" "txt" 1))
(if fpath
(setq fobj (open fpath "w"))
(progn (princ "\n 未选择文件,不导出坐标!") (setq fobj nil))
;;写入文件表头
(if fobj
(write-line "编号,里程,X垂足,Y垂足,X放样点,Y放样点" fobj)
(setq num 1)
;;判断遍历方向
(if reverseFlg
(setq lx distTotal startDist (- step))
(setq lx 0.0 startDist step)
(while (if reverseFlg (>= lx 0.0) (<= lx distTotal))
;;获取当前里程中线垂足点
(setq ptFoot (vlax-curve-getpointatdist ent lx))
;;微小步长求切线方向
(if (< (+ lx 0.001) distTotal)
(setq ptNext (vlax-curve-getpointatdist ent (+ lx 0.001)))
(setq ptNext (vlax-curve-getpointatdist ent (- lx 0.001)))
(setq tanAng (angle ptFoot ptNext)
norAng (+ tanAng (/ pi 2.0))
ptOff (polar ptFoot norAng offset)
;;绘制垂线
(entmake (list '(0 . "LINE") (cons 10 ptFoot) (cons 11 ptOff)))
;;红色标记放样圆点
(entmake (list '(0 . "CIRCLE") '(62 . 1) (cons 10 ptOff) '(40 . 0.16)))
;;垂足编号【环号图层】文字偏移,不压线
(setq txtPt (polar ptFoot (+ tanAng (* pi 0.25)) 0.35))
(entmake (list '(0 . "TEXT")
'(8 . "环号")
'(40 . 0.30)
(cons 10 txtPt)
(cons 1 (itoa num))
'(50 . 0.0)
;;命令行输出坐标,保留4位小数
(princ (strcat "\n编号=" (itoa num) " 里程 " (rtos lx 2 4)
" ,X=" (rtos (car ptOff) 2 4)
" ,Y=" (rtos (cadr ptOff) 2 4)))
;;写入TXT文件:逗号分隔
(if fobj
(write-line
(strcat "编号=" (itoa num) " 里程 " (rtos lx 2 4)
", 垂足X=" (rtos (car ptFoot) 2 4)
", 垂足Y=" (rtos (cadr ptFoot) 2 4)
" ,放样X=" (rtos (car ptOff) 2 4)
", 放样Y=" (rtos (cadr ptOff) 2 4)
fobj
(setq lx (+ lx startDist)
num (1+ num))
;;关闭文件
(if fobj (close fobj))
(princ "\n 批量垂线生成完成,坐标文件已导出!")
(princ "\n未输入偏距,程序退出")
(princ "\n 请选中直线或多段线中线!")
(setvar "CMDECHO" 1)
(princ)
(princ "\n加载完成,命令:sdhjS")
(princ)
