- UID
- 14
- 积分
- 8265
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-4
- 最后登录
- 1970-1-1
- (vl-load-com)
- (defun get-item (collection item / result)
- (cond
- ((not
- (vl-catch-all-error-p
- (setq result
- (vl-catch-all-apply 'vla-item (list collection item))
- result
- (setq oAcad (vlax-get-acad-object) ; acadapplication object
- oDoc (vla-get-activedocument oAcad) ; activedocument object
- oLay (vla-get-layers oDoc) ; layers collection of activedocument
- (defun rCmdLayer (reactor data / cmd)
- (setq cmd (strcase (car data))) ; get command name
- (cond
- ((wcmatch cmd "*HATCH") ;is the command "*hatch"?
- (rCmdLayer-Setlayer "HATCH")
- (defun rCmdLayer-SetLayer (name / lay)
- (cond
- ((setq lay (get-item oLay name))
- (if (= :vlax-True (vla-get-lock lay))
- (progn
- (setq $laylock :vlax-True)
- (vla-put-lock lay :vlax-False)
- (if (= :vlax-False
- (vla-get-layeron lay)
- (progn
- (setq $layon :vlax-false)
- (vla-put-layeron lay :vlax-true)
- (if (= :vlax-True (vla-get-Freeze lay))
- (progn
- (setq $layfrz :vlax-true)
- (vla-put-Freeze layobj :vlax-false)
- (vla-put-activelayer aDoc lay)
- (defun rCmdLayer-Restore (reactor data / data lay)
- ;;;upon completion of command restores *layers* to previous state
- (defun al:restore (reactor info / cmd layobj)
- (setq cmd (car info))
- (if
- (and
- *capslock*
- (or
- (wcmatch (strcase cmd)
- "*LEADER,*QLEADER,*MTEXT,*TEXT,*DDEDIT,*ATTEDIT"
- (and
- (wcmatch
- (strcase cmd)
- "*DIM,*DIMLINEAR,*DIMALIGNED,*DIMORDINATE,*DIMRADIUS,*DIMDIAMETER,*DIMANGULAR,*DIMBASELINE,*DIMCONTINUE,*QDIM,*LEADER,*QLEADER,*MTEXT,*TEXT,*DDEDIT"
- (= (vlax-variant-value (vla-getvariable *adocobj* "dimaso"))
- 0
- (dos_capslock)
- (if (< (vlax-variant-value (vla-getvariable *adocobj* "cmdactive"))
- 2
- ) ;test for transparent commands
- (progn
- (setq layobj (vla-get-ActiveLayer *adocobj*))
- ;get ActiveLayer object
- (if offlay ; "hidden" layer noted as off (offlay not nil)
- (vlax-put-property
- (vla-item *layers*
- (if (wcmatch (strcase (car info)) "*HATCH")
- "Hidden"
- "Hatch"
- "LayerOn"
- 1
- ) ;turn "hidden" layer back on
- ) ;end if
- (if
- (and
- clobj ; clayer objobject assigned to clobj in al:laystate (clobj not nil)
- (not (equal clobj layobj)) ;if clayer object (clobj set in al:laystate) layer object
- ) ;end and
- (vla-put-ActiveLayer *adocobj* clobj) ;sets layer current
- ) ;end if
- (if layoff ; if the layer (layoff set in al:laystate) was noted as off (layoff not nil)
- (vla-put-LayerOn layoff 0) ;turn it off again
- ) ;end if
- (if layfreeze ; if layer (layfreeze set in al:laystate) was frozen (layfreeze not nil)
- (vla-put-Freeze layfreeze 1) ;freeze it again
- ) ;end if
- (if laylock ; if layer (laylock set in al:laystate) was locked (laylock not nil)
- (vla-put-Lock laylock 1) ;Lock it again
- ) ;end if
- (setq clobj nil
- offlay nil
- layoff nil
- layfreeze nil
- laylock nil
- ) ;set global variables to nil
- ) ;end progn
- ) ;end if
- ) ;end defun
- ;;;disables commandEnded reactor to avoid errors when using "new" and "open"
- ;;;in SDI mode. The error is merely annoying and only appears at the command
- ;;;line as "error: no function definition: al:restore" when opening or creating
- ;;;a new drawing. The cause of the error is commandEnded reactor present form
- ;;;last dwg but LISP has not yet loaded the called function in a new or opened
- ;;;dwg. Furthermore, the reactor cannot be removed because it has already been
- ;;;activated and is waiting for the command to end. Therefore, the reactor must
- ;;;be rendered non-functional by changing its call to the LISP command "LIST".
