查看: 1213|回复: 2
[求助] [求助]:在2004中,如何用lisp加载自己做的线型?
发表于 2003-7-28 19:48:30 | 显示全部楼层 |阅读模式
已领礼包: 593个
发表于 2003-7-28 20:07:38 | 显示全部楼层
Re: [求助]:在2004中,如何用lisp加载自己做的线型?
最初由 闲云 发布
[B]在2004中,如何用lisp加载自己做的线型? [/B]
用线型的替换字体样式
  1. (defun $XDLSP_CHECKFONT ()
  2.   (xdrx_sysvar_push "textstyle")
  3.   (if (not (tblsearch "style" "xdtb_efont"))
  4.     (command ".style" "xdtb_efont" "romans.shx" "0" "0.75" "0" "" "" "")
  5.   )
  6.   (if (not (tblsearch "style" "xdtb_cfont"))
  7.     (command ".style" "xdtb_cfont" "romans,hztxt" "0" "0.75" "0" "" "" "")
  8.   )
  9.   (xdrx_sysvar_pop)
  10.   (princ)
  11. )
  12. ;;; 错误处理
发表于 2003-7-29 08:38:52 | 显示全部楼层
最初由 闲云 发布
这是我做的一段程序,用于对图纸设置进行标准化,供你参考。
  1.   [FONT=courier new]
  2. (defun c:set_update (/               file_name
  3.                                           layersobj    ltypesobj
  4.                                           cs_layer     cs_color
  5.                                           cs_ltype     stylesobj
  6.                                           cs_textname  styleobj
  7.                                           blkobj
  8.                                          )
  9.   (setq file_name (open (findfile "shezhi.txt") "r"))
  10.   (setq        layersobj (vla-get-layers
  11.                     (vla-get-ActiveDocument (vlax-get-acad-object))
  12.                   )
  13.   )
  14.   (setq        ltypesobj (vla-get-Linetypes
  15.                     (vla-get-ActiveDocument (vlax-get-acad-object))
  16.                   )
  17.   )
  18.   (repeat (read (read-line file_name))
  19.     (setq cs_layer (read-line file_name))
  20.     (setq cs_color (read-line file_name))
  21.     (setq cs_ltype (read-line file_name))
  22.     (if        (not (tblsearch "layer" cs_layer))
  23.       (vla-add layersobj cs_layer)
  24.     )
  25.     (setq layerobj (vla-item layersobj cs_layer))
  26.     (if        (not (tblsearch "ltype" cs_ltype))
  27.       (vla-load ltypesobj cs_ltype "cs2003.lin")
  28.     )
  29.     (setq ltypeobj (vla-item ltypesobj cs_ltype))
  30.     (vla-put-color layerobj cs_color)
  31.     (vla-put-linetype layerobj cs_ltype)
  32.   )
  33.   (setq        stylesobj (vla-get-textstyles
  34.                     (vla-get-ActiveDocument (vlax-get-acad-object))
  35.                   )
  36.   )
  37.   (repeat (read (read-line file_name))
  38.     (setq cs_textname (read-line file_name))
  39.     (if        (not (tblsearch "style" cs_textname))
  40.       (vla-add stylesobj cs_textname)
  41.     )
  42.     (setq styleobj (vla-item stylesobj cs_textname))
  43.     (vla-put-fontFile styleobj (read-line file_name))
  44.     (vla-put-BigFontFile styleobj (read-line file_name))
  45.     (vla-put-Width styleobj (read (read-line file_name)))
  46.   )
  47.   (repeat (read (read-line file_name))
  48.     (setvar (read-line file_name) (read (read-line file_name)))
  49.   )
  50.   (close file_name)
  51.   (vla-CopyFrom
  52.     (vla-get-ActiveDimStyle
  53.       (vla-get-ActiveDocument (vlax-get-acad-object))
  54.     )
  55.     (vla-get-ActiveDocument (vlax-get-acad-object))
  56.   )
  57.   (vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object))
  58.              acActiveViewport
  59.   )
  60.   (princ)
  61. )
  62.   [/FONT]
附件是两个支持文件,请放在搜索路径中。
GMT+8, 2026-11-3 21:14 , Processed in 0.860161 second(s), 37 queries , Gzip On.