- (defun al:disable (reactor info / tdat)
- (if
- (= (vlax-variant-value (vla-getvariable *adocobj* "sdi")) 1)
- ;in SDI mode?
- (vlr-reaction-set
- (car (vlr-object
- '(VLR-Command-reactor
- nil
- '((:VLR-commandWillStart . al:autolay)
- (:VLR-commandEnded . al:restore)
- (:VLR-commandCancelled . al:restore)
- :VLR-commandEnded
- 'list
- ) ;end if
- ) ;end defun
- ;;;Here's where we set up the reactors to do all this cool stuff
- (vlr-set-notification
- (vlr-manager
- '(VLR-DWG-reactor nil '((:VLR-beginClose . al:disable)))
- 3
- 'active-document-only
- (vlr-manager
- nil
- 3
- ;;;get rid of old reactor if present. The reactor will be present, because in
- ;;;SDI mode, it's associated namespace is not destroyed, but has the new drawing
- ;;;loaded into it. At the time this file is loaded, this reactor is either not
- ;;;present or has been rendered useless (in SDI mode) at the closing of the last
- ;;;dwg and is excess loaded code bulk and should be removed. The VLR-MANAGER
- ;;;provides an easy means of doing this.
- (vlr-manager
- nil
- (:VLR-commandEnded . list)
- 1
- (princ
- "\nAutoLay V2.2 loaded. Type "autolay" or "capslock" to enable/disable."
- (princ)
- Set up and installation instructions:
- This is kind of an outline of the things you may need to edit to make this program work with your companies drafting standards.
- The main body of autolay has the conditions that must be tested for to see if a layer needs to be switched to or created. It is also
- where the layer name comes from. (al:laystate "Hatch" cmd) is the first such command (noted as cond 1) in the code to create or
- switch to a layer, where "Hatch" is to be the actual name of the layer to be created. The conditions will probably be the most
- difficult part to adapt to your companies drafting standards. Lets take a look at cond 6 for example:
- (;cond 5
- (wcmatch cmd "*TEXT");are you creating text?
- (al:laystate "Text" cmd);make, thaw, turn on and make current "Text" layer as needed
- );end cond 5
- If the command (cmd) is "*text", then create or switch to a layer named "Text". You can have as many conds and *layers* as you
- need. You can also add other parameters such as text style and/or size in different CONDS to put different text styles or sizes
- on different *layers*. That would then look more like:
- (;cond 6
- (and
- (wcmatch tst "~SIMPLEX");is the current text style NOT "Simplex"*
- (= tsz (* (getvar "dimscale") 0.0625));is this the current text size?
- );end and
- );end cond 6
- The routine al:ltype is the one that decides what linetype is assigned to a layer (name). Similar is true for al:lweight and al:color.
- Edit these to suit your companies drafting standards.
- One more thing. If you use a different linetype source file (.lin file format) other than acad.lin or acadiso.lin, you will
- have to edit in the name of the linetype file name in the al:mkLay routine.
- To disable AutoLay[2.2].lsp, type "autolay" at the commond prompt.
- This should be enough to get you going. Pick away, play around with it and learn from it until you get it to do what you want. I
- already did the hard part of coding and testing.
- Best Regards
- Eric Schneider|;
